Old 04-20-2023, 12:31 AM   #1667
funkjaw
Drives: 16' WWB
Originally Posted by RedReplicant View Post
Fortunately it was just two mis-pinned wires, it is alive. (they swapped DBW motor 12v and 12v for the sensors)
I had a friend who just got his kit do some multimetering for me, it looks like they changed wire colors for some stuff and moved some stuff from regular ground to sensor ground (dbw went to sensor ground, cam/crank are still regular ground).
@funkjaw, I'm really surprised at the power you're making - sounds quite healthy, haha.
Glad you got that sorted! It's funny on the dyno today the tuner was saying my oil temps were high and erratic and I had to explain to him that was perfectly normal and not to worry about it...
and thanks man it's pretty exciting!!!... well I mean my wife isn't excited about all the money I spent on this, which is partially the fault of this thread - but I know once she drives it she'll be less pissed off at me.. hopefully.
funkjaw is offline   Reply With Quote
The Following User Says Thank You to funkjaw For This Useful Post:
RedReplicant (04-20-2023)
Old 04-20-2023, 09:02 AM   #1668
ML
ML's Avatar
Drives: 13 White MT FR-S
anyone need some 1000cc DW injectors hit me up.
The Following 2 Users Say Thank You to ML For This Useful Post:
funkjaw (04-20-2023), RedReplicant (04-20-2023)
Old 04-20-2023, 10:52 AM   #1669
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Originally Posted by funkjaw View Post
Dyno time!
I purchased and paid a shop ($2250) to assemble and install a 4 Piston TSX Pro head with some Toda A3 cams, 1. because my original head had leaking valve seals and I was tired of burning oil, 2. because after 15,000 miles I wanted a little more power, and finally 3. because I can no longer work on a car due to needing lower back surgery.
Well it just hit the dyno today and here are the results (followed by complete parts list).
The red lines are WHP and the blue lines are WTQ
The top lines are with the new head/cams on E50
The bottom lines are from when it was originally tuned on stock head/cams on 93
264.3WHP
199.4WTQ
This is making me really excited for my car, I doubt I'll make quite this much but really nice to see some great NA numbers!
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following 2 Users Say Thank You to Kelse92 For This Useful Post:
Old 04-20-2023, 04:08 PM   #1670
redlined600
redlined600's Avatar
Drives: Fr-s
Dyno time!
264.3WHP
199.4WTQ
Overall from when I first swapped the car to now:
+39.6WHP peak
+36.3WTQ peak
Comparing new head/cams on E50 vs stock on 93
I don't have an overlay of when I dyno'd on E85 with the stock heads, but looking back at that old dyno sheet, here are numbers for those curious
+30WHP peak
+4WTQ peak
While +4WTQ doesn't seem like a lot, looking at my E85 graph as a whole it makes more torque everywhere in the power band:
@3300 RPM +5WTQ
@4000 RPM +22WTQ
@5000 RPM +4WTQ
@6000 RPM +10WTQ
@7000 RPM +12WTQ
@8000 RPM +18WTQ
This is really good news to me because I was afraid I would lose some low end going with these cams and happy to report that the opposite happened which is great because this will always be a daily driver first and foremost.
Parts List:
2006 k24A2 from the junkyard - unknown miles
4 Piston TSX Pro Head
Toda A3 camshafts
Bosch 74mm TB with Kpower adapter (we'll see how long this holds out)
Mishimoto Powerstack Performance Air Filter
Toda Valve Springs
Ferrea Valves
OEM retainers, locks, seats
Viton Valve Seals
Toda Timing Chain
Toda Oil Pump Chain
Toda Chain Tensioner
ARP Head Studs
Trac Truf 40 degree VTC limiter (this might have been overkill and may have even robbed a HP or two but I wanted to be safe than sorry)
OEM guides
DragCartel lower guide
I don't have the car back yet but once I do I'll do an acceleration video and compare it to the old E85 setup.
Here is the dyno vid:
That's pretty awesome!
Any chance any of you with a v1 engine harness have the harness out of the car? My harness came back from KPower and the thing doesn't read any of the cam/crank sensors and the throttle doesn't work.
