Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-24-2022, 09:15 AM   #1
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Price friendly spare tire/hardware kit?
I tried searching on here. Anyone have the dealership/Subaru part number for mounting hardware and where to buy a spare donut tire wheel setup?
vindiesel is offline   Reply With Quote
Old 11-24-2022, 09:39 AM   #2
EZLVN
Drives: 2022 BRZ Premium, 1990 Miata
I bought a spare on eBay for 80.00 that was from a 2016 BRZ.
It fits the recess in the trunk cavity perfectly, and I have not found it necessary to bolt it down. It hasn’t shifted around, even under hard cornering.
EZLVN is offline   Reply With Quote
Old 11-24-2022, 10:23 AM   #3
Auto wreckers usually almost give spares away.
x808drifter (11-25-2022)
Old 11-25-2022, 09:17 AM   #4
vindiesel
vindiesel's Avatar
Thank you both!
The Following User Says Thank You to vindiesel For This Useful Post:
Tcoat (11-25-2022)
Old 11-27-2022, 04:04 AM   #5
ruturaj001
Drives: BRZ 2023
Not specific to PP or regular
Spare Tire Bolt : 901720002
Spare Tire Washer: 97047FG000
Performance specific parts
PP Spare Wheel: 28151FE030
PP Spare Tire: 28121VA050
PP Spare Foam Insert: 95086CA070
PP Spare Foam Spacer: 97046CA000
Regular spare
Spare Wheel: 28151FJ031
Spare Tire: <Still looking>
Spare Foam Insert: 95086CA040
Spare Foam Spacer: 52153PA181
Be careful about buying a very old tire. And if you are planning to get big brake kit then get performance package wheel. I had wheel oddly placed once, bolt wasn't tight enough and I could hear it going over bump. So would definitely recommend the washer and bolt, I paid about $12 with tax.
Wheel was 124 and then I had to buy tire which I got from tire rack. Subaru tires were pretty old that someone else ordered.
ruturaj001 is offline   Reply With Quote
The Following User Says Thank You to ruturaj001 For This Useful Post:
vindiesel (11-27-2022)
Old 11-27-2022, 06:14 PM   #6
mpg9999
Drives: 2022 BRZ
It's not cheap, but if you're looking for new: https://ez-sparewheel.com/products/1...0&%20Submodels)
mpg9999 is offline   Reply With Quote
Old 11-29-2022, 08:29 PM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The PP spare doesn't fit over certain BBKs, such as Brembo B-M4.
I have that BBK and went with a regular spare.
If I get a flat front tire, my plan is to put a rear wheel/tire in the front, and the spare in the rear.
Follow the build thread for my GR86!
Old 11-29-2022, 09:24 PM   #8
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Have you tried with a spacer?
My GT barely clears with a 3mm spacer (under 1mm)
EndlessAzure is offline   Reply With Quote
Old 11-29-2022, 09:42 PM   #9
ruturaj001
Drives: BRZ 2023
Might not be a good idea to put donut in rear. May be just put full spare in trunk.
Old 11-29-2022, 09:50 PM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The issue is the barrel.
The B-M4 hits the barrel of quite a few wheels that fit PP Brembo without problems.
Old 11-30-2022, 02:03 PM   #11
22BRyanZ
22BRyanZ's Avatar
Drives: 2022 BRZ Premium manual
On eBay I was lucky and found a spare wheel/tire from a 2020 Impreza for $60. Same size as BRZ but there's a greater market supply of them. Got the bolt and washer from my local Subaru dealer.
22BRyanZ is offline   Reply With Quote
The Following User Says Thank You to 22BRyanZ For This Useful Post:
vindiesel (12-02-2022)
Old 05-09-2023, 06:58 AM   #12
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
A regular bolt and some large washers will hold the spare in place. I think it's an M8 bolt.
Mcgiiver is offline   Reply With Quote
Old 05-13-2023, 06:40 PM   #13
vindiesel
vindiesel's Avatar
Just paid 130$ shipped wheel tire from older brz and Subaru parts online for bolt and washer to mount in truck. There is minimal Subarus in junkyard near me
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
Old 05-14-2023, 08:13 PM   #14
vindiesel
vindiesel's Avatar
ZionsWrath (10-18-2023)
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 10:36 PM
WTB: Spare Tire kanundrum Want-To-Buy Requests 2 11-15-2016 12:30 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 02:44 PM
Custom full size spare friendly trunk BE4VER Cosmetic Modification (Interior/Exterior/Lighting) 2 08-03-2014 01:53 PM
