Old 01-17-2024, 09:41 PM   #19853
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Originally Posted by dpfarr View Post
Yea, the process for brembos is new to me. 30k miles and about 3mm of pad left. Very reasonable to be able to swap track pads in while switching wheels.
It's quicker, but not exactly like "swap at a pitstop" quick.
Depending on thickness differences between the two sets of pads, you do have to move the pistons back in and the fronts take a decent amount of force. You can do it with a pad and wiggle it back and forth, but it takes some effort... especially going from a thin pad to a full one.
Pins take some effort in the front too. Best to pull them out from the rear rather than tapping from the front as you can scratch the caliper this way.
The rears being much smaller are simple all around.
... so when you think about traditional sliding calipers, there isn't a ton of advantages actually. It's just about the same effort removing one bolt, swinging the caliper away, swapping pads and/or moving only two pistons vs four, and you're good.
I've had both. They're not hard by any means, but not like half the time or anything.
cmiovino is offline   Reply With Quote
The Following 2 Users Say Thank You to cmiovino For This Useful Post:
NoHaveMSG (01-18-2024), Ohio Enthusiast (01-17-2024)
Old 01-18-2024, 11:34 PM   #19854
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Need the right tools for the job. With a cheap or homemade pad spreading tool it takes minutes.
Ultramaroon (01-18-2024)
Old 01-18-2024, 11:48 PM   #19855
If it needs to be faster than a c-clamp, I need to examine my priorities.
blsfrs (01-20-2024), NoHaveMSG (01-20-2024)
Old 01-20-2024, 02:02 AM   #19856
dpfarr
Drives: BRZ ts
I had a Jetta that needed a tool that simultaneously spread and rotated the piston.
dpfarr is offline   Reply With Quote
The Following User Says Thank You to dpfarr For This Useful Post:
blsfrs (01-20-2024)
Old 01-20-2024, 10:57 AM   #19857
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I had a Passat with the same type calipers. I spent an hour trying to push and screw the piston in (the video said it would be easy) then got the loaner tool and finished each one in 3 minutes.
Old 01-20-2024, 06:44 PM   #19858
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My favorite tool for it is actually a clutch basket holder for a motorcycle.
Old 01-20-2024, 08:04 PM   #19859
OMG, yes.
I've been doing it wrong all these years.
Old 01-21-2024, 11:16 AM   #19860
blsfrs
blsfrs's Avatar
Can you post a picture of the one you use. I googled around and saw some tools but I can't get my brain to see how they would work on brake calipers.
Old 01-21-2024, 06:05 PM   #19861
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Like this. Tons of leverage, quick to adjust.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (03-15-2024), blsfrs (01-22-2024)
Old 03-14-2024, 11:25 PM   #19862
Kit Kat
Kit Kat's Avatar
Drives: 2017 Subaru BRZ w/ PP
Today, I installed my new head unit cover. The fitment was absolutely perfect
Name:  Head Unit Cover.jpg
Kit Kat is offline   Reply With Quote
The Following 4 Users Say Thank You to Kit Kat For This Useful Post:
bcj (03-15-2024), chas3wba0 (03-19-2024), JD001 (03-16-2024), Wally86 (04-29-2024)
Old 03-16-2024, 02:59 AM   #19863
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Got fresh fluids front to back
Oxyg3n is offline   Reply With Quote
The Following User Says Thank You to Oxyg3n For This Useful Post:
Old 03-16-2024, 07:18 AM   #19864
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Coolant, brake and clutch fluid?
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
Teseo (03-20-2024), Wally86 (04-29-2024)
Old 03-16-2024, 04:13 PM   #19865
Oxyg3n
Oxyg3n's Avatar
I probably should be thinking about those next tbh. Brake fluid and spark plugs are next up on my list. Might pay someone to do those though since I'm getting old ��
Old 03-16-2024, 09:13 PM   #19866
g e
New drive belt, brake fluid, transmission fluid, differential fluid, oil change, full alignment, pvc valve replacement and new Michelin PS/4 tires last week.
70k miles. Will replace spark plugs later this year.
g e is offline   Reply With Quote
