Old 01-17-2024, 01:22 PM   #15
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by WNDSRFR View Post
This is a perfect description of an electric supercharger. Like the Phantom or the Torqamp. I tried to find the website for Torqamp to refer you to and can't find it on the internet. I can't believe it disappeared just like the Phantom. both products work perfectly on this platform. Now I understand the irony of the name "Phantom".
I found a TorqAmp site. https://torqamp.com/product/torqamp-kit/
+on your suggestion. My main concern is if this company is going to be around long. A while back they were soliciting for investors.
Qwimby1 is offline   Reply With Quote
Old 01-17-2024, 01:59 PM   #16
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Not really easy as it looks on Roadkill.
Simple
Indeterminate
Blowed Up
Don't even need to pick one. It's a package deal!
Old 01-17-2024, 02:36 PM   #17
Qwimby1
Originally Posted by EvilPenguin04 View Post
Guy doesn't sound like he's interested in racing it or driving it hard constantly. As long as common sense is used and he has a good tune it will be fine. If it is a worry still then e85 can help keep it cool.
I ran E85 for a time and it helped, but in my area there's only one place to get it and it wasn't worth the effort.
The Following User Says Thank You to Qwimby1 For This Useful Post:
Teseo (01-20-2024)
Old 01-19-2024, 11:52 AM   #18
EvilPenguin04
Drives: 2015 BRZ 2004 SVT Cobra
I'm spoiled I have 4-5 stations within 15 minutes.
EvilPenguin04 is offline   Reply With Quote
Old 01-19-2024, 02:19 PM   #19
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Originally Posted by FR-S2GT86 View Post
I installed my Harrop without removing my front bumper, although it would have been easier had I had it on a lift for the air-to-water intercooler. If you can replace an intake manifold, you can install a Harrop.
Yep. Once again, I am infinitely capable of whatever install I need to do. I have 2 full sets of tools, access to a fully modern, nearly brand new shop. I am the shop foreman and have been wrenching professionally for nearly 30 years.
I simply don't want to do it.
Saying the other parts are hard to do is just silly. Look at how the electric ones work. People are saying they can install and remove them in less than an hour.
honestly there shouldn't be anything else involved for the basic install of a centrifugal blower put on the front of the engine.
remove intake piping and airbox.
remove drive belt
install SC bracket/SC itself
fit up piping from airbox to SC
Fit up piping from SC to throttle body.
there is tons of room at the front of the engine bay.
As for the turbo kits, I like turbos, and know how to tune with them very well, so it was my first thought. However, Id rather keep the exhaust setup I have. And I can't really see a convenient area to fit a remote mount turbo that wouldn't come with its own problems (heat, space, hanging down too low etc)
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 01-19-2024, 02:22 PM   #20
JohnH
Professional wrench
yea there is one in my province, and its 2 hrs one way and its not even open that often. eff that
225/45VR17 RT660s
Old 01-19-2024, 02:29 PM   #21
menikmati
Drives: 2015 BRZ, 2005 STI
Have you considered just paying someone else to do it for you?
menikmati is offline   Reply With Quote
Old 01-19-2024, 02:35 PM   #22
JohnH
Professional wrench
no. Not only am I more than capable, I don't really trust anyone else to work on my vehicles. Some warranty stuff, sure, but something like this? nope.
225/45VR17 RT660s
The Following 2 Users Say Thank You to JohnH For This Useful Post:
Teseo (01-20-2024), Ultramaroon (01-19-2024)
Old 01-19-2024, 02:54 PM   #23
Time to suck it up, Buttercup.
menikmati (01-19-2024)
Old 01-19-2024, 04:41 PM   #24
Qwimby1
I don't have the facilities or capability to install a belt-driven one, which is one reason I like the ESC. if I had to pay for and install it would add significantly to the cost I also have the option to remove it easily and put it on another car if I choose. My car is a 2014 and I'm not entirely trustful of the strength of that motor, which is why I wanted no more than 5 pounds boost. M Phantom has been working fine for a couple of years and makes a significant difference.
Old 01-19-2024, 06:29 PM   #25
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I wanted to see this thing for myself and it seems they might not be around anymore. No clue how up to date this info is so apologizes if it is no longer correct.
Looking for Phantom Superchargers, we were too. We found out they are no longer around but we have a lot of alternative options to make power reliably and easy to install on your vehicle. Check out our products below.
https://www.delicioustuning.com/scio...ubaru-brz.html
autoracer86 is offline   Reply With Quote
Old 01-20-2024, 10:27 AM   #26
Teseo
Drives: frs
Torque amp should take the lead on ESC but they doesn't do any marketing or make the product more ready, like doing kits + tune and other miscellaneous
Old 01-20-2024, 02:00 PM   #27
Qwimby1
You will occasionally see a Phantom show up in the classified section of this forum.
I haven't seen one for quite a while though.
Old 01-21-2024, 10:17 AM   #28
JSIdriver51
Drives: 2014 Subaru BRZ WRB
Hi. I'd like to get a simple, basic supercharger for my 2020 BRZ. I don't want to run bigger boost. 4-5 PSI would be plenty. I am not after a "max attack" kinda thing, just something to wake it up, not overpower it.
My problem is that I can't find anything that's not a complicated, expensive kit that takes a long time to install.
Honestly, I'd just want the supercharger, mounting bracket, and a 4-5psi pulley. Not sure if they would need a separate belt or use the stock one. I could get the couplers to the airbox and throttle.
I'm thinking a Rotrex C30-64 would be great. Good flow, and capable of enough for what I want.
I don't want to run an intercooler because at that low pressure its not needed, and the complexity of the install turns me off. Plus the added cost for minimal gain doesn't attract me. If I need to I will run methanol/water injection. From my experience in boosted engines, I won't need it, but I will probably run it down the road anyway for the other benefits it brings.
thoughts?
thanks!
Based on what you want and what you talk about, the Sprintex non-intercooled kit would be the best for you. I thought installing the whole kit was pretty easy considering it’s just me (hardest part was lifting it by myself and lowering it in). Having the barebones kit would mean you essentially disconnect the belt (just a 14mm on the tensioner). Then unplug and take off the TB (leave everything attached hose-wise). Take off the hoses from the manifold and remove the manifold (6 bolts). Then route the extensions from the supercharger (map extension and tb extension) and then just drop in the supercharger manifold (head unit is already on) and bolt it up (there is an extra 32mm bolt that attaches at the front to secure the manifold). Reconnect TB and hoses. Then put belt back on. Super easy and not involved compared to other kits. If you have e85 readily available, it’ll help and you can get a flex kit (another 10-15 min install depending on which kit you get). Then get it tuned via Ecutek and you’re done. It’ll push roughly 9-10 on the stock 75mm pulley and it’ll be fine with proper maintenance; adding the e85 will just increase reliability and power
***forgot, the kit uses a plastic elbow that attaches to the intake. Super simple to take off and on (just four clamps)
JSIdriver51 is offline   Reply With Quote
The Following 2 Users Say Thank You to JSIdriver51 For This Useful Post:
Grady (01-21-2024), Teseo (01-23-2024)
FI options: Turbo or Supercharger Misha235 Forced Induction 44 06-05-2020 10:31 AM
DC Sports cat back review and new supercharger options for the 86 Photomikes garage FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 02-09-2017 07:17 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
