Old 01-21-2024, 11:49 AM   #29
Grady
Grady's Avatar
Originally Posted by JohnH View Post
remove intake piping and airbox.
remove drive belt
install SC bracket/SC itself
fit up piping from airbox to SC
Fit up piping from SC to throttle body.
Once again you are describing the Sprintex non intercooler supercharger, only you do not have to remove the airbox. I does not get any simpler that that setup.
The Following 2 Users Say Thank You to Grady For This Useful Post:
JohnH (01-22-2024), whataboutbob (01-21-2024)
Old 01-22-2024, 08:47 PM   #30
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Time to suck it up, Buttercup.
or not. its a case by case basis tho hehehe
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 01-22-2024, 08:47 PM   #31
JohnH
Professional wrench
Ok, Ill look more into that one
225/45VR17 RT660s
Old 01-22-2024, 09:42 PM   #32
JohnH
Professional wrench
Originally Posted by Apolllo View Post
Correct me if I am wrong, but all the Rotrex style Superchargers come with a intercooler IE: Jackson, Kraftwerks, HKS, Vortech will come with a intercooler.
Then you have Edelbrock that does not use a intercooler, just has a heat exchanger.
I looked up Sprintex and it shows a intercooler...might be another option without.
I know you said Supercharger, but what about a Turbo kit? Something like Works stage 1 kit might be what you are looking for. No intercooler, but you do have to install their downpipe.
https://store.worksmotorsports.com/W..._p/142.211.htm
this turbo kit is looking more and more like a winner. Maybe put a slightly weaker wastegate spring to turn the boost down to 5psi, and just put a pipe in place of the liquid intercooler to further simplify it. I don't need 260 to the wheels, honestly. 220 would be just ducky in this car, and the drop in torque would probably make other parts of the car last longer too.
Now I just need to find a Canadian supplier. Ive sent an email to Works
225/45VR17 RT660s
Old 01-23-2024, 07:17 PM   #33
Teseo
Drives: frs
Originally Posted by JSIdriver51 View Post
Based on what you want and what you talk about, the Sprintex non-intercooled kit would be the best for you. I thought installing the whole kit was pretty easy considering it’s just me (hardest part was lifting it by myself and lowering it in). Having the barebones kit would mean you essentially disconnect the belt (just a 14mm on the tensioner). Then unplug and take off the TB (leave everything attached hose-wise). Take off the hoses from the manifold and remove the manifold (6 bolts). Then route the extensions from the supercharger (map extension and tb extension) and then just drop in the supercharger manifold (head unit is already on) and bolt it up (there is an extra 32mm bolt that attaches at the front to secure the manifold). Reconnect TB and hoses. Then put belt back on. Super easy and not involved compared to other kits. If you have e85 readily available, it’ll help and you can get a flex kit (another 10-15 min install depending on which kit you get). Then get it tuned via Ecutek and you’re done. It’ll push roughly 9-10 on the stock 75mm pulley and it’ll be fine with proper maintenance; adding the e85 will just increase reliability and power
***forgot, the kit uses a plastic elbow that attaches to the intake. Super simple to take off and on (just four clamps)
Yeah, but the kit is rarely seen other than the intercooled version
FI options: Turbo or Supercharger Misha235 Forced Induction 44 06-05-2020 10:31 AM
DC Sports cat back review and new supercharger options for the 86 Photomikes garage FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 02-09-2017 07:17 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
