Old 09-04-2024, 02:30 PM   #1
daniloneil8
Help me find a valve cover gasket video?
I searched Youtube and didn't find one? Huh?
daniloneil8 is offline   Reply With Quote
The Following 2 Users Say Thank You to daniloneil8 For This Useful Post:
humfrz (09-04-2024)
Old 09-04-2024, 03:24 PM   #2
Might not exist. There are some excellent, detailed documents, all TSBs on the NHTSA website. I can share those links tonight after work if no other replies in the meantime.
It's quite an art. Buy some off-brand cheap stuff and practice on scraps before diving into the real thing. Experiment with squishing mating surfaces together and separate them to observe the results. Done properly, it takes surprisingly little sealant.
Spuds (09-11-2024)
Old 09-04-2024, 05:16 PM   #3
This might help (read entire thread).
https://www.ft86club.com/forums/showthread.php?t=141308
Ultramaroon (09-04-2024)
Old 09-04-2024, 06:02 PM   #4
daniloneil8
Blows my mind that not a single BRZ owner bothered to film such a routine maintenance task. Other cars would literally have a few dozen videos of this one task. Reminds me of how niche this car was.
Old 09-04-2024, 06:05 PM   #5
daniloneil8
On 2nd thought, I had no idea you need to pull the engine for such a common repair.
No wonder there are no videos, pulling the engine eliminates 99% of casual DIY'ers.
There's no vids because probably almost no one is doing this repair
Old 09-07-2024, 05:27 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s not a common issue on these cars like on the EJ. I’ve actually done EJ valve cover gaskets in the car. You need the valve cover gasket and threebond 1217H sealant or equivalent. It’s best done on an engine stand so you can rotate the head to the top so you can clean the surfaces and not have to worry about oil running back onto the sealing surfaces. DO NOT OVER APPLY THE SEALANT. Follow the FSM. It’s not a difficult job to do. It’s just a PITA. Might as well replace the TOB while you have the engine out.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Spuds (09-11-2024), Ultramaroon (09-08-2024)
Old 09-08-2024, 11:17 PM   #7
Valve Spring Recall Docs
Last revisions:
RCRIT-18V772-0191.pdf sealant job aid
1 - RCRIT-18V772-9195.pdf pg 1-30 2019.06.20
1 - RCRIT-18V772-9116.pdf pg 31-60
1 - RCRIT-18V772-8626.pdf pg 61-90
1 - RCRIT-18V772-8905.pdf pg 91-120
1 - RCRIT-18V772-9776.pdf pg 121-152
Revision history:
1 - RCRIT-18V772-1294.pdf pg 1-30 initial
1 - RCRIT-18V772-5230.pdf pg 1-30 2018.12.20
1 - RCRIT-18V772-6639.pdf pg 1-30 2019.03.27
1 - RCRIT-18V772-0400.pdf pg 1-30 2019.04.03
1 - RCRIT-18V772-1829.pdf pg 31-60
1 - RCRIT-18V772-2437.pdf pg 31-60
1 - RCRIT-18V772-5449.pdf pg 31-60
1 - RCRIT-18V772-7866.pdf pg 31-60
1 - RCRIT-18V772-0518.pdf pg 61-90
1 - RCRIT-18V772-1442.pdf pg 61-90
1 - RCRIT-18V772-3838.pdf pg 61-90
1 - RCRIT-18V772-6347.pdf pg 61-90
1 - RCRIT-18V772-3400.pdf pg 91-120
1 - RCRIT-18V772-5212.pdf pg 91-120
1 - RCRIT-18V772-5439.pdf pg 91-120
1 - RCRIT-18V772-6333.pdf pg 91-120
1 - RCRIT-18V772-2782.pdf pg 121-150
1 - RCRIT-18V772-5329.pdf pg 121-150
1 - RCRIT-18V772-5835.pdf pg 121-147
alex87f (09-13-2024), Spuds (09-11-2024)
Old 09-08-2024, 11:29 PM   #8
There's a wealth of info in those. I found it especially interesting to see the document evolve as Toyota learned the hard way how not to destroy these engines.
bcj (09-09-2024)
Old 09-11-2024, 03:07 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Lol there's no video or pictures on how to lift and support my other car (a modern Buick) anywhere on the internet or official service manuals. Literally best there is says to lift and support it safely with no further detail. This isn't so bad lol.
I had a leak at the front of my valve cover. I cleaned it up and just put extra RTV over the leak. It mostly works. Needed a few times to figure it out.
Also: "Build Thread"
Ultramaroon (09-13-2024)
Old 09-13-2024, 07:00 PM   #10
Spuds (09-16-2024)
Old 09-14-2024, 10:13 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I should do one and be the first then.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (09-14-2024), Spuds (09-16-2024), Ultramaroon (09-15-2024)
Valve cover gasket replacement knucklehead Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 05-06-2021 07:38 PM
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 01:52 AM
Other Oil leaks - Oil Pan gasket? - NOT Cam plate, valve cover, or Cam cover exE36M3 Issues | Warranty | Recalls / TSB 17 11-08-2017 11:15 AM
Valve Stem Gasket VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-28-2016 07:57 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 09:31 AM
