Old 01-03-2024, 11:21 PM   #1
Limitz
Drives: Black Scion FR-S
Help, car turned off when coming to stop and will just crank
I’ll explain first, I have a 2013 Scion frs automatic. I was driving hard… I was at 135mph only problem I noticed was that I was on high rpm almost redlining and car wouldn’t throw another gear but I feel like that’s because there was no other gear to throw in. When I was getting off the freeway and coming to a stop the car just turned off on me. The car would not crank that night but the morning after it would crank but wouldn’t turn on. I haven’t had any issues with the car prior, no misfires, no codes, nothing, car has been perfectly fine till that night.
I decided to check my ignition coils thinking maybe one unplugged since I had that problem once but they looked fine to me. Now my problem is, like a rookie I decided to do that instead of checking the codes first, but I unplugged the ECU to check the coils and the battery to clean it and that cleared my codes can is there a way to get the codes back even when car doesn’t turn on??
And if anyone had something similar happen help pls
Limitz is offline   Reply With Quote
Old 01-05-2024, 01:05 AM   #2
That's for going 135 mph on a highway in the US.
Maybe your car got overheated and that is why it stopped.
Maybe it's out of gas?
I suggest you have it towed to a shop and have them fix it.
Wally86 (01-05-2024), x808drifter (01-05-2024)
Old 01-05-2024, 11:52 AM   #3
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
I did 150 mph with mine, and some extended runs (10-15 minutes) well over 120 mph, these cars don't really overheat at those speeds. There's enough airflow to keep the oil around 115°C (240-ish). My guess is this is something else.
Tow it to a good mechanic who knows these cars. Or at least a Subie shop.
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
humfrz (01-05-2024)
Old 01-05-2024, 01:50 PM   #4
YIKES! That must have been on a looong downhill run ..... with a "Georgia overdrive".
Old 01-06-2024, 04:13 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
This has led me to some asshole on the miata forums asking "Top speed for a stock FR-S?"
That was over 10 years ago.
XD
Old 01-06-2024, 07:07 AM   #6
alex87f
Meow
alex87f's Avatar
On flat ground! I was surprised as well. Cold-ish, dry air may have helped, as probably did the worn out (i.e. smaller diameter) tyres. For some reason the car felt in particularly good shape that day.
It was an express IKEA run before an expected lockdown
humfrz (01-06-2024)
Old 01-06-2024, 04:11 PM   #7
Well, now, THAT explains it -
alex87f (01-07-2024), x808drifter (01-07-2024)
Front brake squeal when coming to a stop with wheel turned johnnyeisu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-17-2023 08:45 PM
RPM drops when coming to a stop jamestemperante Issues | Warranty | Recalls / TSB 5 03-01-2022 01:50 AM
Oil light blinks for 1-2 seconds when coming to a stop/complete stop kev0 Engine, Exhaust, Transmission 27 07-10-2019 12:30 AM
car bogging when coming to stop Qball1754 Engine, Exhaust, Transmission 10 06-06-2019 12:39 PM
beeping when coming to a stop Skin Issues | Warranty | Recalls / TSB 8 07-24-2017 11:06 AM
