timurrrr
Old 01-03-2023, 09:02 AM   #1093
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by RippedManiac View Post
Its a family curse at this point
^ Correct.
All the FA engines are assembled using the same methods.
KillerBMotorsport is offline   Reply With Quote
Old 01-04-2023, 12:46 PM   #1094
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
No, no , no. You said this.
This is what my comment is referring to. Don't change the subject or try to paint it as a response that it is not. This kind of stuff takes time, like watching a cruise ship try to turn. No doubt Toyota and Subaru looked into what caused the issue, the corrective measures in production. How many units were affected. Probability of failure and so forth. Corrective measures on potentially affected cars will probably follow if there are any. It's only been what, 6 months since this issue popped up.
I responded to your comment, I'm not a mind reader.
This is what you said.
"Yet the J02 recall was done entirely voluntarily after very, very, few failures and it is the same manufacturer that we are currently talking about"
Seemed like your are comparing the issues, so I dug into it. Pretty simple bud.
Blighty is offline   Reply With Quote
Old 01-04-2023, 03:52 PM   #1095
OkieSnuffBox
Drives: '23 BRZ Limited
So just for fun I sent my dealer an email regarding pulling the pan for the first oil change, the mention of "oil pan seals" is very interesting. As well as needing to pull the engine to replace the strainer vs just cleaning it out.
"The oil change interval for the complimentary maintenance is scheduled at either 6 months or 6,000 miles (whichever comes first). I am showing that this should be due on March 03, 2023 if that is the case.
Also, we would be more than happy to remove the oil pan during the oil change. But there are some issues I would like you to be aware of:
The first issue is that the oil pan seals are not currently available. We looked up the part numbers and they show Backorder with no E.T.A. as of today.
I would definitely avoid pulling the pan off until those seals were in stock and readily available.
The second issue would be that it is not something that Subaru would cover under warranty unless there was a specific failure. If we were to remove the oil pan and found nothing wrong, they would not pay for the labor or parts needed for this. The cost would be $734.00 to do this.
If we did pull it off and found something wrong or any excess RTV inside, then it would become a warranty issue and it would be covered entirely. My shop foreman informed me that if it were the case, we would need to actually remove the entire engine out of the vehicle to replace the strainer and the other items needed for this. In that case, I would just advise you to be prepared for the vehicle to be down for several days
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
Ash_89 (01-05-2023), formulaBRZ (01-06-2023)
Old 01-04-2023, 04:10 PM   #1096
KillerBMotorsport
~4,500 miles and it's pretty clean...
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post:
Blighty (01-07-2023), DylanJZA (01-05-2023), justinco (01-04-2023), Tcoat (01-05-2023)
Old 01-04-2023, 04:16 PM   #1097
OkieSnuffBox
That's good to see. I just thought it was interesting they said "oil pan seals" are on backorder........when it uses RTV to seal.
Old 01-04-2023, 08:25 PM   #1098
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I would not risk having them pull the pan and re-seal it if that's what they know about these engines.
Follow the build thread for my GR86!
The Following 11 Users Say Thank You to timurrrr For This Useful Post:
DarkSunrise (01-05-2023), DocWalt (01-05-2023), DylanJZA (01-05-2023), formulaBRZ (01-06-2023), justinco (01-05-2023), KillerBMotorsport (01-05-2023), NoHaveMSG (01-04-2023), Ohio Enthusiast (01-04-2023), Pat (01-04-2023), soundman98 (01-04-2023), Teseo (01-04-2023)
Old 01-04-2023, 08:31 PM   #1099
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Probably easier to seal the front cover with the engine out.
Old 01-04-2023, 11:31 PM   #1100
OkieSnuffBox
That was my first thought as well. Then I checked the email sig and the response wasn't from the service manager. So I don't know if he's just trying to blow smoke , something was lost in translation or what.
But pulling the engine out instead of just cleaning out the pickup was the bizarre thing to me.
Old 01-05-2023, 07:07 AM   #1101
KillerBMotorsport
Yeah, very odd.
I could see an inexperienced service advisor mentioning seals, and just not know there are no traditional seals, but going a step further in stock and delivery of said seal, is just odd.
Old 01-05-2023, 08:24 AM   #1102
Is there a reason this can't be expected with a scope through the oil drain, or am I missing something completely obvious? (I haven't looked at this at all, it just occurred to me).
Old 01-05-2023, 08:28 AM   #1103
There are baffle plates in the way.
Dadhawk (01-05-2023)
Old 01-05-2023, 09:26 AM   #1104
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
There are 2 rubber o-ring seals on the oil pan that are also supposed to be replaced each time the pan is removed, this is likely what they were referring to. Interesting to see that some on this forum don't know this but are pulling pans....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 12 Users Say Thank You to Opie For This Useful Post:
DarkSunrise (01-05-2023), dawsonj87 (01-05-2023), DocWalt (01-05-2023), DylanJZA (01-05-2023), mn_ca (01-05-2023), NoHaveMSG (01-05-2023), OkieSnuffBox (01-05-2023), Pat (01-05-2023), Rustyoid (01-05-2023), soundman98 (01-05-2023), Tcoat (01-05-2023), Tokay444 (01-06-2023)
Old 01-05-2023, 10:34 AM   #1105
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
and those parts were out of stock, didn't bother checking to see if they're in stock just now.
That said, I see no reason they can't be reused, they weren't deformed or smashed on my car.
DocWalt is online now   Reply With Quote
Old 01-05-2023, 11:17 AM   #1106
Sasquachulator
Pavement Grey
Thats usually standard practice no?
You usually never supposed to reuse a gasket?
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
DylanJZA (01-05-2023), Opie (01-05-2023)
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
