Old 04-30-2023, 11:50 PM   #1
CPTKaplin
Drives:
FRS no start
Frustrating when you can’t get home! 2014 manual. Car started up perfectly, and I drove to the gym. Hour and a half later I get in, and the sucker doesn’t start. Tried to turn over but not enough power. I tried roll starting it, I was so close but just couldn’t get enough speed. After waiting around for a bit I finally flagged down a lady about to workout and she gave me a jump. Started up, and drove the 15 minutes back home, kept the car running for another 15 minutes then shut it off. Instantly tried to start it up again but it wouldn’t roll over. Wishing I had a voltage reader!
Your thoughts? Must be a bad battery I’m thinking if it’s just not holding a charge but it’s only like 8 months old. Also notched a lot of corrosion around the terminals if anyone knows what that may be from. Any thoughts, experiences or advice would be appreciated. CCW appointment in the morning, can’t miss that haha.
CPTKaplin is offline   Reply With Quote
Old 05-01-2023, 12:07 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
If the battery is brand new, maybe its an almost dead alternator
Old 05-01-2023, 12:09 AM   #3
Better get a new battery tonight if you want to drive it tomorrow. Sounds like you got a dud battery. Warranty claim.
Old 05-01-2023, 12:09 AM   #4
EPS depends on a healthy alternator.
Old 05-02-2023, 11:22 AM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Key word in the description of the problem: Corrosion
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 05-02-2023, 01:11 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I had corrosion on my first FR-S' battery terminal and was working under the hood one time near it before I cleaned it all off.
A gust of wind came and blew a tiny spec of the corrosion off and into my eye.
Had to flush my eye with water for a solid hour. That sucked.
Originally Posted by humfrz
I'm old and lazy
Ultramaroon (05-02-2023)
Old 05-02-2023, 05:18 PM   #7
A little water mist keeps the dust from flying. Works great for sulfuric acid as well as hantavirus.
Old 05-02-2023, 06:12 PM   #8
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Oh God, nothing worse than the smell of mice nesting in your car! I had one in a work van about 25 years ago and couldn't locate it for the life of me until finally the headliner started "seeping" above my head. Horrible smell and I'll never forget it.
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Old 05-02-2023, 06:22 PM   #9
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
The battery is low, charge it. That is all. Driving a car around for 30 minutes, even an hour, won't fully charge a low battery. It needs to be put on an actual charger.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Old 05-02-2023, 07:28 PM   #10
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Not necessarily.: If the corrosion is built up heavily enough between the battery post(s) and the clamps, the car will have both starting problems and charging problems. Using jumpers on the outside of the clamps in an attempt to start, will allow the car to start, however, the corrosion between the post and clamp may not allow the battery to charge properly.
OP really needs to obtain a multi-meter like he said to verify voltages at the proper points in an attempt to further troubleshoot.
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 11:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 12:54 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
