Old 04-18-2024, 10:35 PM   #1
Arguru
Drives: Subaru BRZ 2016
87mm High Comp Pistons
Toda Power Liner Kit Toyota GT-86 2012+
Toda Increased Capacity 2300 KIT Toyota GT-86 2012+
-or-
HKS 2.2L Complete Engine FA20 Step 3 Subaru | Scion | Toyota 2013-2020
If I where to use these kits to increase engine capacity. Why is it seemingly impossible to find high quality 87mm High compression ratio pistons? I want 87mm Pistons, 12.5 cr or 12.7 cr. Or is it possible to modify the HKS Pistions before ordering? I want higher compression ratio and bigger bore. Also, I need the valves to match.
-I dont care about FI(Forced Induction), as I am a NA (Naturally Aspirated) fan, and will remain that way.
Arguru is offline   Reply With Quote
Old 04-19-2024, 07:06 AM   #2
tomm.brz
Drives: brz 2017 hksv2
with the cost of those is probably cheaper a long block fa24 and goes faster..
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Tatsu333 (04-20-2024), Teseo (04-19-2024)
Old 04-19-2024, 08:58 AM   #3
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Umm the prices online are 30-40k for this are you really going to spend that much on a gt86 motor
autoracer86 is offline   Reply With Quote
Old 04-19-2024, 09:43 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Waayyyy cheaper. I've seen entire FA24 running assembly with trans locally for 9k.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 04-20-2024, 05:39 AM   #5
Eaton PSI
Drives: 2013 86
It is impossible, so I decided to improvise. Custom made 90mm 11.5:1 pistons and custom sleeves. Modified OEM head gaskets. Just under 2.2L on the stock crank.
Eaton PSI is online now   Reply With Quote
The Following 3 Users Say Thank You to Eaton PSI For This Useful Post:
DocWalt (04-24-2024), RToyo86 (04-21-2024), Tatsu333 (04-21-2024)
Old 04-20-2024, 05:44 AM   #6
Eaton PSI
Drives: 2013 86
Sleeves were made by LAsleeve. They'll likely make you another set if you ask them. Some of the forged piston manufacturers will do custom stuff. Gaskets are trickier... I got greedy and had to machine a bit out of stock ones to get 90mm. If you keep it sensible the stock gaskets are good for 89.5mm
The Following 2 Users Say Thank You to Eaton PSI For This Useful Post:
DocWalt (04-24-2024), Tatsu333 (04-21-2024)
High compression forged pistons? jRuN Forced Induction 1 01-14-2020 11:06 PM
High Compression pistons EN2_Squirrel Engine, Exhaust, Transmission 23 05-01-2014 03:29 PM
13.5:1 Pistons woode Forced Induction 13 04-28-2014 12:06 AM
Best pistons to use and Comp ratio? Fabron757 Forced Induction 36 02-05-2014 04:21 PM
12.5/1 Comp Forged Rods and Pistons Darryljr11 Engine, Exhaust, Transmission 1 10-26-2013 08:11 PM
