Old 08-27-2023, 02:26 PM   #15
components
inspection
Link to manuals in my sig line. It's VERY unlikely to have two concurrent failure points. Cascade failures are common where dependencies exist. I don't think that's the case here.
Old 08-27-2023, 03:30 PM   #16
Jonb1760
Drives: 2104 Subaru. BRZ
Thanx everyone. Enough info for me to go on, I think. Will update after I have a go.
Jonb1760 is offline   Reply With Quote
The Following User Says Thank You to Jonb1760 For This Useful Post:
Ultramaroon (08-27-2023)
Old 08-27-2023, 05:37 PM   #17
You could also run the tank low and run it on a straight highway again to see if you can reproduce the failure. When it starves, try sloshing what we suspect is stuck on the dead side of the tank. If the engine fires, illuminati confirmed.
obligatory: take a few liters of fuel in case we're wrong.
Old 08-28-2023, 04:57 PM   #18
Jonb1760
Seriously considered it. 😏
Old 09-02-2023, 02:34 PM   #19
dpfarr
Drives: BRZ ts
Originally Posted by Ohio Enthusiast View Post
My thoughts as well. Based on refueling amounts it sounds like you ran the left side dry but the right side had some left (probably the missing 10 liters). Does anyone know how much fuel is enough to allow fuel to mix between the sides without pumping?
In situations were the process of getting e85 is complicated and I’m at like 0.5 gallon remaining, I’ll sometimes get 1-2 gallons of 91 to get me to the next station. Gauge never moves but the ethanol readings show that I’m running on 91.
dpfarr is offline   Reply With Quote
Old 01-31-2024, 12:22 AM   #20
Jonb1760
So… update. Nothing. Mechanic had it for ages, tried everything he could think of bar replacing pump assembly. I’m just now driving very carefully under half a tank and carrying some fuel in the boot. Shit I know but don’t know what else I can do. I live in a remote area with very little help around. No real faith n dealer.
blsfrs (01-31-2024)
Old 01-31-2024, 09:36 AM   #21
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
This is likely a very simple problem to repair, and has been mentioned previously, the low light never comes on because the right side saddle still has fuel in it. Your problem will be in one of a few places;
  1. Faulty, or clogged fuel tank return tube/sub pump (There is a filter on the end of this tube that can get clogged)
  2. The fuel hose between the return tube and the pump assembly (clogged, disconnected?)
  3. Issue in the main pump (loose connection, failed part)
I would start with replacing the sub pump & filter, then while in there be sure the fuel hose isn't clogged or disconnected.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
Ultramaroon (01-31-2024), x808drifter (01-31-2024)
Old 01-31-2024, 12:59 PM   #22
Did you ever take it back out on the highway and do the slosh test I described? You're already carrying spare fuel.
Intermittent fuel pressure/signal drop (Fuel regulator prob?) Decimus Issues | Warranty | Recalls / TSB 6 03-27-2019 07:38 PM
How to fix fuel starvation on left hand turns - Verus Fuel Door FT-86 SpeedFactory Engine, Exhaust, Transmission 3 08-21-2017 03:22 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
