Old 03-30-2023, 04:14 PM   #15
It arrived, quite quickly actually.
Hey, that's encouraging! Mind taking a pic of the bore?
Old 03-30-2023, 04:37 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I will grab one and post it later.
Ultramaroon (03-30-2023)
Old 03-30-2023, 09:57 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not a great pic, but here is the inside of the sleeve.
The quill on my spare trans is in good shape and measured a tick over 1.292"
Exedy bearing ID is 1.309", hard to measure though since it is plastic. The width of the inner bearing "race" measured .752".
The inner sleeve on the BG has an ID of 1.306". The length of the sleeve that rides on the quill measured 1.387". I have a little mixed feeling about the grease groove but I don't think it will be an issue.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkSunrise (03-31-2023), soundman98 (03-30-2023)
Old 03-30-2023, 10:27 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've got mixed feelings as well. once one starts using the clutch, that dust is going somewhere, most likely right into that dab of wet grease...
NoHaveMSG (03-31-2023)
Old 03-31-2023, 12:32 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is the main thing I don't like. I may grease it lightly and drop out the transmission at the end of the year and see what it looks like.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (03-31-2023), villainous_frx (05-12-2023), Wally86 (05-01-2023)
Old 03-31-2023, 05:33 PM   #20
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
That will be a great service to the rest of us.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
NoHaveMSG (04-01-2023), Wally86 (05-01-2023)
Old 03-31-2023, 09:40 PM   #21
soundman98
soundman98's Avatar
when i saw that part of the video, i started wondering about using a dry lube instead. but that still negates the grease-holder lip.
Old 04-01-2023, 02:09 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah. I’m kinda wondering about the dust globing up the grease and getting it flung around. There’s enough room on the back section lubricant impregnated plain bearing would fit. I’m not looking to redesign this for them though but I will message them my opinion on it after I have some time on it.
Capt Spaulding (04-01-2023), soundman98 (04-01-2023)
Old 04-02-2023, 11:24 PM   #23
Turdinator
Señor Member
Turdinator's Avatar
Silicone based greases don't grab dust in the same way petroleum ones do. Worth using if you can find an appropriate one.
1974 TA22 Celica
2013 86 GT
The Following 5 Users Say Thank You to Turdinator For This Useful Post:
Capt Spaulding (04-03-2023), Jdmjunkie (04-03-2023), NoHaveMSG (04-03-2023), soundman98 (04-02-2023), Wally86 (05-01-2023)
Old 04-07-2023, 10:34 PM   #24
soundman98
soundman98's Avatar
i can't decide if my bearing is starting to have issues, or i'm just not driving the car as much. there's times where the clutch pedal feels 'notchy'. zero noise, just a feeling in the clutch pedal that could entirely be an unfamiliarity with not using the car every day.
in any case, i ordered the full verus/bearing kit. just need to come up with the retention clips.
i don't buy all the snake oil they're selling, but feel the lengthened bearing carrier should definitely help keep the bearing aligned with the clutch fingers much better than the bearing alone. and the obvious bearing shielding should definitely be an improvement as well. though despite lack of details on the 'low friction coating', i figure any coating ought to be better than no coating.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (04-08-2023), RToyo86 (04-24-2023)
Old 04-24-2023, 01:25 AM   #25
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I put an order through for the full kit with versus fork. Seperately ordered an exedy OEM clutch/flywheel.
My 2017 has 75k miles with no idea how long the "revised" TOBs actually last..
Old 04-24-2023, 02:45 AM   #26
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
The one put in my car by Toyota lasted about that long.
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
RToyo86 (04-29-2023)
Old 04-29-2023, 07:52 PM   #27
RToyo86
RToyo86's Avatar
Got an ETA that next batch should be shipping in roughly a week.
Some what related can anyone confirm if the exedy OEM clutch kit comes with the retainer clip?
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
DarkPira7e (04-29-2023), Wally86 (05-01-2023)
Old 05-06-2023, 05:17 PM   #28
CMAutohaus
CMAutohaus's Avatar
Drives: AE86, R33 GTST, X Runner
Kit does NOT come with the clips. You need to buy the 3 clips separately from the dealer.
CMAutohaus is offline   Reply With Quote
The Following User Says Thank You to CMAutohaus For This Useful Post:
Jdmjunkie (05-07-2023)
Throwout bearing going bad B-R-Z Engine, Exhaust, Transmission 40 09-08-2017 10:23 AM
Best quality throwout bearing? smg1138 Engine, Exhaust, Transmission 19 07-31-2017 08:48 AM
Throwout bearing. bdanisi Issues | Warranty | Recalls / TSB 54 07-17-2016 07:13 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 02:17 PM
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 03:17 AM
