Old 05-13-2024, 03:43 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Verus hood vents
Are there any downsides to running Verus hood vents?
I’d like the added venting out of the engine compartment. Especially at the track.
I don’t DD the car any longer so it’s seldom out in the rain, except if caught while pleasure cruising or on a road trip.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 05-13-2024, 04:56 PM   #2
jflogerzi
jflogerzi's Avatar
Trackspec hood vents are better but will require more of the hood to be cut.
2013 Series 10 FRS #553
Old 05-13-2024, 06:02 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
They don't look gud
I've noticed that hood vents increase the HVAC intake temperature, since it's pulling air out of the bay and dumping it into the windshield/cowl where your cabin intake is.
EndlessAzure is offline   Reply With Quote
Old 05-13-2024, 07:14 PM   #4
CSG Mike
CSG Mike's Avatar
Originally Posted by EndlessAzure View Post
They don't look gud
OP is asking for a track application... HVAC intake temp is probably less of a concern there!
That said, in normal driving conditions, there should be minimal to no impact on AC performance.
RT-BRZ (05-13-2024)
Old 05-14-2024, 08:04 AM   #5
M0nk3y
I think the Verus Hood Vents are a great first step in hood venting. it's a relatively easy installation, their templates are great to utilize, place and install.
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
kask2_6.0 (05-20-2024), RT-BRZ (05-14-2024)
Old 05-14-2024, 09:25 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Very happy that I installed mine. If I could do it over, I'd just go Trackspec though. No need for half measures
jflogerzi (05-14-2024)
Old 05-14-2024, 08:48 PM   #7
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
I regret not going with the full sized Trackspec vents. I used a Civic Type R vent which helps with cooling, but reduction of lift is likely limited due to the size. I’ll likely end up getting a new hood and getting the full sized BRZ vents
Wangspeed is offline   Reply With Quote
Old 05-18-2024, 12:30 AM   #8
gr8
Drives: GR86
My Verus hood vent cracked and somewhat melted, would not recommend if you intend to track heavily or run in hot weather.
gr8 is offline   Reply With Quote
The Following User Says Thank You to gr8 For This Useful Post:
Wangspeed (05-18-2024)
Old 05-18-2024, 02:05 PM   #9
DarkPira7e
DarkPira7e's Avatar
You cracked and melted ALUMINUM? I think maybe you should double check what you're seeing.
Old 05-18-2024, 06:59 PM   #10
Muskoka800
My thoughts exactly.
Perhaps he cracked/melted the optional rain guards. They are plastic.
Old 05-19-2024, 01:21 PM   #11
redlined600
redlined600's Avatar
Drives: Fr-s
The GR86 version (center exit) is ABS plastic.
redlined600 is offline   Reply With Quote
Old 05-19-2024, 08:53 PM   #12
gr8
Drives: GR86
Yea, unfortunately the GR86 hood vent is plastic. Get the TrackSpec one, you’ll want the added reduction of lift anyways.
Old 05-19-2024, 11:18 PM   #13
DarkPira7e
DarkPira7e's Avatar
What in the hell were they thinking? Plastic, bridging that much of a gap? Seems certain it'll buckle in the middle with high speed pressure
Old 05-20-2024, 11:25 AM   #14
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
There is also a third option!
kask2_6.0 is offline   Reply With Quote
Verus Hood Vents w/Rain Guards M0nk3y Exterior Parts (Aero, Lighting, Etc.) 2 12-07-2023 08:19 AM
WTB verus hood vents alphasaur Want-To-Buy Requests 0 08-23-2023 09:57 AM
Verus Hood Vents Castswag Exterior Parts (Aero, Lighting, Etc.) 5 06-30-2021 06:15 PM
Verus hood vents norcalpb Exterior Parts (Aero, Lighting, Etc.) 4 12-09-2020 09:05 PM
Wtb: hood vents or carbon fiber vented hood Pooponwindows Want-To-Buy Requests 0 05-25-2018 01:24 PM
