Old 06-30-2023, 12:21 PM   #1
andyk5
Drives: GR86
Help me read my tire wear
4th track day (2 SOW 2 BW CW13) on 225/45/17 Cup2s drivers side front rotated after every track day. Car is stock except top hats, camber bolts and alignment. I don't remember what the camber on the front is but I think it is under 2 degrees.
Usually all my 200-240tw tires wear this way. First I wear out the center strip, than the outside half of the tire with the inside basically brand new.
So what are the issues here?
1) Not enough camber? If so can I get more by adding a second set of camber bolts (upper hole, opposite side) or gotta have coil overs now?
2) Am I losing the center strip first due to over inflation?
3) I drive pretty aggressively, maybe I am causing too much understeer due to steering angle?
andyk5 is offline   Reply With Quote
Old 06-30-2023, 12:36 PM   #2
Racecomp Engineering
1. yes more camber needed.
2. possibly. what pressures are you running?
3. hard to say from here! are you fighting understeer a lot?
also are you on stock wheels?
a tire pyrometer might help you a lot.
- Andrew
andyk5 (06-30-2023)
Old 06-30-2023, 12:56 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
I'm on RCE Yellow springs, camber bolts in both top and bottom and Pedder's offset top hats and have -3 camber and could gain a little bit more (between -3.2 and -3.4, I dialed it back a little for the street).
What's your tire pressure? Sounds like you're running too high pressure?
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
andyk5 (06-30-2023), strat61caster (06-30-2023)
Old 06-30-2023, 01:03 PM   #4
andyk5
Drives: GR86
- Andrew
Pressures vary from 28-30 cold, to 33-37 hot.
I don't fight understeer a lot, I actually fight oversteer most of the corner. I guess corner entry I div in pretty hard and the car pushes but mid corner and corner exit is always a battle against oversteer.
I am on stock wheels. Tire pyrometer seems like too much over head. I need to do hot laps then come to hot pits get out, check tire temps and record right?
Old 06-30-2023, 01:18 PM   #5
Code Monkey
Drives: Subaru BRZ
There's your problem.
Code Monkey is offline   Reply With Quote
Old 06-30-2023, 01:19 PM   #6
It's not conceptually difficult to use, but it can be a pain to do by yourself.
Either way, yes I think more camber would help. How do your rear tires look? More front roll resistance could also help.
- Andrew
Old 06-30-2023, 01:25 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Looks over driven with too much steering input more than anything else. I bet decreasing pressures helps the first time you try it and then you get comfy pound on them again and the problem persists. More camber will be better but won’t solve what you’re seeing here.
Are those GT radial sx2 or Michelin?
Edit: either way back down the speeds in corners, tires shouldn’t be screaming, ideally they whisper. You can make them scream for a lap but after that you get the wear you see above.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
NoHaveMSG (06-30-2023), Ohio Enthusiast (06-30-2023), whataboutbob (07-01-2023)
Old 06-30-2023, 07:40 PM   #8
andyk5
Drives: GR86
They are Michelin Cup2s but my RT660s wear the same exact way. The only tire that can take my abuse and not get destroyed like this are GT radial SX2s and thats mainly due to them turning in to a hockey puck and just slide after the 3rd track day.
Edit: I think I don't know how to drive fast without abusing my fronts... my laptimes are not even that competitive, running 2:10 at buttowillow with this setup, should be 2:06 ish to be considered reasonably fast.
The Following 2 Users Say Thank You to andyk5 For This Useful Post:
Desertnate (07-21-2023), strat61caster (06-30-2023)
Old 06-30-2023, 07:46 PM   #9
andyk5
Drives: GR86
- Andrew
The Following User Says Thank You to andyk5 For This Useful Post:
Old 07-01-2023, 11:11 AM   #10
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
The cost of a pyrometer is half that of one new tire. So, before ruining another set…
I bought mine on eBay.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Racecomp Engineering (07-01-2023)
Old 07-01-2023, 02:13 PM   #11
andyk5
Drives: GR86
Ok, if I a have a pyrometer and have some measurements lets say mid session, what do I do with that information?
Old 07-01-2023, 02:18 PM   #12
Code Monkey
Drives: Subaru BRZ
It tells you if you are camber limited, if the tire is overinflated, etc.
Get the deluxe version.
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 07-01-2023, 05:36 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
false. a pyro meter doesn't shout "camber!" or "overinflated!", the same as a hammer doesn't build a house.
a hammer is used to nail wood together that can build a house, just as a pyrometer can be used to tell temperature across the width of the tread.
it's how the tool is used, and the information it provides is used that determines the tools functionality.
how does a fancy temperature probe tell camber or pressure issues over a bad wheel bearing or terrible driving?
i'm not saying that it's not part of the solution, but it's not THE solution. even worse, is if the OP were to get one, and then it sits on the shelf.
strat61caster (07-01-2023)
Old 07-01-2023, 07:19 PM   #14
andyk5
Drives: GR86
If it did I'd def buy one lol.
soundman98 (07-01-2023)
Tire wear and tire noise on different tracks (Pitt Race vs Mid Ohio) Ohio Enthusiast Tracking / Autocross / HPDE / Drifting 6 01-13-2023 09:36 AM
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 07:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 12:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 03:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
