Old 12-03-2024, 07:12 PM   #1
daniloneil8
Remote unlock not working. Key needs new battery? How?
Not keyless start.
I turn the key to start car.
But door and trunk unlock not working every time.
New battery
Video below
Got it done.
Did both keys.
5 for $4.40
daniloneil8 is offline   Reply With Quote
The Following User Says Thank You to daniloneil8 For This Useful Post:
humfrz (12-03-2024)
Old 12-03-2024, 07:54 PM   #2
Originally Posted by daniloneil8 View Post
Not keyless start.
Do I need new key?
Or can I change the battery?
No obvious battery slot
I'd suggest you put a new battery in it.
My 2013 key has a small slot near the top of the FOB, on the seam, that will open up the two halves by putting a flat tipped screwdriver in it and twisting.
Old 12-03-2024, 09:01 PM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
The car is totalled. You are done.
Or, maybe you could read the manual?
humfrz (12-03-2024)
Old 12-03-2024, 09:41 PM   #4
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Living life on the edge, less crowded, better view!
2018 tS Still in the family.
Stephen W. is online now   Reply With Quote
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
daniloneil8 (12-04-2024), humfrz (12-04-2024)
Old 12-03-2024, 11:00 PM   #5
Luns
Drives: 2017 GT86
The photo shared is of an uncut key, which I doubt is the actual key used by the OP. The texture of the plastic is similar to third-party replica key blanks I've had experience with. The replicas typically will accept an original transponder/remote module, but can vary quite a bit in the actual execution such that the two halves aren't interchangeable with genuine parts, and sometimes even a genuine remote doesn't fit well enough to work correctly.
It wouldn't surprise me if this key (or the one the OP is actually using) is missing the recess for a screwdriver to wedge apart the halves. If that's the key, the halves still need to be pried apart, and a knife would be a better tool to start attacking the seam than a screwdriver.
Luns is offline   Reply With Quote
The Following User Says Thank You to Luns For This Useful Post:
humfrz (12-04-2024)
Old 12-04-2024, 12:02 AM   #6
Oh, be nice now -
Old 12-04-2024, 08:41 AM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Yogi Berra, Buddha, or someone said (and I paraphrase): When you read the instructions, you get an education. You get experience when you don't.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
RT-BRZ (12-04-2024), Stephen W. (12-04-2024), Ultramaroon (12-04-2024)
Old 12-04-2024, 09:51 AM   #8
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
That reminded me of a quote I just heard the other day.
"Experience is a bitch. The test usually comes before the lesson."
RT-BRZ is offline   Reply With Quote
The Following User Says Thank You to RT-BRZ For This Useful Post:
blsfrs (12-04-2024)
Old 12-04-2024, 11:16 AM   #9
daniloneil8
I don't have the manual
Thanks tho
humfrz (12-04-2024)
Old 12-04-2024, 11:29 AM   #10
daniloneil8
My key does have the slot pictured in the helpful video.
Old 12-04-2024, 11:50 AM   #11
Thanks tho
Here ya go.
https://www.startmycar.com/us/scion/fr-s/info/manuals
Old 12-04-2024, 06:20 PM   #12
daniloneil8
Wrong key type for FRS.
I have BRZ
Old 12-04-2024, 09:29 PM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I have BRZ
Why does your profile say you drive an FRS?
Why have you not split the casing in half yet and replaced the battery?
Why are we still here
humfrz (12-04-2024)
Old 12-04-2024, 10:31 PM   #14
DarkPira7e (12-06-2024)
SOS button and Remote Services not working Robotaz GR86 General Topics (2nd Gen 2022+ Toyota 86) 11 03-30-2022 04:33 PM
Remote Lock/Unlock Issues STIMAN Issues | Warranty | Recalls / TSB 13 09-20-2021 07:01 PM
Remote won't unlock doors. Need help diagnosing problem. DeviantBlue Issues | Warranty | Recalls / TSB 21 06-05-2018 02:23 AM
Remote lock/unlock not working zdaughtry1 Electronics | Audio | NAV | Infotainment 2 03-16-2017 10:16 AM
Key fob battery died. Can I manually unlock without alarm going off? Stu L Tissimus Electronics | Audio | NAV | Infotainment 3 05-28-2016 06:06 PM
