Old 01-20-2024, 10:02 AM   #1
JIM THEO
Drives: BRZ 2018
Don't mix Subaru Super coolant with Subaru Longlife coolant
This is what have been advised regarding the European versions of the above two coolants:
"Dear Sir
The main difference between the Subaru antifreeze from Switzerland Super Coolant Long life K067EYA004 (silver canister) and the original Subaru antifreeze from Germany K067EYA000 (black canister) is the technology and service life of the antifreeze.
Switzerland - technology is of classic carboxylate antifreeze, the additive acts specifically at the site of corrosion formation. Type SNF, additive G30. This type of antifreeze is suitable for Subarus from 1977 to present. Service life 5 years or 100,000 km.
Germany - phosphate lobride technology P-OAT. Used as a factory fill product since 2011, in >MY 2012 cars. Forms the thinnest film and sends the additive directly at the site of corrosion formation, like G30. Service life is 11 years at first filling, then 6 years or 120,000 km.
This one is suitable for your BRZ MY 2018.
Both types of antifreeze can be used in Subarus, but THEY CANNOT BE MIXED!
Important: mixing Silicate Nitrite Free and Nitrite Free (G48 hybrid technology) is prohibited, as well as with lobride (G40).
When changing the type of antifreeze, it is recommended to carry out the change with certified equipment at Subaru service!
Regardless of what antifreeze you use, it is useful to have a supply of the exact antifreeze that is poured into the cooling system when traveling.
Best Regards"
JIM THEO is offline   Reply With Quote
The Following 4 Users Say Thank You to JIM THEO For This Useful Post:
blsfrs (01-20-2024), gkubed (01-20-2024), Tokay444 (01-22-2024), Ultramaroon (02-02-2024)
Old 01-31-2024, 09:49 AM   #2
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
For us US folks, this just means don't mix the blue "super" coolant that comes in these cars stock with Subaru's older green coolant.
I prefer to keep the same coolant in the car it came with. Green with green, blue with blue. For twins, that means just using the blue super coolant always.
Keep it simple.
(Supposedly the blue super coolant is backwards comparable if you do a full flush. Always felt Subarus were weird with coolant and it was best to stick to the original.)
cmiovino is offline   Reply With Quote
The Following 4 Users Say Thank You to cmiovino For This Useful Post:
DocWalt (02-01-2024), EndlessAzure (02-02-2024), Ultramaroon (02-02-2024), YamahaR86 (04-29-2024)
Old 02-02-2024, 06:06 PM   #3
JIM THEO
Drives: BRZ 2018
Keep it simple.
The Super Coolant is the latest and newest coolant from Subaru that you can't mix with the Long Life Coolant which is for older cars.
The first one is blue the second is greenish blue, not much different.
The Following User Says Thank You to JIM THEO For This Useful Post:
Old 02-02-2024, 06:20 PM   #4
Just mix a little green in with the blue. Should get you there.
Old 02-02-2024, 06:30 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Instructions unclear. Mine is Blue Pink now
EndlessAzure is offline   Reply With Quote
Old 02-02-2024, 06:47 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
That's the GPS lube. Helps going around corners.
OEM Toyota Blue Super Long Life Coolant == Super Coolant Pre Mixed? bakingpancake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-15-2022 01:24 PM
Subaru Coolant at NAPA mhughett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 10-27-2017 04:42 PM
FS: Subaru Super Coolant Hanakuso Mechanical Maintenance and Tools 0 06-11-2016 04:35 PM
Toyota Coolent & Subaru Long Life Super Coolant Interchangeable? davithedork Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 01-05-2016 04:19 AM
