Old 04-03-2023, 06:35 PM   #1065
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Is there any literature I can read that explains how one would use tactrix to edit a current tune when adding a 2.5 bar map sensor?
Sur is offline   Reply With Quote
Old 04-10-2023, 12:30 PM   #1066
legendz6
Help with logging issues
Has anyone tactrix SD card logging stopped mid drive and start flashing red-red-red-red-blue pattern? SD card will show the log stops and no new logs are generated until next power cycle of the car. I have video here showing the blinking pattern when it fails. I've tried bending the pins, female to male obds and still have this issue. I am also using the a01g logcfg posted in this thread
https://photos.app.goo.gl/EQoVzLpZMJUfBuHw5
legendz6 is offline   Reply With Quote
Old 04-10-2023, 12:38 PM   #1067
callisto
Drives: 2019 Subaru BRZ
One forum post seems to indicate that red/blue could mean I/O error, and this particular user resolved it by reseating the microSD card. You might try backing up your log config and then trying to reseat it, or format it with a non-quick format, or copy a 4GB file to your 4GB card on your laptop and see if it crashes partway through, or try another microSD card.
http://forums.openecu.org/viewtopic....ed+blue#p24434
The original standalone logging post says that the lack of green means it isn’t sending OBD signals, so it _could_ be a physical connection - except that stopping and starting the car fixes it, which doesn’t usually solve a physical issue.
http://forums.openecu.org/viewtopic....ed+blue#p21900
callisto is offline   Reply With Quote
Old 04-13-2023, 01:48 AM   #1068
legendz6
Solved with a new SD card. Seems like my tactrix requires a high quality SD card. My cheapo amazon silicone power 64 GB cards and some random card that came with my 3d printer didn't work. Using a Sandisk extreme 128gb now formatted to fat32 and its all good. Thanks
The Following User Says Thank You to legendz6 For This Useful Post:
callisto (04-13-2023)
Old 07-01-2023, 05:15 AM   #1069
pro_turbo
Drives:
help
trying to flash and open the Openflash map v4 into my car and this happen
please advice
pro_turbo is offline   Reply With Quote
Old 07-01-2023, 08:07 AM   #1070
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
please advice
Instead of flashing theZA1JA01J version flash the ZA1JA01G version it's compatable and ecuflash has flash definition supplied for A01G roms
AussieBRZ is offline   Reply With Quote
Old 07-04-2023, 02:39 AM   #1071
pro_turbo
Drives:
thanks
will do
any help on good avcs map ?
Old 09-12-2023, 03:35 AM   #1072
Davidss
Drives: 2015 FRS
Hey I am having some trouble figuring out what base and definition file to use to flash an OFT tune. I have a ZA1JD00C ecu, I can read the ecu just fine and see the tune in ecu flash, the tables all look fine. However loading the OFT tune in ECU flash all of the tables are garbage data. I have tried updating to the latest base file and definition from the github (links below) which doesn't work I can't even see the tables at all anymore not even with the stock tune.
https://github.com/TD-D/SubaruDefs/b.../32BITBASE.xml
https://github.com/TD-D/SubaruDefs/b...Z/ZA1JD00C.xml
Davidss is offline   Reply With Quote
Old 09-12-2023, 03:54 AM   #1073
tomm.brz
Drives: brz 2017 hksv2
use romraider to modify the tune
Old 09-12-2023, 05:13 AM   #1074
boundaras
Drives: BRZ Blue MY17
think about Logging wideband with Tactrix.
I wired wideband signal to OBD pin 12,and What scripts should I write in logcfg.txt.
thanks!
boundaras is offline   Reply With Quote
Old 09-18-2023, 05:56 AM   #1075
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
That's because oft tunes use substitute base rom files an oft ZA1JD00C tune is actually based on a ZA1JA01G European rom then hacked to look like a D00C
So if your car was D00C just download the A01G oft tune it's unhacked and flash that with tactrix ecuflash has A01G definition by default it will just flash straight in its compatable with D00C
Old 09-18-2023, 05:59 AM   #1076
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
thanks!
The stock front 02 sensor is actually a good wideband you just need to rescale it in tune then you can use stock sensor as a wideband.
No need for an aftermarket wideband or wiring or coding and the ECU and tune gets a true wideband data to reference
Just open tune n romraider and paste in the 02 sensor scaling here for and 2012-2021 car
https://www.ft86club.com/forums/show...8&postcount=16
Old 09-18-2023, 08:11 AM   #1077
boundaras
Got it,thanks for the suggestion!
Old 10-21-2023, 11:53 PM   #1078
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Does anyone have a stock rom for a 2020 Euro BRZ?
Github only has 2017:
https://github.com/TD-D/SubaruDefs/t...20standard/BRZ
And the first post has only 2018 attached.
Arthur-A is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
