Old 06-15-2023, 04:06 PM   #99
Code Monkey
Drives: Subaru BRZ
Went to Barber a couple months ago, did 4 sessions on Saturday, parked the car and later on when it was time to leave I heard a terrible screeching sound coming from the passenger rear side, 4 out of 5 lug nuts were finger tight... Tightened the lug nuts but did not drive Sunday, drove back home and the wheel and wheel studs were done. Took almost two months to source a replacement wheel from Japan and we are back in business.
Code Monkey is online now   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Petah78 (06-23-2023)
Old 06-15-2023, 04:18 PM   #100
Code Monkey
Drives: Subaru BRZ
Adjusted ride height on each corner and got another alignment. Based on tire temps, went to -4.8 camber on driver front and reduced the camber a tad in the rear.
RedReplicant (06-15-2023)
Old 06-21-2023, 09:22 PM   #101
Code Monkey
Drives: Subaru BRZ
Replaced the tired lug nuts with new ones.
Old 06-23-2023, 09:27 AM   #102
Petah78
Drives: 2022 BRZ sport-tech
Was the lug holes on the wheel damaged from running loose lugs? That is some scary stuff.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 06-23-2023, 11:21 AM   #103
Code Monkey
Drives: Subaru BRZ
Yes, that's what happens when an aluminum wheel vibrates against steel wheel studs and lug nuts.
Old 06-25-2023, 11:33 PM   #104
Code Monkey
Drives: Subaru BRZ
Installed the APR 61" GTC-300 wing and front air dam.
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
DarkSunrise (06-26-2023), ihavefat (07-03-2023), Jdmjunkie (06-25-2023), jongers (07-29-2023), RedReplicant (06-26-2023), villainous_frx (06-26-2023)
Old 07-15-2023, 11:37 AM   #105
Code Monkey
Drives: Subaru BRZ
Another oil analysis report.
The Following 3 Users Say Thank You to Code Monkey For This Useful Post:
blsfrs (07-16-2023), Petah78 (07-16-2023), ZDan (07-24-2023)
Old 07-16-2023, 12:23 PM   #106
Petah78
Thanks for posting your UOA. Are you comfortable with the iron/copper reading? What weight/brand oil was used? How many track sessions within the 2000 miles? Thanks
Old 07-16-2023, 03:03 PM   #107
Code Monkey
Drives: Subaru BRZ
Motul 300V 5w40, I always change oil after 6 track days. Not concerned with iron or copper levels. Compared to the last 3 reports from my 2017 BRZ, Motul 300V 5w30, engine rebuilt to OEM specs:
cumulative miles: 2450, 4266, 6106
iron: 8, 12, 7
copper: 5, 4, 2
Iron seems to be ok, copper a bit high but it has been trending down.
Old 07-16-2023, 09:25 PM   #108
Code Monkey
Drives: Subaru BRZ
Some updates on aero...
Went to Road Atlanta, definitely more grip in corners. Most noticeable differences in turn 1 where I was carrying extra 3-4 mph, entering the esses where I could go flat out at the top of the hill instead of waiting a split second for the car to settle, and in turn 12 where I think I should be able to go flat out in 4th once I get used to the aero. Did a 1:42.33 (Harry's Lap Timer) compared to previous 1:44's.
6th session of the day got cut short due to a flat on the back straight; the driver front tire got cut on the inside sidewall. There is paint missing from the coilover spring so the tire must have touched the spring. Not sure though if the tire touched after it got flat and mushroomed on the inside or it was touching here and there and it took 6 sessions to weaken the sidewall.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
jongers (07-29-2023), RedReplicant (07-17-2023)
Old 07-24-2023, 08:56 AM   #109
Code Monkey
Drives: Subaru BRZ
Before heading to Barber, changed the setup a little bit to hopefully avoid cutting the tire again.
Put stiffer springs in; moved the 7" 650 lbs springs from the rear to the front and got 6" 700 lbs springs for the rear with #171 tender springs from Vorshlag. Also raised the car about 0.5" just in case.
Did a 1:44.31 at Barber (compared to previous 1:46's) and the driver front tire got damaged on the inside again, this time in a more dramatic fashion (but still held pressure!). At this point, I believe extra g's from the aero must be stretching the tire sideways enough to contact the spring. Ordered 25mm spacers to replace the 20mm I have now and hopefully the problem will be solved.
To add insult to injury, had a small off into the grass and damaged the splitter. I knew the splitter would get damaged at some point, just hoped it would last more than 2 hpde's. Time to build a custom splitter, one that does not require removing the front bumper.
The Following 7 Users Say Thank You to Code Monkey For This Useful Post:
clu (07-24-2023), DarkSunrise (07-24-2023), Dzmitry (07-26-2023), mistople (07-25-2023), RedReplicant (07-24-2023), villainous_frx (07-24-2023), ZDan (07-24-2023)
Old 07-25-2023, 02:30 AM   #110
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Whoa, that tire looks wild. Glad it didn't fail on you near Mr. Barry R.
mistople is offline   Reply With Quote
The Following User Says Thank You to mistople For This Useful Post:
Code Monkey (07-25-2023)
Old 07-25-2023, 10:57 AM   #111
Racecomp Engineering
Any reason you're not using a front helper spring? Not saying it's causing your tire destruction issues, but your upper spring perch is getting mucked up and just makes me a little nervous.
- Andrew
Old 07-25-2023, 11:04 AM   #112
Code Monkey
Drives: Subaru BRZ
Yes, should probably use a helper spring in front too although I have been running like that for the last 6 years with zero problems. It is always the rear that made a big clunk noise as the springs settled so at least that is fixed.
Racecomp Engineering (07-25-2023)
2017 Subaru BRZ hpde build Code Monkey Member's Car Journals 207 04-18-2022 11:11 AM
2022 BRZ JDM Spec build at HKS USA for SEMA2021 143 BRZ Second-Gen (2022+) — General Topics 5 02-14-2022 01:27 PM
redSerpente’s HPDE/86CUP Street build redSerpente Member's Car Journals 10 04-26-2021 07:50 PM
LS3 HPDE / Time Attack Build RavioliG Member's Car Journals 17 02-11-2018 04:56 PM
86_Freak - Build for DD/C Street/HPDE duties 86_Freak Member's Car Journals 3 03-07-2016 10:15 AM
