08-29-2023, 02:54 PM | #1009 |
1st86 Driver!
Don't know if you mentioned this to her, but make sure you instruct her "if it starts to stall push the clutch in not let out". Once folks get that it takes very little time to master.. I tought my wife and 3 sons each how to drive stick around a parking lot without stalling in less than 20 minutes (on different occasions).
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
08-29-2023, 03:42 PM | #1010 | |
Dismember
Drives: 2013 Red Scion FR-S
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | Dadhawk (08-30-2023), soundman98 (08-29-2023) |
08-29-2023, 04:43 PM | #1011 |
extra what?
After demonstrating to my grandkids that stalling was nothing to fear, I had them master starting out with only the clutch and letting the engine maintain itself. Once they could feather the clutch, I cut them loose with the gas pedal. Worked like a charm for them.
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post: | Dadhawk (08-30-2023), EAGLE5 (08-30-2023), Liquidsnake (08-30-2023), soundman98 (08-29-2023), Spektyr (08-29-2023), villainous_frx (09-04-2023) |
08-30-2023, 10:00 AM | #1012 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
I think the main component to teaching stick is actually having them get used to three components of the stick as a separate entity in order to understand h ow they work/feel:
-How the clutch feels (since the grab point and pedal travel is actually different in every car) -How to control the throttle (maintain steady RPM, mostly at low RPM) -Shifter action (the one thing i ended up realizing about the shifter is that you dont need to forcefuly or apply heavy pressure to "shove" the shifter into each gate.) You can teach them coordination all you want but if they have no idea how much throttle pressure they need to apply or what they actually need to feel for the clutch, theres going to be a lot of trial and error based stalling until they somehow find out how everything works together. I taught my nephew with my old Scion iM and he got used to it pretty quick. Maybe about 3 stalls before he was able to get the car moving from a stop fairly consistently without stalling, or jerking. But nerves got to him (makes you lose focus) so he'd have to kind of shake it off before trying again (that fear of stalling, or the thought of doing something wrong could damage the car...you know that type of feeling) Oh and even as the owner of the car, deep down you are clenching with every stall by another driver, but you know its something that happens and something that isn't to be feared. I've seen enough videos on youtube where someone is teaching stick and they don't go over these 3 main points so the student is bobbing, stalling and jerking all over the place. And the "teacher" is just continuously barking the "you have to coordinate the clutch and throttle" at them. |
The Following User Says Thank You to Sasquachulator For This Useful Post: | soundman98 (09-03-2023) |
08-30-2023, 10:20 AM | #1013 |
Drives: '23 BRZ Limited
Only $170k? Sorry, that's just kind of a funny statement. That's like top 8% of income earners.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | soundman98 (09-03-2023) |
08-30-2023, 12:00 PM | #1014 | |
Drives: GR86
As you say, they're incredibly self-conscious about stalling and lurching - all the things that make in unpleasant to be in the car with them. It's SO much easier to practice when you're not as acutely-aware that every mistake you made is immediately apparent to your passenger/instructor. Big mall parking lots are perfect. Particularly these days as most malls are failing and are usually half-full or less. You have wide-open spaces where obstacles won't appear unexpectedly, but there's also no expectation of moving at any real speed (20mph, maybe 30 tops). All you really need to do is master starting from a stop, shifting into second, slowing down for turns, and stopping without killing the motor. Then a little bit of using reverse. After that, you can turn the driver loose on city streets (low traffic, ideally) and the rest takes care of itself. |
The Following User Says Thank You to Spektyr For This Useful Post: | soundman98 (09-03-2023) |
08-30-2023, 12:44 PM | #1015 |
has a funny hat
Drives: 2014 BRZ Limited
“I” have only owned one automatic transmission so far (my first car), so when my wife and i first started dating (long after that car was gone) I taught her do drive manual by starting with the “In Case Of Emergencies and I’m Incapacitated” procedure: rev to 2500 and release the clutch on a three count.
Actually, it started with her shifting the trans while I drove, which familiarized her with the shift procedure and was something she just liked doing. It was years later before she would be willing to learn proper start technique, as long as she could get a car moving in an emergency, she refused (more or less still does) to have anything to do with being in the driver’s seat unless there’s an automatic transmission. |
The Following User Says Thank You to pope For This Useful Post: | soundman98 (09-03-2023) |
08-30-2023, 01:20 PM | #1016 | |
Drives: 2020 86
I guess if you don't mind a 100 mile commute or can somehow live in deep Appalachia and still pull down that kind of salary you could maybe pull it off. But within an hour of most places with any real economic opportunity it isn't much money any at all these days. Median home price in Denver is about 585k. Let's assume a best case scenario of 117k (20%) down payment, 7.4% interest rate, 1% property tax, and 2k/yr homeowner's insurance, the monthly note is $3,894.50 170k salary after tax in Denver is about 110k annually or $9160/month. That's not accounting for any retirement savings, health insurance, family care, transportation, or any other common expenses. Assuming you ONLY have to pay your mortgage and somehow have $117,000 already lying about for a down payment, your DTI is 42%. That's considered pretty bad out of the gate. I guess if you don't eat food, walk to work and don't mind sitting in your dark house without electricity or running water you might be able to put some money away. *edit* I should also point out that the 170k number is total compensation, including RSU and assuming 100% bonus payout. Waiting for your rsu shares to vest or a slow year where bonus payments are curtailed due to lack of performance by the company at large can result in a not insignificant variance in compensation. Last edited by WildCard600; 08-30-2023 at 01:44 PM. |
08-30-2023, 01:54 PM | #1017 | |
People are moving here because it's so much cheaper. The appreciation of my house is crazy. It just sucks our politics are so insane.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | Dadhawk (08-30-2023), soundman98 (09-03-2023) |
08-30-2023, 01:55 PM | #1018 |
Drives: FR-S,GTI
Or
You could live in a place with a much lower cost of living. Somewhere maybe like Oklahoma? |
08-30-2023, 01:56 PM | #1019 |
Drives: FR-S,GTI
Crap
Beat me to it. |
08-30-2023, 01:58 PM | #1020 |
I know that's a shot at me, we don't like the politics here. But we also don't want a massive mortgage. We make way above the average, but we like having extra to do what we want.
08-30-2023, 03:00 PM | #1021 | |
Drives: 2020 86
Careers and stability are overrated anyway, let's chase materialism. |
The Following User Says Thank You to WildCard600 For This Useful Post: | soundman98 (09-03-2023) |
08-30-2023, 03:08 PM | #1022 | |
Drives: 2020 86
That's how it starts. Good luck. |
Similar Threads | ||||
Another good reason to drive an AT | Hotrodheart | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-13-2016 01:00 AM |
A Good Reason to Stay With Narrow 17s | FlamingRectumSyndrome | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 04-30-2014 04:18 PM |
FA20CLUB: GOOD REASON TO REMOVE YOUR TURBO KIT RIGHT AWAY.... | FA20Club.com | Forced Induction | 27 | 06-21-2013 11:19 PM |
Car Name; Reason why FT-86 won't stick | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 07-17-2011 12:52 PM |
