Old 11-03-2022, 07:12 AM   #71
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Engine/Trans/Diff oil temps are different aren't they?
The Following User Says Thank You to x808drifter For This Useful Post:
DocWalt (11-03-2022)
Old 11-03-2022, 09:06 AM   #72
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by OkieSnuffBox View Post
I trust the data provided from 949 and FM. FM has data showing both the transmission and differential will hit north of 300 on track. They also developed a stud kit for the trans case to help with strength.
They never did any of those things for the 3 previous generations.
The transmission is garbage, that is known, the trans cooler was an attempt to make it last longer but it makes no difference since the issue is case/shaft flex that leads to bad gear mesh that strips the teeth off. The diff gets hot but so does the twin diff. Regular fluid changes are needed in any track car without additional coolers, NA & NB included as much as people like to ignore it. That said, as mentioned by someone else, the ND has a LOT more power than any of the prior Miatas, of course it needs better cooling.
Stud kit was developed by Mazda Motorsports, for the record. They switched to the SADEV on the Cup cars for a reason... the stock trans doesn't hold up.
I owned an ND for quite a while. I'm familiar with all of the weaknesses and not weaknesses.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
Blighty (11-03-2022), Petah78 (11-03-2022), x808drifter (11-04-2022)
Old 11-03-2022, 10:10 AM   #73
Petah78
Drives: 2022 BRZ sport-tech
Thank you for this. Aside from the trans, is the ND miata (1 or 2) in general reliable from a track use perspective?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 11-03-2022, 12:34 PM   #74
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Extremely.
I personally *hated* the Brembos, totally worthless upgrade. The Recaros were great at least.
The Following User Says Thank You to DocWalt For This Useful Post:
Old 11-03-2022, 08:17 PM   #75
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
lol. nice.
Blighty is offline   Reply With Quote
Old 08-20-2023, 10:46 AM   #76
ruturaj001
Drives: BRZ 2023
Originally Posted by ZDan View Post
Ima say, probably not. Last-gen didn't need them either IMO. At the very least run an event and see what the oil temps first. Personally, for my track usage (~4x 15-minute sessions per track day), at 272F, I'm fine running 5w30 oil with 3.5+ HTHS.
Which 5W30 are you running? I was running mobil1 extended performance and recently realized that HTHS is 3 for it. I am either switching to euro formula mobil1 or euro formula Pennzoil, at 3.5 and 3.6 respectively. Also considering 0w40 oils. Max I saw was 250F approximately (BRZ gauge).
@Everyone else Sorry to dig up old thread. I think I am at point where I need either thicker oil or oil cooler but not necessarily both(?).
ruturaj001 is offline   Reply With Quote
Old 08-20-2023, 11:42 AM   #77
ZDan
ZDan's Avatar
Drives: '23 BRZ
I ran Redline 5w30 last year in the '17. This year the '23 has Subaru 5w30 which is probably closer to 3 HTHS... Will likely go with Redline for next oil change, but may stick with Subaru 5w30 if they do the next service.
Old 08-20-2023, 04:11 PM   #78
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Out of curiosity, how did it perform for you? From my personal experience, Redline High Performance is one of the most robust oils you can get.
Arthur-A is offline   Reply With Quote
Old 08-20-2023, 06:58 PM   #79
ZDan
ZDan's Avatar
Drives: '23 BRZ
Fine, really no differences I could detect, but I like having the higher HTHS Redline 5w30 in there for tracking at high oil temps. Currently have Subaru 5w30 because Subie dealership changed the oil when they inspected and cleared the oil pan and pickup tube of RTV.
Old 08-21-2023, 03:22 AM   #80
ruturaj001
Drives: BRZ 2023
RTV cleanup under warranty?
Old 08-21-2023, 05:14 AM   #81
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
I've had my done on warranty but oh boy what a ride It was to get it done under warranty in EU where those cars are not available for a long time and there is just a handful of them. Long story short I've found RTV sticked to dipstick at around 100km of milage. Reported to dealership and the answear I got from service manager was "we're not touching the oil pan until there are symptoms of engine not working properly". Contacted Toyota Poland, than their master technican for our country and told him about RTV situation all around the world, after nice and reasonable talk with the guy (complete opposite of unhelpfull dealership service manager) I got it done under warranty.
MrSkubi is offline   Reply With Quote
Old 08-21-2023, 07:31 AM   #82
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yup. They quoted $397 to inspect, and when they found some agreed to warranty it, no prob.
Old 08-21-2023, 12:38 PM   #83
OkieSnuffBox
Drives: '23 BRZ Limited
I haven't done it, but my dealer said if they find it would be under warranty, and if they don't find any it would be about $650.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 08-21-2023, 04:14 PM   #84
ruturaj001
Drives: BRZ 2023
Man that's expensive. I guess, getting short block and replacing engine would be 5-6k? Paying 6-10% is ridiculous compared to chance which seems much lower than that.
FS: NJ/NYC OEM (Forester) oil cooler/oil cooler connector Joon525 Engine, Exhaust, Bolt-Ons 3 09-20-2019 05:00 PM
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 10:50 PM
AT Trans Cooler: Performance cooler vs Standard Faulkner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-30-2018 11:34 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
