Old 06-14-2024, 03:55 PM   #1
Mike Roadway
Drives: 2023 BRZ Limited 6MT
First 7 Must-Do Mods
Hey Twiners,
Here's my latest video where I share my recommended first seven mods to our BRZs and GR86s.
The big point is not unplugging the fake engine noise as mod one...but it's certainly on the top seven list.
Let me know what you all think and what your first seven mods were or are going to be!
Cheers,
Mike
Mike Roadway is offline   Reply With Quote
The Following User Says Thank You to Mike Roadway For This Useful Post:
NoHaveMSG (06-23-2024)
Old 08-06-2024, 10:02 PM   #2
gregbent31
Drives: 2020 Toyota 86 GT
Thanks for sharing
gregbent31 is offline   Reply With Quote
The Following User Says Thank You to gregbent31 For This Useful Post:
Mike Roadway (10-02-2024)
Old 08-08-2024, 02:27 AM   #3
Why not just post the list of mods here, so we can discuss them? This is, after all, a forum.
pope (08-11-2024), RT-BRZ (12-11-2024)
Old 08-08-2024, 07:22 AM   #4
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Because that wouldn't drive views and clicks the their channel. But you already knew that.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
RT-BRZ (12-11-2024), Ultramaroon (08-08-2024)
Old 08-08-2024, 07:48 AM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
"Twiners" Heehee
Old 08-08-2024, 08:52 PM   #6
Don't forget to like and subscribe!
bcj (08-09-2024), RT-BRZ (12-11-2024)
Old 08-12-2024, 09:40 AM   #7
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
I mean, he also posted a link to a video about second-gen cars in the part of the forum for first-gen cars, so...
series.trackday is offline   Reply With Quote
The Following User Says Thank You to series.trackday For This Useful Post:
slim blanco (08-14-2024)
Old 10-10-2024, 01:38 PM   #8
Racecomp Engineering
My first 5 must do mods under $250 that I would do basically on day 2:
1. performance alignment (add camber bolts or OEM crash bolt)
2. Cusco heel/toe pedal
3. MTEC shifter springs
4. rear subframe inserts
5. rear diff mount inserts (removed front bottom)
Then next 5:
1. wheels and tires (properly sized and the right compound for your application)
2. suspension (properly selected for your application) with proper alignment
3. rear lower control arm
4. rear toe arm
5. MCA traction mod + rear trailing arm
Something like that. A few other bits I really like, but those are the things I'd be prioritizing if another BRZ/GR86 fell into my lap tomorrow.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
NoHaveMSG (10-12-2024), RT-BRZ (12-11-2024), Ultramaroon (10-10-2024)
Old 10-10-2024, 02:26 PM   #9
- Andrew
You don't mind the numb, squishy clutch? Gawd... like driving an old semi.
RT-BRZ (12-11-2024)
Old 10-10-2024, 04:37 PM   #10
Honestly I got my car with about 5k miles on it and I think the previous owner did the MTEC clutch spring (and the rest of the car was 100% stock which is odd). So it feels fine to me!
- Andrew
Old 10-10-2024, 05:11 PM   #11
- Andrew
Gotcha. Well, I'll still plug my mod here.
Agree with you, next up would be performance alignment. I love the Pedders top hats. Just a little sprinkle to get it closer to neutral.
NoHaveMSG (10-13-2024), Racecomp Engineering (10-10-2024), RToyo86 (10-10-2024)
Old 10-10-2024, 08:23 PM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
- Andrew
I've got all those done except the subframe inserts
Rear shifter bushing is also good
Whiteline transmission bushing insert would be an immediate. STi/TRD engine/trans are good too, just expensive by comparison.
I forgot I took mine out when I was diagnosing the clutch issue. Need to reinstall that!
Also quite happy with pedders. The added caster added a bit of steering weight for me. Wheel wants to pull to center faster If that makes sense.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Racecomp Engineering (10-10-2024), Ultramaroon (10-11-2024)
Old 10-10-2024, 10:39 PM   #13
How have I never heard of this mod.
Almost put the pedders mounts in there. They're good stuff.
Also good stuff! These little things do add up IMO.
- Andrew
Old 10-11-2024, 12:27 AM   #14
It's not very sexy, and a bit abstract for most. I've come to terms with my genius being underappreciated.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
NoHaveMSG (10-13-2024), Ohio Enthusiast (10-11-2024), Racecomp Engineering (10-11-2024), RToyo86 (10-11-2024)
What mods have you done so far? Rossi AFRICA 148 11-16-2015 02:41 AM
FIRST MODS! karma003 Scion FR-S / Toyota 86 GT86 General Forum 53 03-20-2014 04:00 AM
hey new here, what mods have you done so far ?? missbrz Scion FR-S / Toyota 86 GT86 General Forum 34 12-25-2013 10:15 PM
First Mods Skippman BRZ First-Gen (2012+) — General Topics 7 02-11-2013 08:14 PM
