Old 01-21-2023, 08:28 PM   #57
RedReplicant
Drives: None
Originally Posted by timurrrr View Post
Definitely same OD, as the seals are identical.
I believe the pistons are indeed the same exact part.
Beautiful. I bought reman'd 2017 STI rear calipers, I think they are the exact same thing as a PP rear but I will measure when they get here.
Certainly a lot cheaper way to get PP rear brakes.
RedReplicant is offline   Reply With Quote
Old 01-22-2023, 05:58 PM   #58
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I should note that PowerStop has four other brake pad lines available for the PP Brembos in addition to the Z23's and Z26's already listed. Here's all their pad lines in order of (supposed) performance / aggressiveness from OEM replacement to "Stage 2 Track Day", with links to their product pages:
PowerStop also has one line of rotors:
In addition to the Centric rotors already listed on the first post, they also have:
  • Cryo-treated high-carbon front rotors - 125.47019CRY front
  • Stoptech slotted rotors - 126.47019SL front left / 126.47019SR front right / 126.47043SL rear left / 126.47043SR rear right
  • Stoptech slotted cryo-treated rotors - 126.47019CSL front left / 126.47019CSR front right / 126.47043CSL rear left / 126.47043CSR rear right
  • Stoptech drilled and slotted rotors - 127.47109L front left / 127.47019R front right / 127.47043L rear left / 127.47043R rear right
  • Stoptech drilled and slotted and cryo-treated rotors - 127.47109CL front left / 127.47109CR front right / 127.47043CL rear left / 127.47043CR rear right
  • Stoptech drilled rotors - 128.47019L front left / 128.47019R front right / 128.47043L rear left / 128.47043R rear right
  • Stoptech Select drilled and slotted rotors - 227.47019L front left / 227.47019R front right
Information on all the Centric brake components available for our cars (including non-PP stuff) can be found here.
I have a set of the Z23 pads I'm going to swap on for the street to replace the dusty stockers along with some new Centric blank rotors, and I picked up a set of the Track Day pads (front and rear) for my upcoming HPDE track weekend.
Last edited by Tatsu333; 11-23-2023 at 06:51 PM. Reason: 2023.11.23 - Updated Centric /Stoptech rotors info with current part numbers
Tatsu333 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post:
dpfarr (11-23-2023), SuperTom (08-15-2025)
Old 01-29-2023, 07:21 PM   #59
RedReplicant
Drives: None
Are the rattle clips required?
Are the front tie bars actually required? I noticed the STI doesn't run them and instead uses a shorter front bolt caliper bolt, I somehow hadn't realized that they weren't a bracket or a spacer until I was putting the front together.
FWIW, STI rear calipers are a substitute for the PP rear caliper. You can get them significantly cheaper.
Old 01-30-2023, 12:27 AM   #60
Tatsu333
FWIW, I think some folks have fitted the PP Brembo brakes on the 2nd gen aluminum knuckles without them using the STI bolts because they don't fit with them. I think the feedback was just that they were noisy without them...?
RedReplicant (01-30-2023), timurrrr (02-01-2023)
Old 01-30-2023, 11:22 AM   #61
RedReplicant
Drives: None
Alright, that kind confirms what I was thinking. Easy way to save a few pounds of unsprung weight. Thank you!
Old 02-01-2023, 12:57 PM   #62
Tatsu333
Maybe even a little more if you swap in some 2nd gen aluminum knuckles...but that ain't cheap.
The Following User Says Thank You to Tatsu333 For This Useful Post:
RedReplicant (02-01-2023)
Old 02-01-2023, 02:17 PM   #63
RedReplicant
Drives: None
Would if I could, series rules and all. I pulled off a Stoptech 355mm / 345mm kit for the PP.
BRZ PP brakes? No points
2nd gen knuckle? Illegal because they didn't come on first gen
The Following User Says Thank You to RedReplicant For This Useful Post:
Tatsu333 (02-02-2023)
Old 04-27-2023, 10:30 AM   #64
imprezive
Drives: 2017 BRZ - WRB - PP
FYI - I just received confirmation from Centric that the performance high-carbon "replacement" rotors for the PP packaged have been discontinued. I ordered them like 6 months and they were still listed on their website/distributor sites as available, but out of stock. Turns out they were actually discontinued.
