Old 12-24-2023, 02:33 AM   #1
Theodorable
Drives: 2015 Scion Frs
Slave master cylinder problem!
So I was installing my new/used slave assembly. when I installed it and topped off the reservoir. Started pumping. Clutch had no pressure and no resisting when pushing the clutch. The pedal would be locked to the floor so you’d have to pump with hand. Still pumped like 50 times no difference no pressure. So I was trying to diagnose. And I decided to do the slave cylinder hose to see if liquid was being pushed. There was not. Then I decided to do the master cylinder cause if there’s no fluid in the slave then how could it build pressure to push the clutch fork. So here’s a vid of the slave cylinder and master cylinder being pumped. Id assume when the hardline is disconnected from the master cylinder it was leak uncontrollably but I’m not sure cause this is the first time doing this. Lmk if this is normal or not and what I should do. I was planning on gettting a new master cylinder or even replace the whole assembly.https://youtube.com/shorts/Y38a0kKPK...bGMCZmC6jLRldp
https://youtube.com/shorts/XvGiw_KvF...FaWPAq3VmXtARS
No visible leaks when everything was installed assuming it’s something internal. Any help is appreciated thank you
Theodorable is offline   Reply With Quote
Old 12-24-2023, 02:42 AM   #2
You started with a dry master cylinder. Read up on bench bleeding master cylinders.
Old 12-24-2023, 02:58 AM   #3
Theodorable
Noted thank you! I’ll do some research on that tonight
Old 12-24-2023, 03:27 AM   #4
Mine drains slowly just by opening the bleed valve. Keep air from being sucked in on the release.
Old 12-24-2023, 09:00 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
So do I get my $5?
Or is the Slave Master not part of the "Manual Swap"?
The Following User Says Thank You to x808drifter For This Useful Post:
Ultramaroon (12-24-2023)
Old 12-24-2023, 09:00 AM   #6
x808drifter
LMGTFY
So do I get my $5?
Old 12-24-2023, 01:00 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Have you looked into the differences in the wiring and ECUs of manual and autos? If not, bleeding the clutch system may be the least of your worries. From my understanding, switching from auto to man not a "plug and play" deal.
Old 12-24-2023, 09:15 PM   #8
Theodorable
I have everything for swap including. MT harness etc. so don’t worry bout that. It’s just the cylinder I have a problem with
The Following User Says Thank You to Theodorable For This Useful Post:
blsfrs (12-25-2023)
Old 12-24-2023, 09:17 PM   #9
Theodorable
It also is plug and play because there’s no wires that connect to the clutch. It’s it’s own separate system that doesn’t require any wiring the harness
Old 12-24-2023, 09:18 PM   #10
Theodorable
Originally Posted by x808drifter View Post
So do I get my $5?
What are you on?
Old 12-24-2023, 09:21 PM   #11
Theodorable
I’ve also already installed everything to manual already. The only problem in my way from getting the car started and on the road is the clutch pedal/slave cylinder and or master cylinder
Old 12-25-2023, 12:12 AM   #12
Do us a favor. Notice that it's the same few people answering your questions. Please don't make another thread when you hit your next snag.
Bent Slave Cylinder Rod Beefybork Scion FR-S / Toyota 86 GT86 General Forum 10 04-08-2022 03:42 AM
Clutch Master Cylinder and Slave Cylinder Question oec88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 11-01-2021 04:38 AM
Slave cylinder Help vincelive123 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-09-2017 03:50 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 05:48 PM
Clutch Slave Cylinder KAR Southern California 4 08-08-2015 10:25 PM
