Old 02-19-2017, 05:53 PM   #1
Johnders2586
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help
Hey Guys,
Just got this code and was wondering if anyone had some advice as to what to check or look for. Possible causes?
Some back ground on the Vehicle.
13 BRZ with about 78K on it.
Recently installed OFH and flashed stage 2 about 4-500 miles ago.
Car started kind of funny and had the CEL come on. After a short drive i checked the code using my OFT and it said no codes showing.
Reset my battery, drove to the store and back no CEL
Went out later on, started driving, light came back on, stopped checked code, got P0140 as shown in the description. cleared code, hasnt come back on yet.
Im wondering if its possibly a bad 02 sensor? It seems the code is saying it not detecting the sensor.
Thanks.
Any thoughts would be great.
Johnders2586 is offline   Reply With Quote
Old 02-01-2018, 03:48 PM   #2
jenzan
jenzan's Avatar
Drives: '13 Subaru BRZ SSP 6 MT Sport Tech
Does anyone have an answer? Also looking into the same issue. Thanks!
jenzan is offline   Reply With Quote
Old 02-01-2018, 04:14 PM   #3
jasonojordan
Drives: 2013 satin white brz limited
Have either of you checked to make sure the sensor wires and intact and connected properly to the harness? Any other mechanical updates in either case before the issues started?
jasonojordan is offline   Reply With Quote
Old 02-18-2023, 08:35 PM   #4
TheYeetler
Drives: 2013 FRS
Having the same issue stage 2+ tune and it came on immediately after I hit 110 getting on the highway. As soon as I let off the gas it came on immediately came home and that’s the code I got
Stage 2+
Uel headers
Berk muffler delete
TheYeetler is offline   Reply With Quote
Old 02-18-2023, 08:36 PM   #5
TheYeetler
Drives: 2013 FRS
And all the wires look intact
Old 02-19-2023, 03:33 AM   #6
tomm.brz
Drives: brz 2017 hksv2
you can very well disable those dtc and also disable the secondary sensor by zeroing the Af#3 tables
People with flex or whoever hooks up aftermarket sensor to the o2 input, do it all the time, all the people i Tuned have thst sensor disabled in tune
Old 02-19-2023, 11:23 AM   #7
TheYeetler
Drives: 2013 FRS
How would I go about disabling the o2 sensor
Old 02-19-2023, 11:38 AM   #8
tomm.brz
in romraider there are 2 tables called A/F#3 limits, put them all to 0
then disable DTC: P0037,P0038,P0137,P0138,P0140,P0141
Done
Old 04-01-2023, 02:38 PM   #9
rydertm
Done
I’m not too experienced with rom raider and I can’t find the A/F #3 tables, the only two I see both say A/F #1. Do you know where I could find them?
rydertm is offline   Reply With Quote
Old 04-04-2023, 04:32 PM   #10
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
A few weeks ago I had my turbo installed. For the last few years was running un catted UEL headers and the stage 2 OFT tune. Using the base tune for my kit until my ecutek arrives. I’ve had no codes for the first month of FI. This morning p0240 popped up.
I was told I could use tactrix(my base tune is running off it) to clear the code. The Instructions above about RomRaider are pretty much the same? Or would i be looking at different paths and values.
Sorry I’m not to experienced with tuning but I’m trying to learn.
My tuner told me I would be able to do this in tactrix but I can’t find any sort of step by step instructions.
Thank you in advance.
Sur is offline   Reply With Quote
Oxygen sensor cross threaded. Zaneman Issues | Warranty | Recalls / TSB 13 07-05-2017 01:14 PM
DIY: Oxygen sensor spacer Hardrock4445 DIY (Do-It-Yourself) Guides 13 07-11-2015 12:43 PM
O2 Oxygen Sensor Fuse Location? Synack Engine, Exhaust, Transmission 6 04-09-2015 10:47 PM
WTB: Stock oxygen sensor Njjawn NY / NJ / CT / PA 5 01-17-2015 04:53 PM
WTB: OEM Rear Oxygen (o2) Sensor xjohnx Want-To-Buy Requests 5 04-07-2014 11:32 PM
