Old 12-29-2022, 05:49 AM   #1
Dyniek
Dyniek's Avatar
Drives: Toyota GT86 TRD '19
Exclamation One wheel won’t rotate!
So I have a GT86 TRD '19 (so brembo brakes) and I haven’t been driving for around a week. Yesterday when I started the car, I tried to go forward and I felt a lot of resistance (I had this situation once, when it felt like brakes just stuck to discs, but then I just added a little more gas, and the car went forward, there was a hearable subtle crack and the problem was nowhere to be seen). So I tried to do the same, added a little bit gas, and I heard thie same sound, but the car still wouldn’t move without resistance. Turns out, my front right wheel still won’t rotate, so it would just slide on surface (I have a little bit of dirt on my driveway).
I tried applying brakes a couple of times, I tried going back and forth and nothing.
I read online that it might be due to corrosion and after checking my brake discs, they’re pretty rusty (car wasn’t moved for a week).
Is this normal? My friends never had this with other cars like BMW and Mercedes.
How do I proceed now to free my car?
How do I prevent this situation in future?
Dyniek is offline   Reply With Quote
Old 12-29-2022, 09:18 AM   #2
Grady
Grady's Avatar
Normal, try not to wash the car the park it. (I do that all the time and they stick)
Need to find some ground with more traction it will break loose. To prevent it, keep the brakes from getting wet when storing.
The Following User Says Thank You to Grady For This Useful Post:
The Red One (12-29-2022)
Old 12-29-2022, 09:47 AM   #3
SCFD
It could also be due to the pad compound. Some pads are just much more prone to this with the worst I've experienced being the Stoptech 309s. They were so bad that it can be completely dry out and I use the e-brake to stop the car instead of my brakes but they'll still seize.
SCFD is offline   Reply With Quote
The Following User Says Thank You to SCFD For This Useful Post:
soundman98 (12-30-2022)
Old 12-30-2022, 07:37 AM   #4
Dyniek
Dyniek's Avatar
I cleaned my driveway, and it immediately got traction and broke loose. Thanks!
Any way to keep my discs dry/rust free when keeping car outside?
The Following User Says Thank You to Dyniek For This Useful Post:
The Red One (12-30-2022)
Old 12-30-2022, 09:12 AM   #5
Grady
Grady's Avatar
Car cover.
Old 12-30-2022, 09:40 AM   #6
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
I learnt my lesson 20 years ago when storing cars over the winter months.
After 4 months of storage my wheels were much stuck as you describe.
I had deducted it was from washing the car before storage and had got the brakes wet and rolling the car into the garage was not enough to dry them off.
A bit of driving once unstuck got the rust off.
Im so obsessed with that now that I will roll down my driveway just to dry off the disks and warm up things if I know I wont be using it for a few days after a wash.
I will even nudge the sleeping BRZ over the winter just to make sure it’s not happening.
My all year driver does not seem to be affected with seized disks (only has 2..) or anything besides collecting tree sap after staying out immobile for weeks at a time.
If you store it outside try to keep it out of the wind when it rains.
I had an unscrupulous Subaru dealer out west that wanted to do a brake service on the then new BRZ after I had left it overnight in the rain and pressure washed by my Brother in law after a long cross country trip… Had an appointment the following morning for an oil change, Dealer said that the disk surfaces needed resurfacing due to the car having been immobile for so long…
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
Overdrive (01-06-2023)
Old 12-30-2022, 01:28 PM   #7
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
The rotors get surface rust very quickly.
Old 01-06-2023, 03:32 PM   #8
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Not really, other than minimizing how long the car sits in between drives so that the pads can clean the surfaces off before it gets excessive. The car is exposed to the elements, so the only way to minimize corrosion on the rotors would be some sort of enclosed storage space. If there's any decent amount of moisture in the air or it outright rains, you're going to end up with corrosion on the rotor faces while the car sits outside. Let it continue to sit after that and it's just going to get worse.
As a matter of fact, I drove my car last night, maybe 16 hours ago, and it is raining today, has been for at least 8 hours. I guarantee when I go out to the car there will be little rust spots on my rotors. It's just a thing that happens.
Someone mentioned a car cover. That may help out, but again, depending on how long the car is sitting in between drives, you're going to get some accumulation of rust on the rotor surface.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
OFT 180° rotate feature missing on v2 bryan86tx Software Tuning 1 08-01-2018 05:16 PM
East Bay NorCal: OEM Wheels, free wheel lock set and wheel totes akacinna Wheels and Tires 2 05-07-2018 01:53 AM
Hear Tire Rotate Zzzquil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-12-2015 05:33 PM
Rotate my own tires? zinzan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-28-2014 01:13 PM
Fuel Injectors, are they supposed to rotate around? rb6freak Engine, Exhaust, Transmission 2 12-22-2013 10:02 PM
