Old 04-01-2023, 01:00 AM   #19755
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
How much negative camber in front "should" you run for DD/canyon carving? -2 degrees?
Originally Posted by humfrz
I'm old and lazy
Old 04-01-2023, 07:03 AM   #19756
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
1/2 a degree would be plenty for my sister to get a good run out of her tires. Though she would probably wear the insides more. I like -2.5 and get good wear over the life of the tire with suitable pressures. So it all depends!
The Following User Says Thank You to gen3v8 For This Useful Post:
Ultramaroon (04-01-2023)
Old 04-01-2023, 03:26 PM   #19757
That's what sucks about static camber. Have to decide between cornering or even tread wear. In reality, the cost of the rubber wasted is a pittance compared to overall cost of operation/ownership. We're only losing the ability to even out the wear through periodic tire rotation. IMO, for a DD, just toss in some negative and call it good.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
Dzmitry (04-05-2023), jcw99 (04-07-2023), MrSkubi (04-03-2023), new2subaru (04-03-2023), NoHaveMSG (04-03-2023), RToyo86 (04-08-2023), soundman98 (04-01-2023), Teseo (04-01-2023), villainous_frx (04-02-2023)
Old 04-01-2023, 06:57 PM   #19758
Teseo
Drives: frs
I'm like -1.5 or so, plenty of grip for canyon carving but without compromising tires lofe span.
The Following User Says Thank You to Teseo For This Useful Post:
Old 04-03-2023, 09:57 PM   #19759
pope
has a funny hat
Drives: 2014 BRZ Limited
Drove it for the first time since it went into winter storage in October.
Weather forecast was a bit off though. Rainy drives are still fun.
pope is offline   Reply With Quote
Old 04-08-2023, 06:57 PM   #19760
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Looked at it. Going up to 15c this week, may take it out of garage, 4 months hibernation
is enough.
CB750F is offline   Reply With Quote
Old 04-08-2023, 09:37 PM   #19761
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Originally Posted by CB750F View Post
Looked at it.
Your power must be back if you got the garage door to open…
Since there are lots of Chocolate Rabbits around for tomorrow its a reminder that you have to pick up a new battery to replace that 8 yr old exhausted one ..
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
Dadhawk (04-08-2023)
Old 04-14-2023, 01:56 PM   #19762
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
A few days ago, but changed up the gauge cluster face.
Oxyg3n is offline   Reply With Quote
The Following 3 Users Say Thank You to Oxyg3n For This Useful Post:
Busybee (04-16-2023), KMA KiCKz (04-14-2023), villainous_frx (04-14-2023)
Old 04-17-2023, 12:00 AM   #19763
Oxyg3n
Oxyg3n's Avatar
Took it to 86 Cafe
Busybee (04-17-2023), Clipdat (04-17-2023), MrSkubi (04-17-2023)
Old 04-17-2023, 11:28 AM   #19764
almostquick
Drives: 2017 BRZ PP
Very nice. Where did you get the gauge cluster faces from?
almostquick is offline   Reply With Quote
Old 04-17-2023, 06:29 PM   #19765
Oxyg3n
Oxyg3n's Avatar
@almostquick thanks. Got them from revlimiter.net
Old 04-22-2023, 08:34 AM   #19766
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Finally had the time for the Fumoto valve, changed the oil (Idemitsu) and the filters. I was a little concerned due the slope but everything went smoothly.
Her favorite shoes are also on!
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following 6 Users Say Thank You to Busybee For This Useful Post:
Clipdat (04-23-2023), JD001 (04-22-2023), new2subaru (04-22-2023), RToyo86 (05-02-2023), Teseo (04-23-2023), The Red One (04-22-2023)
Old 04-22-2023, 10:33 AM   #19767
JD001
JD001's Avatar
Drives: Subaru BRZ
Finally got round to booking my BRZeeeeee in to get the KW V3s setup as at the moment it's running with the KW "out of thd box" set-up which is too low for me.. Decided to also have the Superpro rear suspension arms and the toe links installed.. Just curious to see what the extra rear camber adjustment does to the car's handling... The front camber bolts were definitely noticed, sharper turn-in.
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Busybee (04-22-2023), Clipdat (04-23-2023)
Old 04-22-2023, 10:36 AM   #19768
JD001
JD001's Avatar
Drives: Subaru BRZ
So you didn't manage to talk to the guy across the road about using his nice flat driveway?