Ready to set it all on fire, I've got a day to get it figured out.
Dude, UGH!
redlined600 is online now   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
funkjaw (04-21-2023)
Old 04-21-2023, 07:12 PM   #1671
funkjaw
Drives: 16' WWB
What front sway bars ya'll runnin without any clearance issues? I have a Hotchkis 25.4mm hollow sway bar and it definitely touches and causes vibrations against the transmission adapter.
Old 04-21-2023, 11:06 PM   #1672
RedReplicant
Drives: None
I've got the Perrin 22mm in mine, fair bit of room there
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
funkjaw (04-22-2023)
Old 04-22-2023, 03:55 PM   #1673
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I have Eibach, and it seems to clear fine.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 04-22-2023, 11:09 PM   #1674
funkjaw
Drives: 16' WWB
As promised here is an acceleration video of my car with the new 4piston head and toda A3 cam setup. It picked up .3 seconds in the 20mph-60mph vs the stock head on E85 in a previous video I posted. This probably translates to 4 or 5 tenths faster in the quarter mile I suppose? Definitely nothing to shake a stick at that's for sure.
The Following 2 Users Say Thank You to funkjaw For This Useful Post:
Jdmjunkie (04-23-2023), RedReplicant (04-23-2023)
Old 04-23-2023, 10:23 PM   #1675
Adamf220
Drives: 2013 frs
Well that sucks, finally got my kit and am working on getting all together and that's the same sway bar I've got
Adamf220 is offline   Reply With Quote
The Following User Says Thank You to Adamf220 For This Useful Post:
funkjaw (04-23-2023)
Old 04-23-2023, 10:44 PM   #1676
funkjaw
Drives: 16' WWB
Yeah I mean it works, but obviously the NVH introduced is not ideal. I'll likely get 20mm sway bar to fix it.
Old 04-24-2023, 12:35 PM   #1677
Kelse92
At the track
Ohh I didn't even think about swaybars being an issue... I bought another Karcepts one recently... hope it works. Guess I'll keep my Perrin 19mm one a little longer as a backup.
The Following User Says Thank You to Kelse92 For This Useful Post:
funkjaw (04-25-2023)
Old 06-02-2023, 03:52 PM   #1678
Irace86.2.0
Hey fellas,
I've reached out to OS Giken, Competition Clutch, Clutch Masters, Exedy, Tilton, XClutch with inquiries about whether their twin clutches would work. Clutch Masters, for instance, makes a K24 to Subaru transmission adapter and flywheel that work with their twin discs, but this is for the EJs (see below). Several have gotten back to me with a "No" and some have asked for measurements and some said they could if I sent in my flywheel or provided accurate measurements.
https://clutchmasters.com/i-30508045...-flywheel.html
Does anyone know these dimensions who has their parts readily available? I have a spare transmission in my garage, so I could probably get the thickness of the adapter plate, the distances to the TOB and input shaft from the transmission, but I don't have the engine out to be able to measure the flywheel and engine side. If someone is feeling so kind then I would appreciate any measurements they could contribute.
My goal is to get a twin disc that is organic, sprung and with a steel flywheel for the most steetable clutch setup possible, but I don't know if I will be able to get everything I want. I've read and watched videos that the Clutch Masters is nice because the spring tensioners on the plates make them not rattle, so it doesn't sound like a Ducati dry clutch.
RedReplicant (06-02-2023)
Old 06-02-2023, 04:36 PM   #1679
Jdmjunkie
Drives: Scion FR-S 10 Series
I hope OS Giken responds positively. They make some of the best clutches I have every used. And they only make noise when you push in the clutch because of the floating pressure plate. Also it would me I could buy their sequential transmission if I ever win the lottery.
Jdmjunkie is offline   Reply With Quote
The Following 2 Users Say Thank You to Jdmjunkie For This Useful Post:
Irace86.2.0 (06-02-2023), RedReplicant (06-02-2023)
Old 06-02-2023, 05:14 PM   #1680
Irace86.2.0
They did. They want to know the thickness of the adapter plate.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Jdmjunkie (06-02-2023), RedReplicant (06-02-2023)
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
