| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Argento Scion FR-S
Performance Wheel Test - A Look at Wheel Weight, Density, and Stiffness
https://www.motortrend.com/how-to/mo...nce-wheel-test
It’s true, wheel weight by itself doesn’t give you much info. Where is the weight? A lighter wheel with less mass in the middle isn’t going to do much for you, if I understand. And then you have the tires, which are 20 lbs by themselves, and at the edge of the rotating mass. Sure 20 lbs vs 30, 20 will likely be better, but a lot 2 lbs difference?
#2 |
Drives: 2017 BRZ w/PP
On average people are too dumb to understand what rotational inertia is, that is why just weight (technically it should list mass instead) is listed. I=mr^2 so for a given mass as the distance from the axis of rotation increases the resistance to rotation will go up exponentially. The tire is ignored because it is assumed the same on every wheel.
| The Following 2 Users Say Thank You to Breadman For This Useful Post: | mike_ekim1024 (05-01-2023), soundman98 (05-05-2023) |
#3 | |
But there are a few pounds difference between Michelin and Bridgestone performance tires for example. Shouldn't we be looking at that?
| The Following User Says Thank You to mike_ekim1024 For This Useful Post: | Spuds (05-03-2023) |
#5 | |
Oh, yes, I don't mean test the wheel and the tire at the same time. I mean once you stick with a wheel, to test the tire independently. The point I was making was that the tire is just as heavy as the rim, and it's on the very edge of the wheel.
| The Following User Says Thank You to mike_ekim1024 For This Useful Post: | Ohio Enthusiast (05-01-2023) |
#6 |
Drives: 2013 BRZ HKS Turbo
Rotational inertia is not the primary reason for lighter weight wheel/tire...the primary benefit is less unsprung weight. Less unsprung weight allows the suspension to work more efficiently and effectively.
But as this article attempts to show, but does a poor job at, is that wheel weight really doesn't matter for 99.9% of applications. You aren't going to feel it in unsprung mass, and you certainly aren't going to feel it in inertial effects. This does not hold true if you start comparing extremes. A 20 lbs monoblock compared to a 35lb 3piece wheel will be noticeable...but I'd bet at least 50% of this forum still couldn't tell the difference! These 1, 2 lbs weight differences only matter if you are in the upper echelon of racing. What does actually matter, and what many people can feel, is what this test and most others seem to disregard. Wheel rigidity and impact strength. Wheels bend and twist quite a bit, especially on track, and this can be felt through the steering wheel. Lower quality wheels, tend to have less overall strength, impact, tensile, and compressive, AND they tend to be less plastic in deformation...aka you're wheel will crack catastrophically instead of bend. And to make matters more complex, material properties are only half the equation, the other half is design characteristics, and the devil is in the details there. Wait until most of you figure out the term "forged" or "made in china" doesn't mean a god damn thing to the wheel's quality, and can even indicate the opposite of what you might think.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
| The Following 5 Users Say Thank You to terboboost For This Useful Post: | Clipdat (05-03-2023), DocWalt (05-03-2023), mike_ekim1024 (05-02-2023), NoHaveMSG (05-02-2023), soundman98 (05-05-2023) |
#7 |
The Dictater
Drives: '13 Red Scion FRS
I can tell the difference in inertia when I put on my summer wheels and tires vs the "winter" (all seasons on stock wheels) set. I think the wheels are -5lb and tires are -2lb. I did calculate it out once* and the tires made more of a difference mathematically.
*Approximating the wheel as a simple cylinder and tire as a simple ring.
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | mike_ekim1024 (05-03-2023) |
#8 | |
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
For example here you can find tires weight in specs at the bottom: https://www.tyrereviews.com/Article/...-Tyre-Test.htm Retreaded semi slicks are also often described as heavier comparing to regular tires so yeah - it is something that people consider when buying tires. Especially competition ones. That said I believe weight in case of tires is much more complicated because it's directly connected to properties like sidewall stiffness for example. I think rims have less variables and when you're looking for performance then basically you mostly care about size and weight. With tires there's billion of variables and weight while is there it's probably secondary parameter comparing to what most people look after - compound, driving characteristics, feedback, operating temps, wet performance etc etc |
| The Following User Says Thank You to lapsio For This Useful Post: | mike_ekim1024 (05-05-2023) |
#9 |
Drives: 2022 BRZ; 2014 BRZ
The biggest difference I notice in weights between my different wheels is how easy they are to take on and off. When you're swapping wheels 2+ times a month it becomes very noticeable. As far as driving goes, eh I've never noticed a massive difference between wheels. I'm sure it shows up a little on the stop watch, but the biggest differences are going to be with tire compound.
| The Following User Says Thank You to foshjowler For This Useful Post: | mike_ekim1024 (05-05-2023) |
#10 |
Drives: 2023 brz limited 6mt red
I just drive around with 2 gallons of gas in the gas tank. I unsprung 60lbs of liquid weight compared to full tank. Didn’t have to buy light weight wheels or gut the interior. So much cheaper.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
| The Following User Says Thank You to vindiesel For This Useful Post: | mike_ekim1024 (05-07-2023) |
| Performance package wheel/tire weight vs. regular wheel/tire combo | qqzj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-26-2019 01:27 AM |
| How much does wheel weight affect performance? | Slammillionaire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 89 | 07-05-2019 02:20 PM |
| Does wheel weight matter that much? | smg1138 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 03-06-2015 03:57 AM |
| Steering wheel stiffness? | j4m35ly | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-20-2012 02:51 PM |
