Old 12-23-2022, 11:14 AM   #15
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Replace the transmission snout, the part that the TOB rides on, along with the fork, pivot & springs....you will thank me.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
Jdmjunkie (12-23-2022), WNDSRFR (12-23-2022)
Old 12-23-2022, 11:47 AM   #16
WNDSRFR
Drives: FR-S,GTI
Originally Posted by blsfrs View Post
Is that the original fork? If so, 10 years and 240,000 miles ain't too bad. Given the history of this component in the older twins, it would prolly be a good idea to change the fork and pivot whenever you change a clutch.
Yea, it's the original fork. And it should be the original clutch. Except that when the first TOB blew I ordered the stage one kit from Exedy. The original clutch was fine but I replaced it anyway. The last time I changed the TOB I did the snout also. It still looks ok. I think I'll just polish it and reuse it. This time I'll grease the crap out of it though. I think that's what caused the failure of the fork. The TOB was binding on the snout. There's plastic powder all over the snout. I think maybe one of the clips let loose that caused everything.
The Following 4 Users Say Thank You to WNDSRFR For This Useful Post:
blsfrs (12-24-2022), Opie (12-23-2022), soundman98 (12-23-2022), Spuds (12-23-2022)
Old 12-23-2022, 02:07 PM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
can you post a picture of the snout? i'm beginning to get curious on it's wear patterns.
Old 12-23-2022, 02:52 PM   #18
WNDSRFR
Drives: FR-S,GTI
This is unbelievable.
I ordered the parts I need. I got the fork, pivot, clips and TOB.
Now I can't find any oil. I'm looking for Motul Gear 300 75W90 because that's what I use. I found some in Italy and in Canada. And the shipping cost more than the oil. Maybe I'll switch to Redline. Or is there something wrong with Valvoline? It costs about 10 times less.
Old 12-23-2022, 02:55 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Anything that fits factory spec is fine. I like Mt90. I know others that swear by Valvoline.
NoHaveMSG is online now   Reply With Quote
Old 12-23-2022, 02:56 PM   #20
WNDSRFR
Drives: FR-S,GTI
Here's my snout. I cleaned it but haven't polished it yet. I think some 2000 grit should take care of the minor scratches.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Old 12-23-2022, 07:17 PM   #21
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, this is making me lean in a direction on my Verus fork vs snout sleeve issue...
I may have a snout sleeve kit available soon...
Edit, I really need to read the whole thread before posting...
Also: "Build Thread"
Old 12-23-2022, 07:34 PM   #22
Spuds
The Dictater
Spuds's Avatar
Amsoil manual transmission and transaxle gear lube is what I use. I am quite happy with it and it seems to be available.
e1_griego (12-24-2022), WNDSRFR (12-24-2022)
Old 12-23-2022, 07:39 PM   #23
Spuds
The Dictater
Spuds's Avatar
Here is mine before cleaning as another point. Yes, I know there's a lot of grease and clutch stuff...
The Following User Says Thank You to Spuds For This Useful Post:
soundman98 (12-24-2022)
Old 12-24-2022, 09:34 AM   #24
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I wonder about the wisdom of too much grease on the snout. In the bell housing, fine dust from the clutch disc is whirling around and getting impregnated in that grease eventually making it more of an adhesive than lubricant. IMHO grease on the snout will cause premature failure.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
soundman98 (12-24-2022), WNDSRFR (12-24-2022)
Old 12-24-2022, 01:57 PM   #25
WNDSRFR
Drives: FR-S,GTI
Good point about the grease.
As far as the oil goes, I think I'll just go to Walmart and buy the cheapest GL4 75w90 oil they have. That's what I do for motor oil. I get the cheapest full synthetic 0-20 they have. Or I'll get Amazon oil if it's on sale. I think people way overthink oil. I find it hard to believe the difference people think different oil brands make. I'll bet Motul buys it's bulk oil from Pennzoil and relabels it at 3 times the cost.
Oil is oil.
Gas is gas.
blsfrs (12-24-2022)
Old 12-24-2022, 01:59 PM   #26
WNDSRFR
Drives: FR-S,GTI
And isn't it something that the transmission takes 2.2 liters of oil and is sold in quart containers.
blsfrs (12-24-2022)
Clutch or transmission problem? 86runner Engine, Exhaust, Transmission 13 04-12-2022 08:34 PM
SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB zc06_kisstherain Transmission and Driveline 3 10-17-2018 11:31 PM
ACT Clutch Adjustment Problem Shady195 Engine, Exhaust, Transmission 17 10-20-2016 03:42 PM
Clutch problem? Pele86 Engine, Exhaust, Transmission 13 06-04-2013 11:58 PM
