#15 | |
Drives:
Yes. The new tune is for the ID 1050x An error must have occurred or I did something wrong. I’m getting a error stating that the ECU VIN () does not match ROM VIN Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to B00STED86 For This Useful Post: | x808drifter (03-05-2024) |
#16 | |
Drives: brz 2017 hksv2
if not, then this is entirelly useless as it s not same tune and same logic and same injection splitting this car, if the tuner doesn t put active work into it to make it stable, gives idle problems with big injectors there is a brief moment when warm specially, that the car will idle for some seconda only with PI but car is warm and low idle speed so the big injectors struggle to mantain afr since they d have to inject a very small amount of fuel and they are not able to provide it nicely because it s out of their linearity range |
#17 | |
another guy had same issue, he flashed baxk to stock and license was wiped somehow and then ecutek will give anothwr license for free as long aa you provide the log they will ask you |
#18 | |
Drives: None
#19 | |
Drives:
Thank you for the information. I will be send them and email right now. Sent from my iPhone using Tapatalk |
#20 | |
Rust bucket enthusiast
They should be familiar with it. SO familiar that maybe they've grown used to generic latency and adjustment settings? I'm sure they do great, but everyone makes mistakes.
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | tomm.brz (03-06-2024), x808drifter (03-06-2024) |
#21 | |
Drives:
Stalling after ID 1050X install and new tune
So EcuTek said that whoever did the previous tune (I don’t have a way to contact the previous owner) deleted the VIN from the ECU. How do you go about putting that information back on to the ECU? Can a dealership do that, or can I take it to any shop that has a scan tool? Sent from my iPhone using Tapatalk |
#22 | |
i was just saying that it's kind of easy to have them behave bad on warm start in this car, and i ve seen it more than a couple of times with that particularly tuner he went to |
| The Following User Says Thank You to tomm.brz For This Useful Post: | RedReplicant (03-06-2024) |
#23 | |
https://www.ft86club.com/forums/showthread.php?t=102810 or by any dealer with the official software so only officials Toyota or Subaru, either techstream or ssm3 |
| The Following User Says Thank You to tomm.brz For This Useful Post: | B00STED86 (03-11-2024) |
#24 | |
it s more complicated than just that, but actually it is how it is to me |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | DarkPira7e (03-06-2024), RedReplicant (03-06-2024) |
#25 | |
That was my feeling as well, I just didn't want to be so harsh, hahaha
#26 | |
Drives:
Thanks for all of the great information. I ordered a cable and will download the software. Sent from my iPhone using Tapatalk |
#27 |
Drives:
Anyone have have or know where I can get a key for techstream v18? Cant find anything online.
I also need the MCI for TOYOTA TIS driver. Everything I found online had dead links or they were flagged by anti virus. A disk came with my mini vci cable I ordered, but of course I don’t have a CD Rom drive on my PC Any help would be greatly appreciated. I need to get this VIN programmed in so I can flash my tune! Sent from my iPhone using Tapatalk |
#28 |
Drives:
Problem has been solved. Thanks for the guidance.
Ordered a mini vci and got techstream to work on my tablet. Was able to write the VIN to the ECU and then flash the tune. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to B00STED86 For This Useful Post: | DarkPira7e (03-11-2024) |
| FS: Injector Dynamics 1050x injectors w/ wiring adapters | EddyEggnog | Engine, Exhaust, Bolt-Ons | 7 | 07-11-2024 08:44 PM |
| 1050x leak | IsaiahW | BRZ First-Gen (2012+) — General Topics | 3 | 04-09-2021 11:28 AM |
| LF: DW 770 or IC 1050X injectors | kev0 | Want-To-Buy Requests | 2 | 03-16-2021 01:56 PM |
| Car is stalling on start after Intake+header and a tune install. | WinterWolf | Engine, Exhaust, Transmission | 6 | 10-04-2019 09:44 AM |
| Sluggish/Stalling After aFe Intake Install | FR-S Matt | Engine, Exhaust, Transmission | 6 | 01-15-2013 09:57 PM |
