Drives: 2013 Scion FR-S (Base)
When installing Driver and Passenger Window Switch Panels with swapped White LED's from Automotive Custom Lighting , I came across an issue. The Driver Side Panel lights do not turn off at all. The lights remain on when the car is locked, when DRL Lights are off, and when the ignition is not turned on.
Yet the Passenger Panel works completely as expected, the lights turn off when the car is locked and when the car has the ignition turned off. I had checked all fuses, and they are all intact and functional. The only way I can get the Driver Panel lights to turn off is to remove the fuse that powers it. Please see attached photos. I had recorded a video explaining this issue as well: ( https://youtube.com/shorts/n8HHJJ59v...G1oLDOURz8kAAe ) |
#2 |
Drives: 2018 BRZ
If you put back the stock panel does it show the same behavior? If so, I suspect a pinched wire in the wiring harness shorting out something. If not, the problem is with the aftermarket panel/LEDs/swapping-work.
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | x808drifter (02-16-2024) |
#3 | |
Must be a sloppy soldering job done by the guys who swapped the LED’s. I will be shipping the broken panel back out to them to have their guys take a look. |
| The Following 2 Users Say Thank You to SAWYER For This Useful Post: | bcj (02-16-2024), x808drifter (02-16-2024) |
| Driver Side Window Switch issues | Drake_93 | Issues | Warranty | Recalls / TSB | 1 | 04-16-2023 09:37 PM |
| Push pin or screw? Driver side under panel (interior) | Packofcrows | Issues | Warranty | Recalls / TSB | 3 | 04-04-2018 06:57 PM |
| Driver side window/switch issue | MRCA1ST | Issues | Warranty | Recalls / TSB | 4 | 03-06-2018 02:11 PM |
| Driver side window/lock switch issue | xoBethxo | Electronics | Audio | NAV | Infotainment | 3 | 04-01-2016 01:09 AM |
| wtb:Window visors, shark fin, fog lights, switch backs, clear side markers | Vincenttam | Want-To-Buy Requests | 13 | 06-28-2014 05:02 PM |
