Drives: White FR-S kosei k4r 17x8
America's tire technician overfilled my tires
Almost a month ago I got some new continental tires at America's tire which they installed. Today my OCD kicked in and I checked the tire pressure(tire's max rating is 51), and found one of the front tires was filled to 86psi!!.
How bad is this? I've been driving in 100F+ heat for a few weeks like this, was I in danger of a tire blowing up? Should I get them to replace the tire? Also curious what tire pressure y'all prefer for daily/spirited driving. Last edited by jiffyjhn; 07-13-2024 at 12:06 AM. |
| The Following User Says Thank You to jiffyjhn For This Useful Post: | humfrz (07-13-2024) |
#2 | |
If your tires have not blown from that pressure, they should be OK, once the pressure is reduced. I have found that it is not unusual for shops to overinflate tires (usually about 5 psi). Your car should have a sticker around the door jam that gives the recommended tire pressure. The same pressure will usually work OK for both daily and spirited driving. |
#3 | |
I'm starting to think they did it as a joke to put 86psi in a 86. |
#4 |
Drives: 2013 frs base
I hope they didn't top off any of your car's fluids. No telling what they would have put in there.
#5 |
#6 | |
#7 |
The Dictater
Drives: '13 Red Scion FRS
Probably fine if you reduce pressure down to a decent setting. Might have a bit more wear in the center on that tire but if it was only a month shouldn't be perceptible in the long run. Wouldn't go back to that location again if I were you.
Recommend to keep checking pressures every few days.
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | jiffyjhn (07-14-2024) |
#8 | |
When radial tires came out, they always looked low on pressure (to me at least). So, check the pressure more often was a good idea. Most newer cars come with a little figure that pops up on the dash that warns of low tire pressure. However, it won't tell you if the tire is over inflated - ![]() Since tire pressures won't get too much over inflated, all by themselves, someone would have to over inflate them. Back in the day, most people wouldn't over inflate tires because it took too much effort - ![]() It must be my nap time! |
| The Following User Says Thank You to humfrz For This Useful Post: | blsfrs (07-15-2024) |
#9 | |
Rice King
Thanks, Qualified Total Loss Inspector
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
| 2016 SCCA Track Night in America Driven by Tire Rack | ft86Fan | Tracking / Autocross / HPDE / Drifting | 50 | 06-25-2016 02:06 PM |
| SCCA Track Night in America Driven by Tire Rack | ft86Fan | Tracking / Autocross / HPDE / Drifting | 0 | 08-18-2015 07:09 PM |
| America's Tire Damaged My Wheels. | Lust | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 07-28-2015 09:58 PM |
| Subaru Wiring technician expert help... | Trap63 | Electronics | Audio | NAV | Infotainment | 2 | 08-06-2013 04:47 PM |
