Old 06-21-2023, 02:12 AM   #43
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by redvee86 View Post
So is there a consensus on the best oil to use for the transmission?
Originally Posted by humfrz
I'm old and lazy
The Following 4 Users Say Thank You to Clipdat For This Useful Post:
blsfrs (06-21-2023), redvee86 (06-22-2023), soundman98 (06-21-2023), Ultramaroon (06-21-2023)
Old 06-21-2023, 10:52 AM   #44
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I would go with whatever brand name is mentioned most. Motul, AMSOIL, Redline.
From all the posts I've seen, AMSOIL and Redline seem to be better when dealing with cold climates. Not saying that Motul is bad, but like I mentioned earlier in the thread, I switched to AMSOIL from Motul and will probably never go back.
spcmafia is online now   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Old 06-21-2023, 01:32 PM   #45
There never will be. Personally, I'd leave it stock and enjoy the satisfaction of learning the technique to manage it; basically timing and double-clutching.
humfrz (06-22-2023), redvee86 (06-22-2023), soundman98 (06-21-2023)
Old 06-22-2023, 01:32 AM   #46
redvee86 (06-26-2023), Ultramaroon (06-22-2023)
Old 06-22-2023, 03:43 AM   #47
redvee86
redvee
Drives: 2012 Sonic Blue 86 GTS AT
@spcmafia Is there a specific AMSOIL oil that you buy?
redvee86 is offline   Reply With Quote
Old 06-22-2023, 01:40 PM   #48
spcmafia
spcmafia's Avatar
For transmission: https://www.amsoil.com/p/manual-tran...?code=MTGPK-EA
For LSD: https://www.amsoil.com/p/severe-gear...?code=SVGPK-EA
Engine: https://www.amsoil.com/p/signature-s...?code=ASMQT-EA
Old 06-23-2023, 02:07 PM   #49
Tokay444
Shouldn't need any friction modifiers in our LSD, since it does not use a clutch pack.
The Following User Says Thank You to Tokay444 For This Useful Post:
Ohio Enthusiast (06-23-2023)
Old 06-26-2023, 12:26 AM   #50
redvee86
redvee
Tried double-clutching other day and it worked! Thanks a lot!
The Following User Says Thank You to redvee86 For This Useful Post:
Decep (07-03-2023)
Old 06-26-2023, 12:44 AM   #51
Yay! Welcome!
Old 07-03-2023, 10:38 AM   #52
Decep
Drives: 2013 FR-S Series 10
As is often the case with manual transmissions it was the nut between the steering wheel and driver seat
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 07-03-2023, 08:07 PM   #53
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Gotta put loctite on that nut or else it gets a screw loose
Old 07-03-2023, 10:46 PM   #54
soundman98
ProCrastinationConsultant
soundman98's Avatar
do they make medical-grade loctite?
can i be dipped in it?
Old 07-04-2023, 06:05 AM   #55
RZNT4R
Well, tradespeople often use super glue on small cuts instead of bandaids. I'm sure it's possible to be dipped in super glue, just be sure to carefully choose the first thing you touch.
Old 07-31-2023, 07:30 PM   #56
RZNT4R
Hey, I'll bump this saying,
I skipped the gearbox oil this spring when I was doing my maint because I didn't have enough Amsoil MTG for a full fill. Well I'm on vacation now and decided to sort that out, but the only thing I could get in town was Motylgear 75W90. Yeah, the "cheap stuff" semi synthetic from Motul.
Now I'm about 60/40 Amsoil MTG/Motylgear, because I had to mix what little motul I could get with what little amsoil I had left.
Shift so good god damn. I'm not kidding. I was not expecting this. I'm kinda freaked out.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
blsfrs (08-01-2023), Ultramaroon (07-31-2023)
Do I need to be extra careful when shifting 1-2 in cold? lapsio BRZ First-Gen (2012+) — General Topics 49 11-22-2021 10:27 AM
2018 cold shifting konahic BRZ First-Gen (2012+) — General Topics 29 02-28-2020 05:09 PM
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 03:48 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 04:24 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
