Drives: 2013 brz limited
car in limp mode! cel light along with stablity control popped on
so i was just driving my car along the road as usual slightly aggressive and all of a sudden my check engine light popped on along with the stability control off light and now my car is stuck revving between 2-3k rpms and wont go any higher or lower i assume thats just limp mode... luckily i was near an auto shop so i pulled it in there and they scanned it, p2109 was the only code that came up, which they said was tps sensor related.
has this happened to anyone else before? is it common? and how do i get my car out of limp mode so i can drive it to the dealership? Last edited by zackegle; 02-24-2017 at 08:33 PM. |
#2 |
Time Traveller
Use just about any bluetooth app (Torque) to clear the code and see if it pops up again. OFTs can also do this.
#3 |
Huge E85 fan!
Drives: 2016 Scion FRS
I'd get it fixed ASAP. That's a safety problem. Sometimes just clearing a code and praying it's OK is fine, but sometimes it'll get you killed if you're pulling out into traffic and it comes back at that very moment. Google that code, there's something wrong
#4 |
Drives: FT86
If you clear the code the dealership or mechanic will have no record of it in ecu.
you can clear it by removing battery terminal and press brake pedal. reconnect battery this is not a common code. |
| The Following User Says Thank You to steve99 For This Useful Post: | guybo (02-25-2017) |
#5 |
Drives: White Subaru brz
Hey just checking did you ever get this fixed? My brz is experiencing the same thing
| OFT Code U0122.. Limp mode.. Help | cameronjones239 | Software Tuning | 16 | 05-19-2021 01:25 AM |
| P0455/P0456 - Will go into limp mode | Kojiro | Issues | Warranty | Recalls / TSB | 23 | 02-22-2018 11:58 AM |
| How to limp mode.. | vichiball | Software Tuning | 5 | 07-12-2016 02:18 PM |
| Limp mode AFTER clearing CEL | white_knight | Issues | Warranty | Recalls / TSB | 8 | 03-30-2016 09:40 PM |
| Car in Limp mode... No CEL | Sportsguy83 | Issues | Warranty | Recalls / TSB | 60 | 08-20-2014 04:35 AM |
