Drives: 2015 FR-S
1 Misfire on all cylinders, No CEL
Hey guys, I'm getting 1 single misfire on all cylinders at both cruise, partial throttle and cold startup. But its always a SINGLE (1 count) misfire according to my ECUTEK log. After every drive I will see misfire on all cylinders and the max count for each is always 1. Of course there's no CEL and I'm wondering if these misfires are just normal that everyone gets? For a normal misfire shouldn't I see the count go higher in a short period of time in the log right? Here's the logs when I captured them for cruise and partial throttle.
2015 FRS 68K miles with Edelbrock SC + Tomei EL Headers and stock injectors. Temps aren't that high in these logs and I don't track the car, obvi since all cylinders have a misfire I can't swap coils to test. Sparks plugs were done at 58K https://datazap.me/u/s0007/misfire-c...g=0&data=27-44 https://datazap.me/u/s0007/misfire-c...g=0&data=28-46 Last edited by FrickingReallySlow; 05-08-2023 at 12:15 PM. |
#2 |
Drives: 2015 FR-S
Found a post by @Strat_FRS on misfires of eco boost engines. Seems like random and intermittent Misfires are expected and normal...if no CEL
https://www.stratifiedauto.com/blog/...uld-you-worry/ |
| The Following User Says Thank You to FrickingReallySlow For This Useful Post: | Grady (05-12-2023) |
#3 |
Miss-fires are normal, excessive miss-fires are not. That is why you need multiple to throw a CEL.
| The Following User Says Thank You to Grady For This Useful Post: | FrickingReallySlow (05-12-2023) |
#4 |
Drives: brz 2017 hksv2
yeah i would n' t worry about 1 single misfire
| The Following User Says Thank You to tomm.brz For This Useful Post: | FrickingReallySlow (05-12-2023) |
| Misfire all cylinders - Rich no CEL | Celigts | Issues | Warranty | Recalls / TSB | 25 | 09-22-2022 02:23 AM |
| Coolant in cylinders | Matthew_ | Engine, Exhaust, Transmission | 13 | 11-12-2020 01:48 AM |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 01:11 PM |
| large clear plastic bottles/cylinders??!?!/ | 7thgear | CANADA | 8 | 01-21-2014 09:38 AM |
| Difference in cylinders? | Buggy51 | Other Vehicles & General Automotive Discussions | 6 | 07-02-2011 09:46 AM |
