| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#29 |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | x808drifter (11-01-2022) |
#30 |
Drives: Mini Cooper S
Do these cars have that much of a buildup issue? I'm coming from a 2010 mini cooper where a catch can was kind of required.
#31 |
This depends on who you ask. For those that want all the internals clean and no chance of knock, and optimized performance (real, theoretical, or otherwise), it's important. Others feel it's not important. Really depends on where you fall on that scale and your budget tolerance.
#32 |
PSA for those not on our mailer. We're having a 20% off Black Friday sale on all oiling products. Thanks for the support!
#34 | |
Drives: Don't yet have a Toyobaru
If 3,000 miles worth of separated oil is one forum-standard "puddle," what's the capacity of the AOS? Enough for the recommended oil change interval, absent track use? |
#35 | |
You might find that you can drain every other oil change, or if you just commute and drive like granny, you might be able to get away with once a year. I'm home right now and don't have the max capacity handy but draining every oil change and after a track day, you should come nowhere near the unit's max capacity. |
#36 |
Rust bucket enthusiast
One extremely important thing worth noting is that in cold climates, these(catch cans in general) have a potential to collect a lot of moisture that will smell like gas. Do not let it get full
#37 |
These units are not open to atmosphere. The only time you would smell gas, is when you drain them.
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | DarkPira7e (01-02-2023) |
#38 | |
#39 | |
Drives: 2023 BRZ
So, based on my experience I would say yes. FWIW my car has a touch over 1000 miles, 2023. I will probably give this solution a try. |
| The Following User Says Thank You to nissanfanatic For This Useful Post: | BioRebel (01-10-2023) |
#40 | |
Thank you for your patronage. If you have any questions about the product or install, please don't hesitate to reach out to us. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | nissanfanatic (01-09-2023) |
#41 |
Drives: 2023 BRZ
Just ordered the dual kit. Have a track day at the end of the month so looking forward to testing it out!
#42 |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | nissanfanatic (01-19-2023) |
| Verus Engineering Air Oil Separator - Information and Release | VerusEric | Engine, Exhaust, Transmission | 127 | 07-08-2023 07:40 AM |
| Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) — General Topics | 50 | 10-29-2022 07:36 AM |
| Killer B Motorsport Carbon Fiber Strut Braces | KillerBMotorsport | Groupbuys | 17 | 10-25-2022 10:05 AM |
| FREE Delrin Shift Knob - Killer B Motorsport | KillerBMotorsport | BRZ Second-Gen (2022+) — General Topics | 56 | 04-27-2022 06:32 AM |
| High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 09:51 AM |
