Drives: 2015 Scion Frs
NEED HELP WITH MANUAL SWAP ASAP!
Ok so I’m manual swapping my car. A couple questions, for the vacuum pump can I leave it there and cap the vacuum hole off instead of buying a cam plate?
Also trans fluid. I know a lot of people use motul 75w-90 300 gear oil but an off the shelf one like Valvoline SynPower 75W-90 Full Synthetic Gear Oil good as well? It’s rated for both GL4 and GL5 like the motul. Is this valid? Update: does anyone know the thread size for the abs brake line fittings? Last edited by Theodorable; 12-28-2023 at 08:37 PM. |
#2 |
Drives: Crapcan
I'd personally block off the cam plate. The factory one is just a cheap stamped piece.
Yeah, you can use an off the shelf stuff, can't be any worse than the factory fill. I actually don't like the Motul anyway and run Redline which is readily available most box stores.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (12-09-2023), Wally86 (12-13-2023) |
#3 |
While I'd also simplify, technically, there isn't anything wrong with just plugging the pump intake. Definitely don't leave it unplugged.
#4 |
Manual Swap ECU need help ASAP
I’m damn near done with my manual swap. The question I have is do I have to reset the ECU if I’m using the same wiring harness’ it came with? So when I plug everything back will it just turn on and start?
ECU/ECM came out the same car as the wiring harness 2013’ and the trans same year 2013’ but different car. Would I need to reset? And if so do I have to tune it? Or does the reset make it so the transmission and ECU are synced together. If not do I use my OFT and tune and if so what tune and link for said tune? Thank you! Last edited by Theodorable; 12-18-2023 at 05:45 AM. |
#5 |
LMGTFY
Drives: 13 FRS, 91 Miata
Why the fuck do you have 2 threads AGAIN?
Reported. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Wally86 (12-22-2023) |
#6 |
#7 |
Pavement Grey
#8 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
Forum etiquette & skills are learned over time through much trial and error.
| The Following User Says Thank You to HKz For This Useful Post: | norcalpb (12-20-2023) |
#9 |
Hopefully.
#10 | |
LMGTFY
Or is it more like I think it is. You have to be a moron to think that this kind of shit is ok? |
#11 |
I mean...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 5 Users Say Thank You to Dadhawk For This Useful Post: | bcj (12-20-2023), pope (12-20-2023), RedReplicant (01-01-2024), Ultramaroon (12-20-2023), Wally86 (12-22-2023) |
#12 | |
I look at thanks stats. People who don't thank, AND start concurrent threads, well... it tells a story.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Wally86 (12-22-2023), x808drifter (12-22-2023) |
#13 | |
Reformed
| The Following 2 Users Say Thank You to HKz For This Useful Post: | Ultramaroon (12-20-2023), x808drifter (12-22-2023) |
#14 |
LMGTFY
$5 says he makes another thread. That'll make it an even 4.
| The Following User Says Thank You to x808drifter For This Useful Post: | Ultramaroon (12-23-2023) |
| How to: Manual Swap FRS/BRZ | darthfrs | DIY (Do-It-Yourself) Guides | 15 | 12-06-2023 03:32 PM |
| Manual swap | IsaiahW | Engine, Exhaust, Transmission | 3 | 10-10-2021 02:36 AM |
| how to swap manual to auto | gt7877 | Engine, Exhaust, Transmission | 17 | 04-05-2020 05:56 PM |
| Is there any complications with doing a manual swap? | juniorrr | Engine, Exhaust, Transmission | 32 | 07-18-2019 09:06 PM |
| Change your manual transmission fluid ASAP!!! | Kostamojen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 383 | 12-12-2016 10:29 AM |
