#43 |
Resurrection 👻👻👻 has anyone ran into problems with an install or long term use, any confirmation on ride height that may or may not require subframe notching with stock axles?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#44 |
Drives: 2015 frs
I didn't drive mine much after the install. I pulled the engine and transmission at 2700 miles and sold them. I don't see any wear on the axles or subframe I'm on stock axles.
#45 |
Ls swap? Or no swap yet?
#46 |
Drives: 2015 frs
LS swap acquiring parts should be done at the beginning of next year.
#47 | |
Potato Farmer
Drives: #SLOBRZ
Don't even notice the sound really.., kinda is drowned out by the exhaust. car is sitting pretty low, Dates love it when i pick them up hey! ![]()
Something something butter..
www.vic86brzclub.com |
#48 |
Because compromise ®
Drives: Red Herring
Hey Fudds,
What is that thingy?
#49 |
Potato Farmer
Drives: #SLOBRZ
I think it's this thingy
![]() Holds my bumper up, and didn't cost me $350! $15, couple of nutserts, stainless bolts and bam! I can now join the rest of the hardparker car racers kids with their quick releases!
| The Following 2 Users Say Thank You to fuddbutter For This Useful Post: | Captain Snooze (02-21-2017), Tristor (02-24-2018) |
#50 | |
Time Traveller
... lowered -1.8" rear ... snapped first axle at outer CV (driver's side) 20K mi ... raised rear to -1.6" ... snapped second axle at inner CV (also driver's side) 1 year later and also toasted my ring & pinion at the same time ($1400 fix btw). 33k mi ... raised rear to -1.25" lets' see where this goes. Lowering too much matters. If axle goes again, will get PBM diff kit. |
#51 | |
Edit: ohhhh phantom charger. I was wondering how you had so much torque without more HP. 👍
| The Following User Says Thank You to 15limited For This Useful Post: | DAEMANO (02-22-2017) |
#52 |
Hi, I got the risers from PSM
https://store.partsshopmax.com/shop/...s/ZNC6SDR.html Im debating between installing them myself or taking it to a professional, would you be able to estimate how long does it take to mount the risers? including taking the diff out and most important, did you need to notch the subframe, and how much drop you have? I will be lowering ~1.4 inch with KW v3, really hope theres no need to notch |
#53 | |
Drives: 2013 FRS
| The Following User Says Thank You to Falkon240 For This Useful Post: | J95 (09-03-2024) |
#54 | |
Drives: 2013 BRZ HKS Turbo
I attached a pic of my subframe trim.I don't recall exactly how long it took, but I'd say probably 6 hours from tires up to tires down. Here is a reel I put together of the install: https://www.instagram.com/reel/Cn0Yx...NlZDc0MzIxNw==
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
| Parts Shop MAX USA prototyping | philstar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-04-2014 01:14 PM |
| Need a Shop for Aftermarket Parts Installation in Portland - Suggestions? | Ammunition | Northwest | 11 | 12-23-2013 03:19 AM |
| RallySportDirect 2011 STi Shop Car for Sale. Over 50K in Parts, under 3500 Miles! | RallySport Direct | Cars for Sale/Trade | 14 | 06-21-2013 12:52 PM |
| Installing TRD Parts / Locating a good shop | Re~Mix | Engine, Exhaust, Transmission | 9 | 06-12-2012 01:05 PM |
