Old 04-15-2024, 12:54 PM   #1
Bergycheese348
Bergycheese348's Avatar
Drives: TRD Supercharged 2016 FR-S
FR-S USB port charging pin w/ TRD gauges
I have the TRD Sport Meter Set, and doing so replaces the OEM headunit. Because the headunit is no longer present, I assume that the wiring for the charging port is open and not closed, hence why it will not charge anything (I would assume it goes straight to the port, then headunit for aux, then to ground). Is there any info on how to make it effectively charge something? Preferably I would depin the wires behind the headunit to make it work so I do not have to work behind the dash too much.
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace
Bergycheese348 is offline   Reply With Quote
Old 04-15-2024, 02:55 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I wouldn't bother with recycling the aux/USB port for charging. It's not rated for modern fast charging (I think 5V 1.5A at best, but it's 500mA more likely) and will be abysmal for powering anything
EndlessAzure is offline   Reply With Quote
So what are yall using for gauges for ur boosted builds? (SHOW ME UR GAUGES!) BlaqkHavok Forced Induction 30 07-04-2022 11:25 PM
OEM usb port not charging cell phones (sometimes) szjalo Electronics | Audio | NAV | Infotainment 5 09-28-2017 03:21 AM
Can't use Bluetooth audio when I'm charging my phone through USB port Eddie Electronics | Audio | NAV | Infotainment 13 06-05-2014 12:54 AM
USB port charging issue unsurety Issues | Warranty | Recalls / TSB 2 05-17-2014 03:49 PM
adding a second usb port for charging? Reason Electronics | Audio | NAV | Infotainment 5 07-11-2012 08:47 AM
