| Member's Car Journals Car journals by our members. |
#43 |
Drives: Toyota 86
Day 2 at TMP:
Temperature: 25C (50kph wind) Tire Pressure: 40PSI hot At 25C ambient temperature, oil cooler was keeping up and keeping the oil pretty steady. The transmission oil temperature was climbing and hitting 250F after about 12-14 minutes of lapping. Strongly considering a transmission oil cooler at this point. Next Mods: Wheels + Tires or Suspension? |
| The Following 3 Users Say Thank You to TheBoss77 For This Useful Post: |
#44 |
Weight Weenie
Drives: 15 FR-S
Are you on stock tires? If so, I'd recommend stock size in a 200TW tire.
| The Following User Says Thank You to new2subaru For This Useful Post: | TheBoss77 (06-25-2022) |
#45 |
Drives: '17 Subaru BRZ series.Yellow
Tires are going to gain you the biggest reduction in laptimes, but as you're still learning you should stick(pun intended) with something that's going to be hard-wearing rather than pay an extra $200+ per set of tires for something that'll wear out after 3 track weekends and 1000 miles.
From your video, it looks like you're experiencing a lot of what I'd call wallowing in turns. It could just an artifact of the video and not being able to see the bumps and undulations in the track surface though. If you are experiencing wallowing, I'd actually look at replacing your shocks; which is not what I'd usually suggest to a newbie, but if they're worn and not damping properly it can cause that wallowing effect. It's also going to make it harder for you to learn weight transfer mechanics as it won't be predictable and easy to feel. |
| The Following User Says Thank You to series.trackday For This Useful Post: | TheBoss77 (06-25-2022) |
#46 | ||
Drives: Toyota 86
I'm currently on stock rims and tires. I hear a lot about Hankook RS4 tires being the next logical step and that's what I'm looking at. The OEM tires are getting to the point where they should be replaced (shoulders worn, no camber on the wheels yet).
I'm not sure what you mean by wallowing, what am I looking for to know what it is? Quote:
#47 | |
At 0:16 you enter turn 1 under slight braking and there's a distinct wobble in the viewpoint are you complete the turn, and then again partway through turn 2. You see it again around 1:08 after you complete the chicane and go through the left-hander. It could be the camera mount, could just be the surface being uneven, but to me it looks like wallowing. You can just check yourself if you need to replace the shocks. Go out to your car, put your hands down on the fender right over one of the front wheels, and push down carefully but very firmly, to compress the suspension. If you can "feel" it pushing back up after you take your weight off it, push it back down again. If you can get a good rhythm going where it's obviously starting to bounce back higher, they're dead. If you can't tell either way, you'd have to make the call based on what you're feeling on the track and what I've described. |
#48 | |
Drives: Toyota 86
Since I started racing this car I always thought that there's A LOT of body roll through the turns, especially when going through the S turn. But the suspension feels very stiff going over bumps as I can feel it travelling up my spine
The camera on the car is glued to the windshield so it's definitely not the mount, but it could be steering wheel corrections? The suspension change is inevitable, it's simply a question of what I want to do next. Sounds like the tires are more of a necessity at this point so suspension will have to wait until next turn. Quote:
#49 |
Drives: FRS Hot Lava
Rear shocks wear out pretty soon. I did not believe it until I chanced them with only 15K miles (severals on track)
I replaced OEM with Bilstein, quick and not expensinve job. Not aligment required after that. Later, as I was happy with the Bilstein I did the same on the front, but front shocks were in good conditions. |
| The Following User Says Thank You to fminicooper For This Useful Post: | TheBoss77 (06-27-2022) |
#50 |
Drives: Toyota 86
Took a little break from racing over the hot summer months but now I'm back at it.
Few mods added since: - Fumoto valve for easy and quick oil changes - Whiteline front camber bolts maxed out at -1.5deg and an alignment from friends at local TireCraft - Fresh gulp of Motul 300V oil Went out to the TMP and set a new PB of 1:29.39. Still running stock wheels/tires and suspension, no aero mods. After reviewing the video, there's still plenty of room for improvement without relying on additional mods. I think I can easily shave off another second or two. |
| The Following User Says Thank You to TheBoss77 For This Useful Post: | villainous_frx (08-18-2022) |
#51 |
Drives: Toyota 86
Another season of racing is in full swing.
Shrunk the battery. About 20lbs weight saving, and no fear of battery leaks Used this thread as an inspiration to build the battery bracket, took a slightly different approach: https://www.ft86club.com/forums/show...attery+bracket No issues starting the car, even with the car sitting in the garage for a few days, started instantly each time. I am planning to add a battery cut off switch to preserve the battery when sitting for longer periods of time. |
#52 |
Drives: Toyota GT86
What tires are you planning to run this season ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#53 |
Drives: Toyota 86
| The Following User Says Thank You to TheBoss77 For This Useful Post: | autoracer86 (06-08-2023) |
#54 |
Drives: Toyota 86
Installed Verus Engineering Hood Louvers to lower under-hood temperature. No rain guards, will see if this was a wise decision.
https://www.verus-engineering.com/sh...86-320#attr=13 |
| SOLVED: Window auto up down upon entry feature stopped | Sgtfluffy16 | Issues | Warranty | Recalls / TSB | 22 | 04-02-2020 06:50 PM |
| BRZ keyless entry/ignition and auto climte control system how-to video | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 11-21-2013 02:58 AM |
| Auto Racing in the US and the World... | madfast | Other Vehicles & General Automotive Discussions | 2 | 11-18-2012 07:03 PM |
| Jm racing auto | SF-FRS | User/Vendor/Sponsor Reviews, Feedback, Comments | 8 | 09-28-2012 11:04 AM |
| Fortune Auto vs BC Racing | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 09-11-2012 11:18 AM |
