| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: 2013 frs base
I've driven around this week. No change in the P0341 code. The engine runs really well, good power. Today, I tried use my Ecutek stuff to datalog but I couldn't get it to connect to my ecu. I've read where their cables can be dodgy. I'm going to see if someone in my area has a scan tool. Maybe I can figure out where my issue is without throwing parts at it.
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: | Teseo (08-19-2024), Ultramaroon (08-19-2024) |
#30 |
I don't like this. Wish I could attach my OBDLink to verify that your VVT is operating properly (slewing). Do you have TechStream?
#31 | |
The car runs great. No drivability issues at all. This leads me to believe that the vvt is operating correctly and the ecm, for some reason, likes this code. |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | Teseo (08-20-2024), Ultramaroon (08-20-2024) |
#32 |
Alternator and bracket
If you do one of these swaps, get the 2022+ alternator AND bracket.
You can trim the old bracket and almost make it work with a 2022+ belt but mine always had a slight squeak similar to the "crickets". RS said to shave the bracket to move the alternator back 1/8" but then I didn't think the idler pulleys would align. I found a 2022+ bracket thought I was home free. The 22+ alternator is slightly different. I made it work but ended up using a 2013 belt. The P0341 is still a problem. RS said he is going fly out here to fix it. |
| The Following 13 Users Say Thank You to blsfrs For This Useful Post: | alphasaur (09-08-2024), BatStig (09-10-2024), brandonblt2 (09-17-2024), JBezugs (09-09-2024), kmbkk (09-09-2024), makinen (11-03-2024), NoHaveMSG (09-08-2024), RT-BRZ (09-09-2024), Spankopotomous (09-14-2024), T-Steve (09-08-2024), Tatsu333 (09-12-2024), Teseo (09-09-2024), Ultramaroon (09-09-2024) |
#33 |
Drives: Toyota 86
| The Following 3 Users Say Thank You to makinen For This Useful Post: |
#35 |
#36 |
watching this thread. May I ask on the cost of the motor?
2013 Series 10 FRS #553
#38 |
Thanks for asking. My car is fixed and I'm waiting for RMS to tune it and then ship it back to Va. The saga of the issue is here:
https://www.ft86club.com/forums/showthread.php?t=154967 |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | T-Steve (12-04-2024), zc06_kisstherain (12-04-2024) |
#39 |
The saga is over. My FRS arrived home earlier this afternoon.
Now that the FA24 is tuned, the car accelerates like a bat out hell. No dyno printout as the car was road tuned. RSM is great to work with and stands behind his product. If only certain a customer was a better diagnostician. |
| The Following 9 Users Say Thank You to blsfrs For This Useful Post: | autoracer86 (12-14-2024), kmbkk (12-16-2024), makinen (12-14-2024), RToyo86 (12-20-2024), Spuds (12-20-2024), T-Steve (12-11-2024), Tatsu333 (12-14-2024), Teseo (12-12-2024), Ultramaroon (12-12-2024) |
#40 | |
Drives: 2022 Toyota GR86 Premium 6MT
edit: nvm, just saw the other thread lol. defective sensor out of the box, wack. not unheard of though. |
| The Following User Says Thank You to removedonut For This Useful Post: | blsfrs (12-21-2024) |
#41 | |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | Tatsu333 (12-26-2024), Ultramaroon (12-21-2024) |
| FA24 swap to a GT86 ? Anything I need be aware of? | twasd | Engine Swaps | 23 | 01-09-2024 11:28 PM |
| Viability of complete FA24 swap (motor and ECU)? | Tatsu333 | Engine Swaps | 43 | 02-18-2023 07:18 PM |
| FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 09:27 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 11:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 04:59 PM |
