Old 03-19-2023, 05:10 PM   #1
Jedistylez
Exclamation CEL and Traction Control light - P0171
So I recently just installed an aftermarket over pipe and UEL headers and didn’t have any issues at first, however after about a day or two the CEL and TCS light came on and I am unable to turn off the TCS light. I also installed a CAI but put the stock intake back thinking it might have been that. My LTFT percentage is way too high at 37% when idle but goes down to normal percentage range when driving. Could this be from an exhaust leak/vacuum leak? It’s a 2017 auto.
Jedistylez is offline   Reply With Quote
Old 03-20-2023, 04:14 PM   #2
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Are you absolutely sure there are no exhaust leaks from the header or overpipe install? Or the intake fiddling? If not, was the car tuned for the headers & overpipe?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 03-20-2023, 05:53 PM   #3
tomm.brz
Drives: brz 2017 hksv2
high probability of exhaust leak near the front o2 sensor
stock tune with stock airbox won t give +35% or more of ltft just for exhaust header unless the front lambda is measuring some fresh air
Old 03-20-2023, 08:29 PM   #4
Jedistylez
I’m sure I tightened everything well but there might be an exhaust leak. I’ll have to check it out to be sure but I used an OFT2 stage 2 plus tune for the headers. It’s only high when idling but when driving the percentages are normal.
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 10:00 PM
ABS and Traction control light DSW Issues | Warranty | Recalls / TSB 3 03-12-2023 11:38 AM
Traction Control & ABS light on darkofrs Issues | Warranty | Recalls / TSB 7 04-02-2022 01:06 PM
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 10:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 08:37 AM