Part numbers 125.47019 & 125.47043
They do have the C-Tek "standard" rotors available still. Part numbers 121.47019 & 121.47043.
imprezive is offline   Reply With Quote
The Following 3 Users Say Thank You to imprezive For This Useful Post:
NaturallyAspirated (04-27-2023), RedReplicant (04-27-2023), Tatsu333 (04-27-2023)
Old 08-15-2023, 10:25 AM   #65
Wilhelm_Hertzog
Drives: 2018 GT86
Originally Posted by pkennethv View Post
Chiming in here to say I've recently had the following installed on my 2018 BRZ w/ Brembo:
EBC BSD1056 (front rotors)
EBC DP51210NDX (front pads)
EBC DP51537NDX (rear pads)
EBC does not currently make any rear rotors that will fit the car (verified by EBC themselves). I tried the BSD1057, and although the diameter, thickness, bolt pattern are correct, the "height" of the hat is such that the inside face of the rotor interferes with parts with the dust shield.
What has your experience been with this setup? I went the same route (BSD rotors up front, kept stock rotors at the rear) but with Yellowstuff pads. After nine months, less than 3,000 miles and three or four track days, the front pads are basically worn down to the point of having to be replaced. Rear pads still have plenty of life left. My OEM setup up front lasted MUCH longer.
I'm wondering if the mismatch in rotors cause brake bias to shift forward which wears the front pads down faster.
Sent from my LM-G900 using Tapatalk
Wilhelm_Hertzog is offline   Reply With Quote
Old 11-11-2023, 05:22 AM   #66
Wilhelm_Hertzog
Drives: 2018 GT86
Originally Posted by Wilhelm_Hertzog View Post
I bought BSD rotors (1056 for the front and 1057 for the back) for my 2018 GT86 (with Brembo brakes) recently, and can unfortunately confirm that the rears rub against the dust cover when installed. Pretty disappointing.
Seems that the BSD 7839 rotors are the right ones. Same dimensions as 1057, but 4mm lower height (64mm vs 68mm), which is the same as the stock Brembos.
Now: BSD 7839 rotors seem very hard to find. Can anyone perhaps point me to a source?
Old 11-21-2023, 09:35 PM   #67
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
What is the recommended slotted rotors for the PP Brembos?
Sent from my SM-S916U using Tapatalk
kraftyone is offline   Reply With Quote
Old 11-23-2023, 12:38 PM   #68
Tatsu333
Stoptech has the 126.47019SL/SR (left / right front) and 126.47043SL/SR (left / right rear) which I've used in the past on another vehicle, but I found they tended to accumulate pad material in the slots which had to be cleaned out regularly or it would negatively affect pedal feel, noise and braking performance. I had heard they were getting hard to find, but both CSG and Summit Racing list them as in-stock currently. EDIT: I updated my previous post (several above this one) with the current part numbers from Stoptech / Centric's website. They added a number of rear applications since I created the original post, and another variant - "Stoptech Select" drilled and slotted rotors.
I'm currently running the PowerStop Evolution drilled and slotted rotors in the rear only. No issues so far. They don't seem to have the same build-up issue as the Stoptechs, and they were about half the price. They're also sold in axle sets, rather than individually, which makes ordering a little simpler. I bought them from Rock Auto, and will likely end up getting them for the front as well. Part #'s are JBR1179XPR for the front set and JBR1795XPR for the rear set.
Last edited by Tatsu333; 11-23-2023 at 06:54 PM. Reason: Added PowerStop part #'s and note about Centric / Stoptech part numbers
kraftyone (11-26-2023)
Old 12-28-2023, 07:10 PM   #69
nick.cfrancis
Drives: 2017 Subaru BRZ Limited Performance
I emailed Centric and they said that both the front and rear high carbon rotors are still available and in stock.
Front: 125.47019
Rear: 125.47043
nick.cfrancis is offline   Reply With Quote
STi Brembos Do Boy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 315 05-01-2016 07:04 PM
STI Brembos. xkalelx Brakes, Suspension, Chassis 24 08-31-2015 01:28 PM
Brembos biggy69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-15-2014 10:23 PM
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 03:25 PM
F/S NY 06 STI BREMBOS subyboy NY / NJ / CT / PA 17 08-21-2013 08:28 PM
