Old 05-08-2023, 12:01 PM   #1
FrickingReallySlow
Drives: 2015 FR-S
1 Misfire on all cylinders, No CEL
Hey guys, I'm getting 1 single misfire on all cylinders at both cruise, partial throttle and cold startup. But its always a SINGLE (1 count) misfire according to my ECUTEK log. After every drive I will see misfire on all cylinders and the max count for each is always 1. Of course there's no CEL and I'm wondering if these misfires are just normal that everyone gets? For a normal misfire shouldn't I see the count go higher in a short period of time in the log right? Here's the logs when I captured them for cruise and partial throttle.
2015 FRS 68K miles with Edelbrock SC + Tomei EL Headers and stock injectors. Temps aren't that high in these logs and I don't track the car, obvi since all cylinders have a misfire I can't swap coils to test. Sparks plugs were done at 58K
https://datazap.me/u/s0007/misfire-c...g=0&data=27-44
https://datazap.me/u/s0007/misfire-c...g=0&data=28-46
FrickingReallySlow is offline   Reply With Quote
Old 05-08-2023, 06:08 PM   #2
FrickingReallySlow
Drives: 2015 FR-S
Found a post by @Strat_FRS on misfires of eco boost engines. Seems like random and intermittent Misfires are expected and normal...if no CEL
https://www.stratifiedauto.com/blog/...uld-you-worry/
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Grady (05-12-2023)
Old 05-12-2023, 10:48 AM   #3
Grady
Grady's Avatar
Miss-fires are normal, excessive miss-fires are not. That is why you need multiple to throw a CEL.
The Following User Says Thank You to Grady For This Useful Post:
FrickingReallySlow (05-12-2023)
Old 05-12-2023, 11:42 AM   #4
tomm.brz
Drives: brz 2017 hksv2
yeah i would n' t worry about 1 single misfire
Misfire all cylinders - Rich no CEL Celigts Issues | Warranty | Recalls / TSB 25 09-22-2022 02:23 AM
Coolant in cylinders Matthew_ Engine, Exhaust, Transmission 13 11-12-2020 01:48 AM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 01:11 PM
large clear plastic bottles/cylinders??!?!/ 7thgear CANADA 8 01-21-2014 09:38 AM
Difference in cylinders? Buggy51 Other Vehicles & General Automotive Discussions 6 07-02-2011 09:46 AM
