Old 04-13-2024, 10:39 PM   #1373
M0nk3y
You need a pre-2017 airbox for compatibility
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
DocWalt (04-15-2024), mikalem (04-14-2024)
Old 06-26-2024, 12:14 AM   #1374
86prime
Drives: 18 BRZ tS
Harrop SC doesn't fit with the stock 2017+ airbox?
86prime is offline   Reply With Quote
Old 06-27-2024, 12:40 PM   #1375
Tatsu333
Drives: 2020 BRZ Sport Tech RS
It uses a custom airbox rear piece that mates to the pre-2017 manual / all years automatic airbox front piece and uses the stock filter.
Tatsu333 is offline   Reply With Quote
Old 10-10-2024, 02:05 PM   #1376
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I'm going to an 85mm pulley from the 95. Does anyone know what belt I need?
TommyW is offline   Reply With Quote
Old 10-10-2024, 09:58 PM   #1377
ArCha
Drives: 2013 Subaru BRZ SWP
Continental 4060965 is what Harrop sent me although I've also used the standard length (4060970) with no issues.
ArCha is offline   Reply With Quote
Old 10-15-2024, 07:58 PM   #1378
Eaton PSI
Drives: 2013 86
I'm running 85mm pulley with conti 4060970/6PK2465 belt. No issues.
Eaton PSI is offline   Reply With Quote
Old 10-18-2024, 09:02 AM   #1379
grumpysnapper
grumpysnapper's Avatar
A long confusing diagnosis ...but, um, a happy ending!
Its a very long, and maybe boring, story…
For a couple of years now I had been getting some idling issues and a slight degree of breaking down at very high and sustained revs.
My engine guy was a bit mystified… the Motec was showing nothing, and everything else was seemingly ok.
On the days when I was using it hard on a dirt circuit it would also go into limp mode towards the end of a long day.
Very high intake temps.
I live in a fairly warm to hot part of the world, so discussing it with the mechanic we both were comfortable that it was most probably the simple explanation of a small motor at sustained high revs, producing a lot of power, going sideways (so not a clean airflow) with the legacy of a massive amount of heat sink from hours of “play” (by the end of the day the gear stick is burning hot… almost untouchable).
Then about 6 months ago there was a horrendous noise from under the front of the car…the electric pump for the supercharger had thrown a wobbly.
Replacing it, I found the entire intercooling system was dry…bone dry! Super weird, absolutely no leaks I could find anywhere…pump, hoses, radiator… nothing.
Confused..I was totally sure I had checked its level in the last few years…and it was fine. In the time before the built engine it was almost pointless checking…there was never any loss.
But maybe I hadn’t filled it after the rebuild? Maybe the mechanic drained it at some point and didnt refill? Had I just not noticed a leak?
So refilled it with a different coloured coolant so I could easily spot any specific leaks from that system over the normal cooling system.
Sure enough after a week or two the level had dropped a little.
But still no visible leaks.
Top up, then same again.
Top up, ring Harrop… “that sounds strange, should be zero coolant consumption…should last years… have you checked every inch of pipe, the back of the front cooler…all the hard to reach/see things?”. Yep I think so, but I’ll triple check under and behind things. Nothing.
Next rally day comes, I pre mix and load up 5 litres (!) of supercharger coolant for the day…just in case.
A small amount missing when I arrive at the track. Top up.
After a couple of hours….lots missing , maybe 750ml.
Top up. Before lunch another whole litre gone.
Afternoon run…check…empty. Dry.
So of course you know how it ends.
Take supercharger off, a pile of bright green dried up gunk in all intakes and spread on the back of the throttle body and inside the intake casing.
Ship to Harrop…tear down, failed intercooler cores. Right side the most clogged/messy. But crap all through them both.
Both replaced and a service for the whole unit while its there.
Harrop were super quick and efficient, and it wasnt as bad as I thought it would be cost wise.
The unit has been worked pretty hard for around 8 years, but they said it was highly unusual, might have been due to that specific coolant type (although the stuff I used was within spec), might have been through fatigue in this specific type of use (vibrational issues), might just have been a couple of dodgy cores.
Bolted back on, no idle issues, clean revving and more power (its funny how you don't notice a gradual decline...) …..full strength and smooth. Happy.
grumpysnapper is offline   Reply With Quote
The Following 3 Users Say Thank You to grumpysnapper For This Useful Post:
Code Monkey (10-18-2024), DocWalt (10-18-2024), Kiske (12-18-2024)
Old 10-18-2024, 11:12 AM   #1380
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
What a bizarre failure! Glad there was no lasting damage and you had a safe tune that pulled power as IATs climbed!
The Following User Says Thank You to DocWalt For This Useful Post:
grumpysnapper (10-18-2024)
Old 05-26-2025, 02:31 AM   #1381
TripleTapHK
TripleTapHK's Avatar
Drives: 2016 Subaru BRZ Edelbrock Kit
Does anyone know if there is an outlet that sells individual parts for the Harrop kit? Looking for the clean air side of the airbox and the hose.
TripleTapHK is offline   Reply With Quote
Old 05-29-2025, 10:36 AM   #1382
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Contact Harrop USA, they'll get you sorted.
Old 05-29-2025, 10:38 AM   #1383
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Installed my kit yesterday. A few "hmmm" moments during the install and man, bleeding the air is a PITA.
Old 08-09-2025, 06:51 AM   #1384
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
good times. out of interest, which front strut brace are you running with your setup? thinking of this kit and want to keep running a front strut brace so need one that is going to clear the SC.
sneaky_pete is offline   Reply With Quote
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
