Old 06-06-2024, 06:03 AM   #1
B00STED86
Drives:
New rims offset question
So I’m looking to grab a set of 17x9 Japan racing jp19’s. Could I run a 215/45/17.
Or go 225?
My current rims are 18x9.5 with 235/40/18 and I rub at full lock at the top of the well
My suspension setup in the front is
Megan street coilovers 8kg
Megan inners
Gk tech angle kit
25mm adj sway bar
Megan adj endlinks
So the offset is from 10-25 and I do have a set of 25mm spacers if needed. What offset should I select so I don’t rub at full lock? I’m a bit confused when it comes to offset.
Thanks in advance
B00STED86 is offline   Reply With Quote
Old 06-06-2024, 06:17 AM   #2
B00STED86
Drives:
Would I be better off with 17x8?
Old 06-06-2024, 06:18 AM   #3
B00STED86
Drives:
Current rims are +35
Old 06-06-2024, 10:46 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
If you want 17x9s, +35 range is ideal. You don't want to go lower that will make your problems worse.
17x8 will give you more room. +35 is decent with no camber, can definitely go lower for flush fit, probably +25 range.
Old 06-06-2024, 06:54 PM   #5
B00STED86
Drives:
Thanks for that. But I have another question. Since the rims only go up to +25 if I ordered a +10 and added a 25mm spacer does that essentially give me +35?
Old 06-06-2024, 07:59 PM   #6
RToyo86
RToyo86's Avatar
Adding spacer reduces or lowers the wheels effective offset, which equals more poke.
+10 offset +25mm spacer = -15 offset.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
B00STED86 (06-06-2024), Wally86 (06-07-2024)
Old 06-13-2024, 01:09 PM   #7
redlined600
redlined600's Avatar
Drives: Fr-s
It's really hard to provide input on a question like this because it's so dependent on so many variables. Ride height, camber, where the camber is achieved, angle kit, spring diameter, tire cross section.
Best thing you could do is put your current wheels at full lock and get in there with a flash light and see where you're rubbing (or close). Then you can conceptualize moving the wheel/tire in or out from there. If you go to a lower offset, look where you might have future issues.
More positive offset = closer to the center of the car, less offset or negative offset = further out. In terms of the offset number, think of a spacer as subtraction, not addition.
https://www.lesschwab.com/article/wh...el-offset.html
Just a guess, but with a +25 offset you'll likely rub the fender liner at a minimum.
redlined600 is offline   Reply With Quote
WTB: Wedssport SA10R rims in 18 x 9.5 + 45 offset BassBoosted86 Want-To-Buy Requests 3 08-15-2017 10:14 PM
Thoughts on turning down rims to change offset? Triumphrider Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-22-2015 01:12 PM
FS: 17x8 35 offset Drag rims with tires Ryeong86 Wheels and Tires 4 05-31-2013 09:55 PM
VOLK TE37SL RIMS 18 x 9" +45 offset [bris] GC GTS Aero Kit Australia Classifieds 12 05-30-2013 03:11 AM
Which Five Axis S5:F Rims? Which Offset? sharkasport AUSTRALIA 8 12-11-2012 01:21 AM
