Old 01-04-2023, 09:43 AM   #43
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by Jynx View Post
Update ~
ECU is getting checked tomorrow and may have to go the dealership to get completely replaced and reprogrammed. (if anyone is still following.)
Dang, I was hoping the post would say that you had solved the problem.
Old 01-04-2023, 03:06 PM   #44
Update ~
Wow. Yes, following for sure. Stay with us.
Old 01-04-2023, 05:02 PM   #45
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
the PCM isnt even controlling the valve in the front and is only partially giving a signal to the one in the back
WHAT!? Did no one think to actuate the relevant components with a bidirectional scanner before changing anything? Excuse the language but you don't even need a fucking scanner to function test a purge valve, the damn thing will start pulsing by itself once the engine has run for a few moments, just gotta put a vac gauge on it.
Old 01-04-2023, 05:04 PM   #46
Jynx
Drives: 2013 Subaru BRZ
Code p0441
this was also done. purge valve in the front will not react to anything and yes it has been replaced. we are on the 4th one. same results. the back one was actually leaking out through the electrical plug so no further testing was needed there.
Jynx is offline   Reply With Quote
Old 01-05-2023, 06:59 AM   #47
RZNT4R
That's not what "checking" means. If a valve doesn't open, why would changing it again help, did no one even try to find out why it wasn't getting actuated?
Old 01-05-2023, 07:05 AM   #48
Jynx
Code p0441
the ecu isnt giving it power. sorry, I'm not very good with electrical stuff and ECU stuff. that is why i got my shop peeps doing all of that.
Old 01-05-2023, 07:55 AM   #49
RZNT4R
The ECU does not give power to the purge VSV, it switches the ground side of the circuit.
(from the '17 wiring diagram) It gets power from the EFI(CTRL) fuse through the EFI MAIN1 relay. Key-on engine-off you should have B+ at the red wire of the purge VSV plug. The ECM switches ground on the yel/green wire to actuate the valve.
Old 01-05-2023, 07:39 PM   #50
Jynx
Code p0441
weird. the dealership said completely something different and everything is pointing to the ECM. today they checked all the relays and and purge valves and said they all have power and are operational. they just said that the ECM is not telling it what to do which leads to P0441. they are hopping back into it tomorrow and I'll have a definite answer.
Old 01-05-2023, 09:13 PM   #51
RZNT4R
I mean, I'm not asking for them to parse a diagnostic flowchart, that's way too hard but any child can see what does what in that circuit from even a quick glance.
It's even worse if they've got the factory wiring diagram that is very simple and has very few components per page versus a wiring like prodemand which shoves as many components and wires on a single page as possible.
You're looking for D1 Purge VSV. Down from that is a red wire going to (F), that's hot in run B+. Up from the VSV is the ECM which switches ground. If they want to test a simpler circuit than this they'll have to look at a door ajar switch, damn.
Old 01-06-2023, 12:30 PM   #52
Jynx
I'll let them know. thank you for the help even though i cant tell if your being nice or a little harsh but either way it helps and thank you for explaining it. I'm no mechanic here so me trying to explain it to you guys is probably like a 5 year talking.
Old 01-06-2023, 01:15 PM   #53
I would be willing to bet that the proper testing has been done by the techs and something is being lost in the translation by the time the info makes it here.
Old 01-06-2023, 03:09 PM   #54
RZNT4R
I'm both being nice and harsh. Harsh on the "techs" who can't figure this out.
I mean, sometimes things happen, like you order a sensor from napa and it's shit, recheck everything back to front and upside and go through, over and under the diagnostic chart and invent new steps to double and triple check even harder and you come to the same answer and pissed off you order the real one from the dealer at 3x the price and it works perfect, sure, that happens, I've lived that nightmare.
But 4x? Someone needs to tell these clowns they need to diagnose things more than not at all.
The Following User Says Thank You to RZNT4R For This Useful Post:
x808drifter (01-09-2023)
Old 01-09-2023, 03:14 PM   #55
Jynx
update. evap code is gone now. the little connector that plugs into the purge valve under the intake was faulty. the wires werent all the way into the plug which is why it wasn't getting power. after that was fixed, now the car is throwing a P0700 and a U0122 code. fixed 1 problem and got 2 more lol. any help with these would be much appreciated!
Old 01-10-2023, 07:06 AM   #56
RZNT4R
Clear them.
U0122 sometimes trips when a scantool hops on the network, P0700 is the transmission going "wtf dude there's a U0122!"
Mine doesn't do p0700 because it's manual, but half the time I connect a scan tool to mine it'll pop the U0122, even a dealership techstream made it pop. Clear and ignore.
Help diagnosing P0441 code 1Saucyyy_brz Issues | Warranty | Recalls / TSB 3 09-18-2022 06:45 PM
Engine code p0171 and p0441 frscory Issues | Warranty | Recalls / TSB 6 02-20-2022 07:06 PM
Having trouble with code p0441 Jynx Issues | Warranty | Recalls / TSB 5 02-19-2022 06:17 PM
p0441 cel code bryan.catano93 Engine, Exhaust, Transmission 5 03-12-2018 12:38 PM
Check engine code P0441 Gibson Engine, Exhaust, Transmission 0 11-23-2016 06:39 PM
