#4355 |
Drives: '13 FRS - STX
@Spuds add a degree of camber up front, you may be ok with it, but I guarantee the outside edges of your tires aren’t.
#4356 | |
The Dictater
Drives: '13 Red Scion FRS
Also: "Build Thread" |
#4357 |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Racecomp Engineering (04-14-2023), Spuds (04-14-2023) |
#4358 |
Track Day Junkie
Drives: 2022 BRZ Limited
YES! For AX or road course you should be at or near 4° in the front.
Stiffen the rear andor soften the front, stiffer setting on rear sway bar. Increase rear spring rate. Tire air pressure adjustments. You should be monitoring them closely, regardless of size. A pyrometer is a must for dialing in the car's camber and pressure. There's a ton of info on the web for how to set up a RWD car! Like: https://www.se-r.net/car_info/suspen...cle%20Dynamics
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube Last edited by Scargod; 04-15-2023 at 08:07 AM. Reason: Clarification |
#4359 |
Drives: 2014 GT86
In HPDE extra negative camber noticeably added grip and improved tire wear EVEN with stock primacies i've been on at first trackdays. But obviously will work/help with better tires aswell. Primacies have relatively stiff sidewalls for street tires though, and not sure of -4 is needed, settled on -3 front/-2.5 rear ..
| The Following User Says Thank You to churchx For This Useful Post: | Spuds (04-15-2023) |
#4360 |
The Dictater
I increased camber up front. Haven't measured yet but should be around 3°. Also took out some toe in the rear. Hoping I got it pretty close to 0.
| The Following User Says Thank You to Spuds For This Useful Post: | strat61caster (04-15-2023) |
#4361 |
Dismember
Drives: 2013 Red Scion FR-S
How true is this statement?
"The truth of the matter is spring rates really do not affect the ride harshness, especially when we speak about shocks and bumps when running over bumps and potholes. This is more in the hardness of how dampers absorb ultra-fast compression motions." Please explain.
#4362 |
Ever had adjustable dampers? Full stiff and it’s garbage over bumps, big range and full soft sucks too. Really it’s both springs and dampers (and the rest of the suspension design and chassis), but good dampers can cover for sub-optimal springs, you can’t really cover for shit dampers though.
#4364 |
Drives: 2017 BRZ PP, 2004 WRX
This is going to be a spicy question, but for an upper-intermediate driver, what do you think the actual autocross run difference would be between going with something like the RCE SuperStreet-1's vs. Tarmac 2's?
Given all other things are equal, such as going with a 245/40/17 A052's on 17x9, having rear lower control arms, same alignment with a good 3-4 degrees up front, same power, etc. I'm kinda torn with going with an all inclusive SS1 setup with tophats and just getting probably 95% of the same performance vs going all in with a ~$3k+ setup with the Tarmac 2's, separate tophats, etc. Would I appreciate the Tarmac 2's as I graduate into being a more top level driver? Currently have about 10 years experience, 5 of those being on the competitive end.
#4365 | |
Drives: Crapcan
#4366 | |
The Dictater
Front camber 2.9° Rear Camber 2.0° Toe is somewhere between 0° and +0.04° both front and back, which is about as close to 0 as I can get in my garage. I also went to the stiff setting on my sway bar. I'm pretty happy with the changes and balance now. Might need to get more camber when I get stickier tires, but I'll cross that bridge when I get to it. Running 0 toe in the rear vs some toe in like before I think is an improvement for autocross, or at least I like it more. The rear is just a bit less stable than before so I have to be a bit more careful on fast direction changes but it's happier getting around tighter/slower corners. Thanks for the feedback folks.
| The Following User Says Thank You to Spuds For This Useful Post: | strat61caster (05-15-2023) |
#4367 | |
Drives: Toyota GT86
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#4368 |
The price is the same as the Tarmac 2's and yes, you have to additional camber plates for those, but if you're spending that much, might as well go all the way for a few hundred more.
That's where I think the SS-1 shine. Good valving, KW build, tophats included, sub $2k price.
| The Following User Says Thank You to cmiovino For This Useful Post: | autoracer86 (05-15-2023) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
