Old 04-24-2023, 02:15 PM   #1331
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Fun fact, wind turbine mounting structures load calculations are based on the blade area being a solid disc, as the impedance to airflow the blades provide is technically similar.
So next time you pass a wind farm, imagine sticking that large of a flat disc of material up on a stick in a windy area, when I can't even hold a 4x8' sheet of plywood up in my driveway!
You've probably seen the size of the buried concrete foundations of those things. They are immense.
And they quickly feather the blades in strongish winds.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
soundman98 (04-24-2023)
Old 04-24-2023, 06:36 PM   #1332
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by alex87f View Post
While I don't doubt the fact efficiency can be gained on a EV through better heat mgmt, I'd take any positive Tesla news with a grain of salt when the article is followed by a Tesla referral code.
But yeah, apart from these gains there are no physics-bending way to run ancillaries. Any energy has to come from somewhere, just like it does on an ICE's ancillaries.
I do wonder whether a steam turbine would make sense to generate electrical power on an ICE, since 60% of gasoline's theoretical power is dissipated.
Years ago, before I got an engineering degree and learned to calculate stuff, I had read something about an ICE with extra steam powered stroke(s) or something along those lines. No idea if it made any sense or even if it was a real thing.
Also: "Build Thread"
Old 04-25-2023, 05:23 AM   #1333
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Well the theory behind it sure makes sense, but there are a few hurdles I can already think of, like:
-some ancillaries like the water pump or AC need to start running as soon as the engine starts up, they can't wait until the engine warms up and builds steam pressure
-you can map the alternator to only work in braking situations, which is a far simpler solution than a steam turbine
However, using a steam turbine to charge a hybrid battery that provides power assist would make sense on paper, and could provide a mileage boost to closed-circuit hybrids in situation where they don't use KERS, such as constant-speed highway driving. The only research paper I could find on this is from Egypt and is 20 years old so it's either super-duper-confidential, or not something being worked on.
It's likely too late for an idea like this that only provides marginal gains, in a world where PHEVs and BEVs will soon take over.
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Spuds (04-25-2023)
Old 04-25-2023, 09:57 AM   #1334
Spuds
The Dictater
Spuds's Avatar
My guess is the latter lol.
Capt Spaulding (04-25-2023), MyHybridBurnsGasAndTires (04-25-2023)
Old 04-26-2023, 11:35 AM   #1335
Drives: what
https://www.theverge.com/2023/4/26/2...-affordable-ev
GM killing off the Bolt, rip
MyHybridBurnsGasAndTires is offline   Reply With Quote
Old 04-26-2023, 02:05 PM   #1336
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by MyHybridBurnsGasAndTires View Post
Yeah, too bad, but the people have spoken, and they want giant trucks and not small, affordable cars, and there are investors to consider--capitalism, right?
Barra said it was in order to shift operations at its assembly plant in Orion Township, Mich., toward the production of two electric trucks: the GMC Sierra EV and the Chevy Silverado EV.
"We'll need this capacity because our trucks more than measure up to our customers' expectations, and we'll demonstrate that work and EV range are not mutually exclusive terms for Chevrolet and GMC trucks," Barra told investors.
Though GM relies heavily on sales from gas- and diesel-powered trucks and SUVs, the company announced two years ago that it was setting a goal of producing only electric vehicles by the year 2035.
"When the Chevrolet Bolt EV launched, it was a huge technical achievement and the first affordable EV, which set in motion GM's all-electric future," GM spokesperson Cody Williams told NPR via email.
Now the company is shifting gears, turning some of those popular trucks into EVs and launching other electric models later this year, including the Chevy Blazer EV and the Chevy Equinox EV, Williams added.
When GM's Orion assembly plant reopens in 2024 and reaches full production capacity, Barra said in the call with investors, jobs will nearly triple there and the company will be able to build 600,000 electric trucks each year.
https://www.npr.org/2023/04/26/11721...vehicle-ending
Old 04-26-2023, 05:07 PM   #1337
Well, that's what she said, but really it's being replaced by the Equinox EV so they can get the Ultium battery in the bottom level car, and it can DCFS. I really think they didn't want to re-engineer the Bolt for that.
Irace86.2.0 (04-26-2023)
Old 04-26-2023, 05:57 PM   #1338
Lantanafrs2
Drives: 2013 frs red
Thank God. I wouldn't want it any other way
Lantanafrs2 is offline   Reply With Quote
Old 04-26-2023, 06:59 PM   #1339
ZDan
ZDan's Avatar
Drives: '23 BRZ
CAFE regs are skewed to favor trucks/SUVs over cars, and also to favor *larger* cars over smaller. Automakers find it easier to meet regs with bigger, less-efficient vehicles. Level the CAFE across the board, make it more stringent every year, and we'll get a lot more reasonable size/weight vehicles on the road and fewer monsters.
Old 04-26-2023, 07:28 PM   #1340
Irace86.2.0
Why do you say that? Seems like they could build any new gen compact with a similar shell and call it a Bolt. I see no reasons why they would be able to build a new, EV Equinox, but would be stuck reengineering and retrofitting a new powertrain to the old Bolt.
Old 04-26-2023, 07:51 PM   #1341
Irace86.2.0
I always thank God for capitalism too and for God to save capitalism from capitalism.
https://fortune.com/2023/04/05/end-o...orate-profits/
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Capt Spaulding (04-26-2023)
Old 04-26-2023, 08:32 PM   #1342
Capt Spaulding
Persona Non Grata
Agreed, except for the first clause.
Old 04-26-2023, 08:43 PM   #1343
Irace86.2.0
Are we really going back to this conversation? People are choosing to buy these vehicles. Like yes, CAFE standards aren't as strict for SUVs and light duty trucks than cars, but heavier vehicles are harder to make efficient too, so either way, it is hard on manufactures. They are selling SUVs and trucks because people want to buy them, and because there is greater profit margin on selling larger vehicles with larger engines and with more stuff. Every industry is trying to upsell you to a larger and more expensive version of the same thing whether we are talking about a double cheese Whopper with XL soda or your 75" TV with 8K resolution.
CAFE standards will likely evolve to apply to EVS, but all EVs meet CAFE standards. Even the Hummer EV gets 52 MPGe, so manufactures could sell only Hummer EVs and not pay a CAFE fine. Discontinuing the Bolt for EV trucks is just good business for them--more money in their pockets. It would also remove more ICE trucks off the road, which do emit more emissions, so by replacing the Bolt with the EV trucks, they are making more money, reducing the fines they might be paying on the trucks and reducing emissions more. Sounds like a win/win, even if it is less than optimal.
Old 04-26-2023, 08:55 PM   #1344
It is pretty much the consensus on several forums I read. They could do what you said but the Bolt didn't meet their sales projections primarily based on it's looks, and the Equinox is closer to what sells these days.
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 02:46 AM
Does anyone know why pansontw got banned? Soloside Off-Topic Lounge [WARNING: NO POLITICS] 17 10-26-2018 05:20 AM
Got banned from gf's complex jdmblood Other Vehicles & General Automotive Discussions 11 07-12-2015 01:46 PM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 03:23 PM
Banned Toyota GT 86 Advert Banned Nevermore FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 11-16-2012 08:27 PM
