Old 11-23-2024, 06:42 PM   #1
sam1
sam1's Avatar
Drives: GT86
Car alarm randomly going off
So, my stock car alarm out of nowhere started going of off like someone's trying to break into it. I would disable it, and it would just turn back on sometimes, other times it would stay off and then turn on randomly again. I had to disconnect the battery until I finally pulled the horn fuses.
Any idea what could be causing this?
The battery is about 3.5 years old; I checked the voltage and it's still good. There was a lot of corrosion build up on the terminal, but I cleaned all that up and it still went into alarm mode.
Online theirs some posts about a bonnet sensor issue, but it seems that was more related to the European models, doesn't look like the hood sensor is in the same place on North American models, I couldn't even find it on mine.
The alarm hasn't turned on today as of yet with the fuses out. I worry it'll happen again randomly so I'm just trying to see if anyone else experienced this?
2017 with 65k miles.
sam1 is offline   Reply With Quote
Old 12-08-2024, 01:14 AM   #2
sam1
sam1's Avatar
Drives: GT86
Update:
So, I didn't really do anything besides cleaning the battery terminals and the alarms haven't turned on randomly since then. I don't know if that was enough to fix it or if something else was just glitching out. I do plan on changing the battery in the near future as it is getting older. Just in case anyone else runs into this problem, hope it helps.
Aftermarket alarm removed, now alarm system won't work DaviKiNui Electronics | Audio | NAV | Infotainment 1 01-20-2018 06:17 PM
Car Alarm Randomly Going Off | Short & Intermittent majixmatrix Issues | Warranty | Recalls / TSB 1 11-06-2017 02:49 AM
USB disconnects randomly - no sound? Johnmh Electronics | Audio | NAV | Infotainment 1 08-15-2015 12:00 PM
AC HVAC turns on randomly DarkestBuddha Electronics | Audio | NAV | Infotainment 0 06-28-2014 09:53 PM
Car Alarm Randomly Triggers nathanR Electronics | Audio | NAV | Infotainment 2 09-03-2013 11:41 AM
