Old 09-07-2024, 04:38 AM   #71
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by cmiovino View Post
RCE SS-1's (6k springs, even), with their camber plates up front, OEM ones in the rear.
Vorshlag vs RCE/KW camber plates won't make a huge difference in height between the two, comparing the two setups in terms of height should be very much the same.
I think that's way too low for T2s on the vorshlag plates. I recall that the RCE camber plates for SS raise the perch up a bit right? The vorshlag perches are actually lower than stock, meaning you lose bump travel. Anything below 13" is not going to go well at all.
Also: "Build Thread"
Old 09-07-2024, 04:41 AM   #72
Spuds
The Dictater
Spuds's Avatar
949’s ride height suggestions have a lot to do with their damper design droop/bump lengths, it shouldn’t be gospel, but I think it’s a great starting point.
@Spuds do you have the big oem tapered bolt in the upper hole of your strut? You have to use some level of camber bolt, even just the smaller oe bottom bolt to get past -4 degrees of camber even when the struts are slotted.
You know, that would certainly explain the camber problem. Yes, just used the OE bolts in the proper locations.
Racecomp Engineering (09-10-2024), strat61caster (09-09-2024)
Old 09-07-2024, 08:11 AM   #73
Tomyyyu
Drives:
And I think we should put out a PSA for people to not blindly following 949's guide. XIDA's rear shock has 7mm more travel than us, and that made a huge difference.
Tomyyyu is offline   Reply With Quote
The Following 2 Users Say Thank You to Tomyyyu For This Useful Post:
Spuds (09-09-2024)
Old 09-07-2024, 11:17 PM   #74
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Yes. Plus their guidance is geared towards track driving. A great track setup is not a great autocross setup. And vice versa.
Breezio is offline   Reply With Quote
The Following 2 Users Say Thank You to Breezio For This Useful Post:
Spuds (09-09-2024), Tomyyyu (09-08-2024)
Old 09-09-2024, 09:37 PM   #75
Spuds
The Dictater
Spuds's Avatar
FYI, raised the car, particularly the front end. 341/346mm, up from 336/342. It drives completely different now. Roll center, bro.
Also added a rear sway bar, but honestly the front end steering change is more pronounced.
Old 09-10-2024, 09:11 AM   #76
ZDan
ZDan's Avatar
Drives: '23 BRZ
If raising the car a bit significantly improved front grip, I'm still *guessing* (even more so) it was more of a front bump travel issue!
Raising the front of the car raises front roll center, which would increase lateral weight transfer up front if rear ride height were left the same, which should give more understeer (all other effects ignored for the moment). But of course raising the rear does the same thing in back, and it's really the F/R weight transfer distribution that affects handling balance.
I forget though, for which type suspension does roll center height move more with ride height changes, strut or multilink?
Spuds (09-10-2024)
Old 09-10-2024, 11:23 AM   #77
Our SS1/SS2/SSR camber plates should give you more bump travel at a given ride height vs the Vorshlag plates, but the Vorshlags give you caster and I think you can get a little more camber.
Bump travel in the rear is not nearly as much of a problem as people used to think IMO.
- Andrew
Spuds (09-10-2024), ZDan (09-10-2024)
Old 09-10-2024, 11:24 AM   #78
Using the "OEM crash bolt" is almost automatic for me at this point...easy and reliable 0.5 degree is nice to have.
- Andrew
Spuds (09-10-2024)
Old 09-10-2024, 03:54 PM   #79
Spuds
The Dictater
Spuds's Avatar
- Andrew
For future reference are the SSx plates compatible with Tarmac coilovers? (it's not obvious to me lol)
Old 09-10-2024, 03:57 PM   #80
Spuds
The Dictater
Spuds's Avatar
- Andrew
Bottom hole or top slot?
Old 09-10-2024, 04:21 PM   #81
Yes.
The "OEM crash bolt" is essentially using another set of the OEM lower bolts in the top hole/slot. The standard OEM bolt for the top hole has a shoulder which takes up space and prevents you from tilting the hub inwards more.
- Andrew
Spuds (09-10-2024), strat61caster (09-11-2024)
Old 09-10-2024, 06:55 PM   #82
ZDan
ZDan's Avatar
Drives: '23 BRZ
So be aware that with the SS plates you will likely lose some front camber as the strut protrudes up above the interface with the srut tower.
My car is kinda asymmetric, I was only able to get -3.2 degrees at the front left *with* factory camber bolt in the upper holes. Could probably could get around -3.8 at front right.
But for mid-corner front grip I'd rather have -3.2 camber *with* adequate bump travel than -4.5 with the outside front being overloaded due to being hard on the bumpstop... Also 330mm front ride height = no problemo...
Spuds (09-10-2024)
Old 09-13-2024, 02:46 PM   #83
900BRZ
Drives: 2022 Subaru BRZ
Originally Posted by ruturaj001 View Post
Hmm, looking up, this looks right, it is squared. I just started researching in to the topic and I agree that square spring rate doesn't make sense on twins. I was using @900BRZ 's blog.
https://900brz.com/posts/gr86-vs-brz
Looking at your numbers, we would be staggered by a much larger margin when trying to have square wheel rate. 60% stiffer in the rear.
Thanks for the mention and correction. I’ve updated the post.
900BRZ is offline   Reply With Quote
The Following User Says Thank You to 900BRZ For This Useful Post:
ruturaj001 (09-14-2024)
Old 09-14-2024, 01:18 AM   #84
ruturaj001
Drives: BRZ 2023
We all are learning. Your blog is how I got introduced to the topic and really like your organized approach. I wish someone would pick up your research and put it to good use, like improving their oil coolers like you did with upgrades. Companies making profit from these don't seem to have put as much effort as you did.
ruturaj001 is offline   Reply With Quote
The Following User Says Thank You to ruturaj001 For This Useful Post:
900BRZ (10-08-2024)
Understeer on '22 BRZ Fletch Tracking / Autocross / HPDE / Drifting 29 12-20-2022 10:09 PM
oversteer and understeer orc BRZ Second-Gen (2022+) — General Topics 76 10-05-2021 04:08 PM
Why does car understeer when going downhill? hpde_addict Tracking / Autocross / HPDE / Drifting 20 01-15-2018 10:42 AM
Understeer after new wheels carsebuco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-04-2017 06:49 PM
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 05:05 AM
