#1233 | |
Drives: '23 CWP BRZ
The car left the garage for the first time in a little over a month, haha. Still need to do some tweaking on the camber to get the fitment more to my liking, get the front a little lower and install some other odds and ends but it's almost ready to get an alignment.
Bagriders Superlow with P2M front LCA and rear LCA, UCA and toe arms. ![]() ![]() Here's a lil video of the max range of the kit at my current setup. I can probably raise the car another few inches, still air out to the ground and lift more. Definitely a lot here. Quote:
| The Following User Says Thank You to 636 For This Useful Post: | DriveDriftDogfight86 (01-16-2023) |
#1234 |
Drives: '22 BRZ
Finally got my APEX Racing VS-5RS wheels that I ordered in July.
![]() ![]() Got some hood struts for Christmas so I installed those yesterday
#1235 |
Drives: '22 BRZ Limited MT
Installed an HKS Spec L II catback. I would have gone with the regular spec L (a few db louder) but the L II tips look much nicer and are swappable.
Pretty happy with it. Sounds way better than stock despite it still being on the quiet side. However, this makes me much less worried about installing headers and being too loud/obnoxious In person, the exhaust tone is much deeper than how it sounds on most video clips this one Code:
https://www.youtube.com/watch?v=FGs76FwZMwk Cold start is noticeably louder but nothing crazy. Once the rpms drop it's actually hilariously quiet |
| The Following User Says Thank You to jetvermillion For This Useful Post: | BioRebel (01-26-2023) |
#1236 | |
Drives: "I drives like a Porsche"
| The Following User Says Thank You to Liquidsnake For This Useful Post: | jetvermillion (01-21-2023) |
#1237 |
Threw on SPC 81305 camber bolts over the weekend. Swapped the lower bolts into the top holes for additional camber. Couple of notes:
- The SPC bolts I used were brand new but I couldn’t seat the nuts by hand. There was a ton of resistance in the first 1/3 of the thread (estimate around 10 ft-lbs to spin it through with a socket wrench). It took so much force the nuts actually heated up. It loosened up progressively after that towards the middle of the thread and took the full 97 ft-lbs so I’m not too worried. I had a set of SPC upper bolts on my 1st gen and didn’t run into this issue. Strange. - I used a 3mm spacer in the front to try to clear my Apex ARC-8’s (17x9 +42; 235/40/17) on stock suspension. Clearance was fine but I only got 4.5 full turns on the lug nuts. I tried my Wedssport TC105n (17x8 +42; 235/40/17) and got 7.5 turns on the nuts. I guess the Apex wheels have a thicker center plate, not sure. Given this, I’ll probably switch to a single camber bolt + Pedders camber top hat in the future to fit my Apex wheels. -Spacers were from Stancemagic (don’t laugh). Only ~$20 on Amazon and they’re hubcentric. Pretty good quality, no vibrations I could feel up to around 85 mph. - The amount of camber from this setup is pretty impressive. Visually it looks close to the -2.8 degrees I was running on my 1st gen. I’d estimate somewhere between -2 to -2.5 degrees. My understanding is that toe doesn’t change in the front much with camber, so will probably drive like this for a while and see how it feel before aligning it.
2022 BRZ Build 2013 FR-S Build |
#1238 |
Drives: '22 BRZ
I had similar experience with those same camber bolts last week, the locking nut was pretty darn tight.
With stock wheels I was getting ~10 turns on my Eibach studs (10mm extended and 10m spacer) but I'll check again with the APEX wheels. I get like 8 turns with my Enkeis. I also have stancemagic spacers to put on the car, they're really nicely made and no complaints. Toe *barely* changed on my car going from -4.5 to -4.8, like 1/64th of an inch or so.
| The Following User Says Thank You to DocWalt For This Useful Post: | DarkSunrise (01-23-2023) |
#1239 |
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
Delivered some tofu with a friend today
| The Following 5 Users Say Thank You to DriveDriftDogfight86 For This Useful Post: | bcj (01-26-2023), DNAcomposition (01-23-2023), JD001 (01-25-2023), soundman98 (01-26-2023), Wally86 (01-26-2023) |
#1240 | |
Drives: 23 BRZ
Which ones did you get? |
#1241 |
Drives: '23 BRZ Limited 6MT WRB
#1242 |
| The Following User Says Thank You to DriveDriftDogfight86 For This Useful Post: | DNAcomposition (01-23-2023) |
#1243 |
Drives: '22 BRZ
The Noble non-CF. They fit great and work well.
| The Following User Says Thank You to DocWalt For This Useful Post: | rb6freak (01-24-2023) |
#1244 |
Lots of dev work going here, so we swapped back to our Street Rat muffler delete for more testing.
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Wally86 (01-26-2023) |
#1245 |
Drives: 18 Brz (Sold) / 22 BRZ
Had lots of fun plowing snow
| The Following 4 Users Say Thank You to Stonehorsw For This Useful Post: |
#1246 |
Drives: Mini Cooper S
For those who miss the feeling of a bite point in the clutch pedal, the mtec clutch spring is a pretty good mod. Installation is a total nightmare though, I'm not a big person (5'11") but I had to remove the driver seat to get in there and swap it out.
| WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 11:36 PM |
| Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 03:51 PM |
| just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 11:05 PM |
| TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 02:16 AM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
